Mainiac Posted October 15, 2017 Posted October 15, 2017 Usually the last trip home of the season, after dumping, we put a couple pounds of ice cubes into the tank with some water. The "splash blending" going down the road really cleans the tank. By the time we are home it is mostly water. That can be dumped into a 5 gallon bucket and the poured into a cleanout or the home toilet. I like to use Eco-Save during the season, as an additive. I think it smells good and has no chemicals. It is bacterial and you only add when waste is present and it digests that. Just not easy to find everywhere... 2
Free2Roam Posted October 15, 2017 Posted October 15, 2017 Usually the last trip home of the season, after dumping, we put a couple pounds of ice cubes into the tank with some water. The “splash blending” going down the road really cleans the tank. By the time we are home it is mostly water. That can be dumped into a 5 gallon bucket and the poured into a cleanout or the home toilet. I like to use Eco-Save during the season, as an additive. I think it smells good and has no chemicals. It is bacterial and you only add when waste is present and it digests that. Just not easy to find everywhere… Thanks Canoe12! Do you just put the ice down through the toilet? 2017 Legacy Elite II Standard 2006 Chevy 2500 HD Diesel 4WD
KarenLukens Posted October 15, 2017 Posted October 15, 2017 Also, question for anyone, we have the macerator and I was wondering if you are supposed to turn it on and then pull the black tank lever or pull first and then turn it on. I also assumed we leave the macerator going for the gray tank too. -Angela You don't need the macerator for the gray tank. After filling the black tank and letting it run out the first time, I leave the water flush system running and walk away for a few minutes to let it run. When clear water comes out, I fill it up to 80%+ to 95% at the most on accident... Lol, then pull the handle and let it run clean again. Then refill it again and it should run clean from start to finish, letting you know that it's perfectly clean. These 2 movies go together but had to be listed separately on this page,so there's another page now... Haha Oliver :) Reed 2 Happy Camping, Reed & Karen Lukens with Riffles our Miniature Poodle 2017 Oliver Legacy Elite II Standard, Hull #200 / 2017 Silverado High Country 1500 Short Bed 4x4 Past TV - 2012 Mercedes-Benz ML350 4Matic BlueTEC Diesel Click on our avatar pic above to find the videos on our Oliver Legacy Elite II
KarenLukens Posted October 16, 2017 Posted October 16, 2017 But had to be posted here separately... 2 Happy Camping, Reed & Karen Lukens with Riffles our Miniature Poodle 2017 Oliver Legacy Elite II Standard, Hull #200 / 2017 Silverado High Country 1500 Short Bed 4x4 Past TV - 2012 Mercedes-Benz ML350 4Matic BlueTEC Diesel Click on our avatar pic above to find the videos on our Oliver Legacy Elite II
Mainiac Posted October 16, 2017 Posted October 16, 2017 Yes, we just empty ice cube trays into the toilet and flush. Simple and effective. 1
Free2Roam Posted October 16, 2017 Posted October 16, 2017 You don’t need the macerator for the gray tank. After filling the black tank and letting it run out the first time, I leave the water flush system running and walk away for a few minutes to let it run. When clear water comes out, I fill it up to 80%+ to 95% at the most on accident… Lol, then pull the handle and let it run clean again. Then refill it again and it should run clean from start to finish, letting you know that it’s perfectly clean. These 2 movies go together but had to be listed separately on this page,so there’s another page now… Haha Oliver ???? Reed <iframe id="fitvid0" src="https://www.youtube.com/embed/m1BcI56Y7lc?feature=oembed" frameborder="0" allowfullscreen=""></iframe> Thank you for this, Reed!! So very helpful!! -Angela 2017 Legacy Elite II Standard 2006 Chevy 2500 HD Diesel 4WD
Moderators Mike and Carol Posted October 16, 2017 Moderators Posted October 16, 2017 We filled it about 20% full on our flushes (did 3). Wasn’t sure how much to fill. We had only used it about a day and a half. When you are “leaving the water running while draining”, are you leaving the valve under the dinette seat open too or do you mean you close the valve and let it fill back up while draining? -Angela If we need to dump and we’re not at 70 or 80% I turn on the water for the black flush until it gets up to 80%. Then I pull, leaving the water running into the black tank. When it gets down to zero or 5% I close the valve and fill again. Sometimes with the water running it won’t get below 5%. Then I do it a third time. When it gets down to zero I shut the black flush water off and let the tank drain. Then I do the gray tank. I leave the valve under the dinette seat open most of the time. I have a back flow preventer on my hose and I think there might be one built in. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Free2Roam Posted October 16, 2017 Posted October 16, 2017 If we need to dump and we’re not at 70 or 80% I turn on the water for the black flush until it gets up to 80%. Then I pull, leaving the water running into the black tank. When it gets down to zero or 5% I close the valve and fill again. Sometimes with the water running it won’t get below 5%. Then I do it a third time. When it gets down to zero I shut the black flush water off and let the tank drain. Then I do the gray tank. I leave the valve under the dinette seat open most of the time. I have a back flow preventer on my hose and I think there might be one built in. Mike thanks, Mike! This is very helpful. -Angela 2017 Legacy Elite II Standard 2006 Chevy 2500 HD Diesel 4WD
hellsbay988 Posted October 16, 2017 Posted October 16, 2017 I agree with the post above. Why not just leave your sewer hose hooked up all the time. Not sure about leaving brass and another metal hooked up all the time. Electrolysis can be a nasty unintended consequence.
ccarole Posted October 18, 2017 Posted October 18, 2017 Hellsbay, What are the consequences? Do the metals fuse together? Corrode? Carole Carole ....and a couple of Malinois 2016 Legacy Elite II #175 2016 Ram 2500
hellsbay988 Posted October 18, 2017 Posted October 18, 2017 Electrolysis occurs when an electrically charged metal comes in contact with salt or similar elements . Since salt and many other trace elements are often found in drinking water I would use a plastic hookup. Many of the other elements found in water are corrosive over time especially if it’s well water. It would depend on the water but why take a chance. With plastic you will never strip the threads by accident. If there is leakage it’s probably because the the threads are stripped or the hose washer needs replacing. 2
ccarole Posted October 18, 2017 Posted October 18, 2017 Good info. Thank you hellsbay. Good reasons to go pvc....and ugh,the dreaded cross threads. Carole ....and a couple of Malinois 2016 Legacy Elite II #175 2016 Ram 2500
Geronimo John Posted December 12, 2018 Posted December 12, 2018 I have two replacement knees and totally agree with your suggestion about knee padding. I carry a standard inexpensive boat throw cushion. Walmart for about $8, the kind that are square, orange,and about 3" thick. It makes reaching those water valves a lot nicer. But mostly it makes changing a spare tire possible. I keep one in my TV and one in the shop. They are also handy to sit on when riding in the boat! TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators SeaDawg Posted December 12, 2018 Moderators Posted December 12, 2018 Good suggestion. We always have some type of padding available in the truck bed.. Btw, did you know that trumpetguy sold his trailer at least a year or two ago? Just an fyi...I know it's not easy to see on the forum. Sherry 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Spike Posted December 14, 2018 Posted December 14, 2018 the act of kneeling, stooping, hauling, and all the physical activities associated with setting up and breaking down camp place a huge strain on the knees One of the best purchases we have made for traveling with our Oliver are two of these GCI Outdoor Quick-E-Seat Folding Tripod Field Chairs. Liz and I are guitarists, and we originally bought these to be able to carry with us along with our guitars when attending outdoor jams with other musicians, etc. I have found the chair a great help when working on various tasks associated with our Oliver II: hooking up tow cables and wires, working on the tires, accessing stuff in the basement, hooking and unhooking the water lines, placing chocks, etc. I don't need to kneel or stoop. We carry a foam knee pad in the basement but have yet to need it. The travel chairs are just about the right height for all of those tasks otherwise requiring one to kneel. They fold up and unfold easily. They also have a shoulder strap, so one can easily transport them. We have found them useful for things like events where we have had to stand in line; we can sit when we want. As musicians, we love them, for we can walk into the woods, find a nice place to practice, and have some relatively comfortable seating. They would, it seems, be great for fisherpeople to take to the lake, stream, or beach. 2 Onward through the Fog! EarthPicks of Cochise County
Trainman Posted March 30, 2019 Posted March 30, 2019 Quick question, since we don't have our new Oliver until July, will I have to raise the dinette seat everytime to to open the flush value so the water will come in from the connected hose outside. Looks like a one-way valve would work here and save the flush time by not having to move the cushion and seat base to get to it. Has there be an upgrade to this system or does it still operate this way. trainman 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold.
Moderator+ ScubaRx Posted March 30, 2019 Moderator+ Posted March 30, 2019 Our trailer (hull # 050) does not have an interior valve in the black flush line. It does have a one-way check valve and that is all you need to prevent black water from running back into the flush hose. And, never having to raise the cushion to manually operate the on-off valve. If one wanted to keep the original concept in place, I would remove the manual valve and replace it with an electric valve with a switch mounted in a convenient location. I did this with the winterizing valves at my pump so as to not have to jump through hoops in order to get to them when we wanted to pump water into our fresh tank while boondocking. Set up my water cans, flip the switch for the valves, turn on the water pump and voilà, refilling the tank. Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Rumline Posted April 1, 2019 Posted April 1, 2019 Ours (#344) has the valve, but I keep it open all the time and have not suffered any ill effects, including odor wafting out the fill port. I remember reading somewhere else on this forum that there is a check valve installed in addition to the manual valve. 2018 OLEII #344 | 2018 Ford Expedition
Moderators topgun2 Posted April 1, 2019 Moderators Posted April 1, 2019 Yes, on these newer Olivers there is both a check valve and a ball valve. If you chose to leave the ball valve in the open position be very careful as to making sure that you do NOT attach your water hose to the incorrect inlet. If, by mistake, you attached your hose to the black tank flush thinking that you had actually attached it to the city or fresh water inlet you would shortly have a BIG mess on your hands (first the blank tank would fill and then it would overflow into the interior of your Oliver). Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Rumline Posted April 1, 2019 Posted April 1, 2019 Yikes! No bueno. Fortunately the fresh/city water inlet and the black tank flush connector have considerable separation from each other, to the point that I don't think I'll ever make that mistake. And if I do, you'll get to say "I told you so!" lol But your warning is well taken. 2018 OLEII #344 | 2018 Ford Expedition
Ray and Susan Huff Posted August 8, 2020 Posted August 8, 2020 On 8/23/2016 at 1:33 PM, Hap said: but now we are in Dodge City, Kansas meandering back to Florida. Who turned on the heat? Two days ago in Wyoming we were having morning temps of 36 degrees. I think it hit 100 in Dodge today. The second Oliver I've read that visited Dodge City. It's on my bucket list as my dad lived there as a young boy until dust pneumonia forced his family to move him to California. If not for the dust bowl, I wouldn't be . . . . . . . deep thought, I know. Anyway, I'm anxious to see where dad spent his boyhood, visit a museum and see what his life was like as a child. Ray and Susan Huff Elite II Twin "Pearl" - Hull#699; delivered December 7, 2020 2013 F350 6.7l diesel Super Duty 4x4 long bed crew cab 1UP-USA Heavy-duty bike rack 2017 Leisure Travel Van Unity Twin Bed (sold)
Ray and Susan Huff Posted August 8, 2020 Posted August 8, 2020 On 10/15/2017 at 4:54 PM, KarenLukens said: You don't need the macerator for the gray tank. After filling the black tank and letting it run out the first time, I leave the water flush system running and walk away for a few minutes to let it run. When clear water comes out, I fill it up to 80%+ to 95% at the most on accident... Lol, then pull the handle and let it run clean again. Then refill it again and it should run clean from start to finish, letting you know that it's perfectly clean. We have a macerator on our small motorhome. It is a lot less messy than gravity dump. Did Oliver used to offer the macerator option? They don't now. Or did you add it DIY? I know this is an old post . . . . . maybe someone will comment 😇 Ray and Susan Huff Elite II Twin "Pearl" - Hull#699; delivered December 7, 2020 2013 F350 6.7l diesel Super Duty 4x4 long bed crew cab 1UP-USA Heavy-duty bike rack 2017 Leisure Travel Van Unity Twin Bed (sold)
John E Davies Posted August 8, 2020 Posted August 8, 2020 Macerators are cool, when they work. The first time you have to rebuild a busted impeller you will most likely wonder why you ever thought it was a bright idea. I installed one on a 1988 Searay 250 Sundancer so I could empty the holding tank into the house toilet when the boat was parked in the driveway, through a 3/4” garden hose. It worked absolutely great, but I always was super paranoid that the hose sticking down the toilet would slip out while I was outside in the boat pumping 50 gallons of sewage through it. Having lived with a composting toilet for four seasons, I would never ever have a black tank and a macerator. Yuck. John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
DavidS Posted August 8, 2020 Posted August 8, 2020 17 hours ago, Susan Huff said: Did Oliver used to offer the macerator option? They don't now. Or did you add it DIY? When we were ordering our Ollie in 2016, there was a blog post and a forum thread on macerators on the Oliver Forum. Then, lo and behold, while our trailer was being built, Oliver offered the Thetford Sani-Con as an option. I read more about macerators on the web, and people really liked them. We decided to include it on our Ollie order. I am really happy we got it! It works really well. No problems with getting the slope of the sewer hose just right, without any low spots. And, of course, it is a pump so it drains much more quickly than via gravity. I really like it. I don't know why Oliver doesn't offer it any longer as an option. It would be pretty easy to install DIY. They put the macerator in the rear bumper storage area. The hardest part about putting it in DIY would be connecting it to the 12 V power system. 2 David Stillman, Salt Lake City, Utah 2016 Oliver Elite II Hull 164 | 2017 Audi Q7 tow vehicle. Travel and Photography Blog: http://davidstravels.net
Moderators SeaDawg Posted August 8, 2020 Moderators Posted August 8, 2020 As noted in the forum thread link DavidS provided, we've had two, of different brands. Paul rebuilt the first one, one time. 🤔 When it died again, we bought a different brand. When it died, we went back to gravity dump. When we first got our trailer, the home cleanout/dump was too far away for gravity. Therefore, got the maceration. Since 2015, we have a convenient, planned dump for the trailer at home. We don't need or want the maceration anymore. None of our friends replaced theirs, either. DavidS, I'm glad you like yours. I don't think either of ours was the Thetford. Sherry 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
