Trainman Posted July 30, 2018 Posted July 30, 2018 So will all pickup tailgates open all the way with the trailer hitched on the Elite II. I'm talking about the Ford, Chevy, Ram, Tundra full size trucks. trainman 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold.
Maverick Posted July 30, 2018 Posted July 30, 2018 I have a 2016 Toyota Tundra and there is no problem with opening the tailgate when the truck is attached to the Oliver Elite II. Horace & Dianne Chesapeake, Virginia 2016 Toyota Tundra Crewmax 4x4 Limited 2015 Oliver Legacy Elite II - Hull # 93
Spike Posted July 30, 2018 Posted July 30, 2018 I have a 2016 Toyota Tundra and there is no problem with opening the tailgate when the truck is attached to the Oliver Elite II. Same here with our 2016 Tundra and Elite II. Onward through the Fog! EarthPicks of Cochise County
John E Davies Posted July 30, 2018 Posted July 30, 2018 My 06 Ram 3500 had acres of clearance. My 200 hit hard and I had to install an extended ball mount (+3 inches). Most trucks have the receiver located well below the height of the bed. John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Nana Posted July 30, 2018 Posted July 30, 2018 My 2018 F150 with internal tailgate step does not clear the Oliver Elite II when hitched.
Moderators SeaDawg Posted July 31, 2018 Moderators Posted July 31, 2018 Nana, does the tailgate clear? Without the deployed step, curious Sherry 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Townesw Posted August 2, 2018 Posted August 2, 2018 2017 Chevrolet Silverado 1500 4WD Z71 tailgate clears. Bill Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
KountryKamper Posted August 2, 2018 Posted August 2, 2018 2010 F150, 2016 Tundra and 2018 GMC 2500 all clear without a problem. Tom & Cheryl LE II #305 2018 GMC 2500HD SLT Duramax
ScottyGS Posted August 2, 2018 Posted August 2, 2018 2016 F-150 does not clear. I expect it depends on how you have to adjust the ball hitch. (Anderson WDH) We had to put it pretty far up to get things riding level. I was wondering if installing airbags on the rear suspension would let us low the ball and then level the ride with air. Anyone have any knowledge on that? Thanks, Scotty Gregg & Donna Scott and Missy the Westie - The Flying Sea Turtle - 2016 Hull # 145 2024 Nissan Titan XD - Western NC
rideandfly Posted August 2, 2018 Posted August 2, 2018 Scotty, Installed Firestone airbags on our 2003 2.4L four cylinder 2WD Tacoma for towing a smaller trailer, not Ollie. Connected Ollie to the Tacoma with 30PSI of air in the bags and did not have rear end sag using a 1/2" lift ball mount without WDH. Only move Ollie around the house with the Tacoma, don't take this rig on the road. Bill 2015 LE2 2024 F-350 6.8L
John E Davies Posted August 2, 2018 Posted August 2, 2018 I was wondering if installing airbags on the rear suspension would let us low the ball and then level the ride with air. Anyone have any knowledge on that? An exended “rack” for your Anderson would be much more cost effective. Would an extra 3 inches get it to clear? It did on my 200. It also gives you more maneuvering clearance when backing. https://andersenhitches.com/Products/33734-custom-4-wdez-hd-rack-with-3-extra-shank-length--2-shank.aspx It says there that made to order custom racks are available, this is no longer true, as per a phone call with them. If you need more than 3 inches a good welding shop could modify yours for less than $100. Don’t let your handyman brother in law mess with it, it needs to be very high quality work. Airbags would work but you must inflate them, then rig the correct tension on the chains. If you use the old thread count with the bumper sittiing higher than before, the weight distribution geometry and tension will be off. It is wrong to rig your system, then lift it up afterwards. That slackens the chains. A big plus for the airbags is for levelling when your bed is fully loaded, for when you need a ton of bark for the yard. It does NOT increase your payload at all. You must keep a minimum of 5 psi in the bags to prevent damage to the material, so expect a slightly stiffer ride and a taller bumper height when not towing. http://www.trucktrend.com/how-to/chassis-suspension/1607-air-suspension-basics-for-towing/ I use airbags on my 200, in addition to the Anderson, and really like them. In addition to leveling they firm up the ride enough in back to make the entire rig feel a little more stable and planted on choppy roads. I only use 12 psi towing (max is 30). I use a bike pump to adjust pressure, it takes a couple of minutes to add air, and much less to remove air. An onboard compressor would be very handy, but a $15 pump and $7 20-psi stick air gauge work fine. John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
mountainoliver Posted August 2, 2018 Posted August 2, 2018 My ‘17 Tundra tailgate would hit the Bulldog latch. The truck would sag under load but the trailer was level using the Anderson in it’s highest position. I installed the Firestone air bags to level the truck and was able to lower the hitch one hole so that the trailer is still level. The tailgat now clears by a couple inches. I didn’t have to make much if any change to the Anderson adjustment due to the fact that the relative position between the hitch and trailer remains the same. The air bags require about 15 pounds for a level truck/trailer. I fabricated a manifold so that I can add air to either side or both air bags and have a built in gauge to check the pressure. I also mounted an old Coleman air compressor next to the manifold for adding air, and plug the compressor in the trailer connector as needed. 3 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
mountainoliver Posted August 2, 2018 Posted August 2, 2018 The photo in my previous post rotated 90 deg when placed in the paragraph, sorry! 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
JMSpoff Posted August 3, 2018 Posted August 3, 2018 2017 Ford F250 with tailgate step clears no problem John Marilyn and Gracie 2017 Legacy Elite II Hull 172 TV 2017 F250 Diesel
BackofBeyond Posted August 3, 2018 Posted August 3, 2018 No problem on 2018 GmC 2500 Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible"
Yukon Posted August 17, 2018 Posted August 17, 2018 2017 F 150 lariet will not allow the tailgate to fully lower. sucks
