Chris and Lisa Posted November 26, 2021 Posted November 26, 2021 Well, we did it. My husband and I have committed to an Oliver Trailer! Now for more decisions. Getting to the point, I would love to hear from Oliver owners their experience with compost toilets. While I love the thought of not having to empty tanks at the campground, I am not sure if compost toilets are worth the extra effort. Personally, my main concern is .... and I hate to have to be so blunt, but after speaking with several women friends, we all have concluded that while using the toilet for No 2, it is almost impossible not to mix pee with the poo. There I said it. There is lots of info about compost toilets but nothing basic like this. It is my understanding that if any urine is mixed with the poo, you will have a problem. If this is absolutely true, I know what decision I will be making. Feedback, please. Thank you 2 Chris and Lisa 2022 Oliver Elite II; Hull #1191; TV-2019 Toyota Tundra Other Trailer: Camp-Inn 550 Teardrop
Frank C Posted November 26, 2021 Posted November 26, 2021 No matter which toilet option you choose, you will still have the gray water tank to empty (the tank that collects water from the sinks/shower) and most states/campgrounds prohibit dumping gray water on the ground, so you’re still dealing with the campground sewer connection. And with the composting toilet you still have to dump the small pee tank somewhere. 3
VBistro Posted November 27, 2021 Posted November 27, 2021 I’ve used a composting toilet in our van for 3 seasons and, while it does take some getting used to, it is possible to avoid mixing pee into the solids bucket. It’s all about positioning. You can “tell” when the pee is coming, and you just lean forward a bit so that it hits the diverter part of the toilet. it’s not absolutely 100%, but then it isn’t strictly necessary to prevent 100% of the pee from entering the compost. A dribble or a drop now and then isn’t the end of the world. It’s what I do, and I’ve never had an issue with smell (the effect of mixing too much urine in your compost bucket). 2 MaryBeth Boulder, CO 2022 Elite II #953 TV: 2021 Ford Expedition Max Platinum, Max Tow Package
hobo Posted November 27, 2021 Posted November 27, 2021 I do the cleaning of our composting toilet and have never seen any evidence of urine getting mixed in with the compost. Neither my wife nor I seem to have an aiming issue. Let's for a moment suppose that a little urine does go into the compost; so what? There is no smell from the intended waste that normally goes into the compost pot, so why would I worry about a little urine getting in there too? We love the composting toilet. No black water to have to deal with. When we get home from a trip, I simply run the grey water out on the ground from a ground pipe I installed in our storage barn. No muss, no fuss. Had to borrow a section of hose from a fellow camper one time to reach the drain pipe at our campsite. He lent me a section of some of his blackwater hose. DISGUSTING!! 4 2018 Elite II, Hull #414 (the very last 2018 produced). Trailer name "2 HOBOS" . 2018 F250 4X4 Crew Cab, 6.7L diesel
NCeagle Posted November 27, 2021 Posted November 27, 2021 I have to agree with @hobo. I also do the cleaning and my wife and I both seem to have no problem "aiming". The only learning curve is figuring out where to sit - and that's different for everyone. Once you figure that out it's easy peasy. 😁 3 1 2020 Elite II, Hull 688 --- 2021 Silverado 2500HD, 6.6L Duramax Diesel
Fritz Posted November 27, 2021 Posted November 27, 2021 I agree -- we've been very pleased with the composting toilet. No second thoughts on that choice. Urine in the primary compartment has simply not been a problem. It did take several cycles to properly prepare the coconut coir (i.e., to get the right amount of starting moisture, which varies depending on whether we are in a dry or humid climate). And we don't seem to get the 3-4 weeks of use that some might; 7-10 days has been quite manageable (the crank gets too hard to turn for arthritic hands). But even with that, I empty on my terms (not when the blank tank is suddenly full and won't take the last flush, like in our previous camper). We don't wait in line for the campground dump station, and we don't have to drive around looking for one when boondocking. 2 2021 Oliver LE2 Ram 2500 diesel
xmavrick Posted November 27, 2021 Posted November 27, 2021 Which toilet is best will depend on your camping style! We have the composting toilet and prefer dry camping at national parks and state parks. The liquid tank lasts about 3 to 4 days and disposing used TP in a bag with a little vinegar helps keeps odor down and your solid tank will last about 3 to 4 weeks depending on usage. As others have said keeping the solids and liquids separate is not a problem. For those that prefer full hookups I think the standard toilet is the way to go, unfortunately regardless of which option you choose the dump station is something you can't get away from. 2 Hull 833 2019 F250 6.2L
JohnL Posted November 27, 2021 Posted November 27, 2021 I had similar concerns regarding separation of liquid and solid waste with our Nature's Head. It turned out not to be a problem. One of the greatest advantages is the amount of water conserved by not having to flush. There is also no odor. It's easy to keep clean with a spray bottle of white vinegar. When disposing of the solid waste there is a not unpleasant "earthy" odor. Urine capacity is about 3-4 days. I have a nylon tote bag that is used to transport the urine container to a toilet in order to be somewhat discreet about the process. For my grey tank I have garden hose adapters for both ends, but have never used a dump station because we usually just empty it in the yard at the end of the trip. When we set off on longer trips I'll probably have to deal with dump stations for the grey water. For me, the composting head was worth the extra expense. 2 2021 Elite II #769, 2018 Toyota Tundra
2008RN Posted November 27, 2021 Posted November 27, 2021 We only have 10 days worth of camping, and haven't emptied the compost yet. We just got back from our last trip and I need to do empty the compost now because of the colder temperatures the defecation will not break down. I think we could make it at least 15 days without emptying the compost. One day was diarrhea. Have had no problems with smell or urine in the solids, nor clean up. Again as other have stated, a spray bottle of 25% vinegar/75% water used after urinating keeps all odors away. JohnL, WOW 3-4 days of Urine tank fill. We get about 32-36 hours if using the Oliver for all of our bodily functions. I never dreamed we would fill the urine tank that quickly, I guess we drink a lot of water. We did buy an extra Urine tank for longer trips, I am glad we did. One of us just carry the urine tank to the outhouse/park bathrooms to empty it without a bag. I figure this is camp ground. no big deal. If I have to go into a McDonald's in order to empty, I will put it inside a bag. Both my wife and I are nurses. Dealing with our own bodily waste, is preferable to dealing with someone else's waste products spilled around the dump stations. I really hate walking through waste at the dump station and then transferring that stuff back into the vehicle/Oliver via my shoes. Had that happen a couple of times when we had a Greyhound bus conversion. We dump the gray back at home. Planning on using a pump to fill the Black tank with gray water to expand our ability to stay out longer without using a dump station while on a road trip. I will get to find out this next summer our alternatives for dumping while on a 3.5 week trek. The only negative so far is feeling like you are sitting in a high chair. The compost toilet sets several inches higher than the regular toilet. The Compost also takes up slightly more space in an already tight space in the bathroom. The decision to compost or not is totally a personal decision and what you are comfortable with. No right or wrong answers, only different choices in the way you deal with the waste. 3 Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
dewdev Posted November 28, 2021 Posted November 28, 2021 We really like our Nature Head compost toilet in our Oliver. My wife and I have never had a problem with urine going into the urine tank, athough I do sit down to make sure it goes into the correct spot. Yes the compost toilet does set several inches higher than the regular toilet. I bought a "Squatty Potty folding Bamboo toilet stool" so when we sit down our feet are placed on the stool for better comfort. I espically like not having to deal with empting the black water waste tank and not having to use fresh water in the regular toilet. 2 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension Maine
Patriot Posted November 29, 2021 Posted November 29, 2021 We do not have a composting toilet and never will. The tried and true gray and black tank system in the Oliver we find is so simple to use and maintain. We have no desire to maintain and clean a composting toilet for a multitude of reasons due in part human excrement is 100% hazmat. The name composting toilet seems a bit of a stretch or misleading as it takes 4-6 months on the conservative side for human waste aka HAZMAT loaded with harmful infectious bacteria to break down before it actually becomes a “compost”. This link with videos has pretty interesting owner feed back with regards to “composting toilets”. https://drivinvibin.com/2020/08/17/rv-composting-toilets/ Another link worthy of reading and knowing the laws before disposing of or burying or dumping human waste. There are many restrictions to be aware of. https://www.boondockersbible.com/knowledgebase/is-it-legal-to-dump-composting-toilet-waste-on-the-ground/ 2 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
Moderators SeaDawg Posted November 30, 2021 Moderators Posted November 30, 2021 I seriously doubt that any owners here "dump" solid waste above ground, or shallow bury the solid waste. It's just not the style of our members. At least, I hope not. A "cathole" for weeks of poo plus cois would be undoubtedly deeper than i'd like to dig. Is it "hazmat"? Probably not. Are kids or adult diapers hazmat, if disposed in a dumpster? Partially composted poo plus coir, imo is far better than plastic encased diapers, environmentally. Especially if bags are compostable, imo. In my neighborhood, we have a trash to energy burner, for non recycling refuse. I know that's not everywhere, but it's a good thing here . Check out this post, on how to responsibly empty a composting toilet https://www.livesmallridefree.com/blog/where-to-responsibly-empty-your-composting-toilet 8 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
John E Davies Posted November 30, 2021 Posted November 30, 2021 I can’t top SeaDawg’s reply, but I would like to add that I sure wish dump stations had a completely separate grey water hole, so I did not have to walk on top of all the spilled fecal bacteria when I dispose of only my slightly sudsy gray water. On my last trip my 3” stinky hose failed catastrophically - split in two - right at the trailer connection while dumping gray water. Imagine how much more nasty that would have been if it had that poo/ pee soup in it. With several RVs waiting in line. Taking videos….Think about it….😳 John Davies Spokane WA 2 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Moderators SeaDawg Posted November 30, 2021 Moderators Posted November 30, 2021 1 hour ago, John E Davies said: my last trip my 3” stinky hose failed catastrophically - split in two - right at the trailer connection while dumping gray water. Imagine how much more nasty that would have been if it had that poo/ pee soup in it. With several RVs waiting in line. Taking videos….Think about it….😳 For those of you who are new to rvs, this is not the norm, as I'm sure John would tell you. Just saying, we've never had that happen to us, in all our years of camping. But, it obviously can. We don't have a composting toilet in our trailer (yet), but I think they have definite benefits in the right situation. We did install a composting toilet in our cabin, and it's great. 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Overland Posted November 30, 2021 Posted November 30, 2021 It never occurred to me to dump my poop on the ground, but I’ve been around enough humans to expect that some do, (with my luck, probably the previous occupant of my next campsite). But then those same people would probably dump their black tank in the same place so maybe we should be thankful. As for that first article, all I can say is that if you tell me that you allowed your pee tank to overflow 50 times, my takeaway isn’t that there’s a problem with the toilet. Having said that, yes there are drawbacks and yes we’ve had a few accidents and issues, but we learned from them and so haven’t repeated the former and have eliminated the latter, at least all but one. The first lesson we learned is that you need to empty the tanks more often than advertised. If you fill the poop bucket to much then it will indeed start to smell and will be more difficult and messy to empty. You need to keep the poop to peat (we much prefer the peat over coir) ratio below a certain level. Contrary to the normal advice, we’ve found that keeping the bucket as dry as possible is the key. You want your poop to be desiccated, quickly, and remain that way. If it is, then zero smell, even when emptying. I think the advice to add moisture comes from the idea that you’re supposed to be composting, but you really aren’t. You just want a sanitary, odor free storage bin. Same advice goes for the pee tank. Test its capacity, and you will have regrets. Our rule is that if you can see the pee, it’s time to dump. That’s about ⅔ full, so you’ve got a little time, but that’s when you need to start thinking about it. Trust me, you get over the shyness of taking the pee tank for a walk across the campground. If someone looks at you funny, just tell them that they went camping to get closer to nature and here it is. My one remaining bit of squeamishness is that I do hold my breath when dumping it. It can get ripe. Lesson number two is to carry a bungee or something to secure the trash bag to the toilet when inverting it to empty. Similar issue to the overfilled pee tank - you don’t want the bag to come off mid-dump. Lesson number three is to minimize the TP as much as you can, and to use as small of sections as you can. Unroll a bunch of TP and stick it in the toilet and it will wrap around the agitator and you’ll have to pull it out by hand. Lesson 3.5 is to bring gloves. Lesson 4, forget the vinegar bottles and what not. You’ve got a faucet on a hose there in the bath, so just give the toilet a quick spurt of water to clean it after peeing. If you do get a little smell from the pee trap, then a squirt of 409 or windex works better for us than vinegar. That only leaves the one problem I haven’t solved, which is how to thoroughly clean the toilet after a trip. The typical advice is to just leave it, but since I like to cut all the power to the trailer when it’s in storage, that would mean no exhaust fan. So I dump and try to clean the toilet as best I can. And one thing I can say with confidence about the Nature’s Head is that it was not designed with easy cleaning in mind. I’ve settled on the old clothes, pressure washer, and try not to think about it too much method but I’d sure like either an easier way or an easier toilet to clean. 1 7 1
BackofBeyond Posted November 30, 2021 Posted November 30, 2021 Plenty of great first-hand advice on the Natures Head system. In our three years of experience with the composting system we were glad we chose it over the regular system. However, we were often off grid, not in places with dump facilities. I don't think it takes any more work to maintain than the regular dumping of the black water tank - and driving past the other campers in the dump line is kind of liberating.... However, if we were going to stay in one place for an extended time - say a winter at a full-service site- or regularly stayed in such sites, I would choose the regular black water system. That would be the decision point. Otherwise - composting. Happy trails. RB 1 5 Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible"
Patriot Posted November 30, 2021 Posted November 30, 2021 14 hours ago, SeaDawg said: I seriously doubt that any owners here "dump" solid waste above ground, or shallow bury the solid waste. It's just not the style of our members. At least, I hope not. A "cathole" for weeks of poo plus cois would be undoubtedly deeper than i'd like to dig. Is it "hazmat"? Probably not. Are kids or adult diapers hazmat, if disposed in a dumpster? Partially composted poo plus coir, imo is far better than plastic encased diapers, environmentally. Especially if bags are compostable, imo. In my neighborhood, we have a trash to energy burner, for non recycling refuse. I know that's not everywhere, but it's a good thing here . Check out this post, on how to responsibly empty a composting toilet https://www.livesmallridefree.com/blog/where-to-responsibly-empty-your-composting-toilet Interesting debate… I don’t think its implied anyone dumps solid waste above ground or shallow buries human waste. But when your boondocking for an extended period of time how and where is human waste disposed of? And will it impact a water source such as a trout stream or lake if buried? Here is a link or the “poop scoop” 😄on human waste and I think one would reasonably conclude it is a bio hazard or hazmat just based on a quick open source search. During my tenure in the Air Force during the Gulf War human feces was 100% absolutely considered hazmat or bio hazard and it had to be dealt with as such. Safe to say sanitizing a “composting” toilet surely comes with its challenges, none of which I have any interest in. Maybe someone could post up their procedure or steps they go through when disposing of and then safely sanitizing and throughly cleaning their compost throne? Or how to dispose of human waste when boondocking? In the end-pun intended 😳😂 Ya just have to roll with what works best for your traveling and camping needs. Happy Camping!! https://bioteamaz.com/2019/02/19/is-human-feces-a-biohazard/ 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
John E Davies Posted November 30, 2021 Posted November 30, 2021 45 minutes ago, Patriot said: Here is a link or the “poop scoop” 😄on human waste and I think one would reasonably conclude it is a bio hazard or hazmat just based on a quick open source search. https://bioteamaz.com/2019/02/19/is-human-feces-a-biohazard/ Human excrement from a healthy individual is not a biohazard, regardless of the Internet source quoted. Blood or disease definitely would change that… You must take that advice with a whole lot of skepticism - they are, after all, trying to sell a service, such as cleaning up a feces- and needle-littered homeless camp. I have never boondocked for so long that I couldn’t find a place to dump either pee or the solids. Most places I choose have a pit toilet. You can buy additional pee tanks, or just transfer the pee to a 5 gallon container. You do have to go get food and water, and those sanitation tasks can easily be done then. Your black tank would certainly require a trip into civilization, or else a mobile pump truck. I think you are making a mountain out of a mole hill. The owners that have these toilets generally like them, for many good reasons. For example, what do you do when your black tank is full and all the dump stations are closed for the season? It’s never an issue with a composting toilet, because you can always locate a dumpster and an indoor public toilet. John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Traderroc6531 Posted November 30, 2021 Posted November 30, 2021 Ok, admittedly I have not done trailer camping yet, only car camping in a tent. I do not use the rustic no water toilets(forget the name) bathrooms at those kind of campgrounds. I use a privacy tent with a simple bucket style with odor free bags. I throw the used bag into the campground big dumpster. No water. Or what is wrong with one of those toilets that does use water? Would these not be simpler to use? I understand Oliver has a toilet in the units but I so want to make life simple and gross free. Now I am a male and I have not gone camping with a female since I recently started camping again. So maybe things are different for them.
Patriot Posted November 30, 2021 Posted November 30, 2021 6 hours ago, John E Davies said: Human excrement from a healthy individual is not a biohazard, regardless of the Internet source quoted. Blood or disease definitely would change that… You must take that advice with a whole lot of skepticism - they are, after all, trying to sell a service, such as cleaning up a feces- and needle-littered homeless camp. I have never boondocked for so long that I couldn’t find a place to dump either pee or the solids. Most places I choose have a pit toilet. You can buy additional pee tanks, or just transfer the pee to a 5 gallon container. You do have to go get food and water, and those sanitation tasks can easily be done then. Your black tank would certainly require a trip into civilization, or else a mobile pump truck. I think you are making a mountain out of a mole hill. The owners that have these toilets generally like them, for many good reasons. For example, what do you do when your black tank is full and all the dump stations are closed for the season? It’s never an issue with a composting toilet, because you can always locate a dumpster and an indoor public toilet. John Davies Spokane WA Wrong…no mountain out of a mole hill here. 😉 Just enjoying the freedom to express the truth and my personal views and thoughts based on knowing what hazmat or a bio hazard is. You obviously do not. Don’t be offended, if you enjoy the compost toilet, well party on. No rub here. Did you even read the above links? If human waste was not a biohazard I guess that during my former military career all that was learned was completely false info. I think not completely based on science. Maybe do a bit deeper dive 😁💩 and more research on poop 💩 before you blanket state that human waste is not a bio hazard. Better yet, ask your Local Game Warden or a USDA officer, a Doctor or federal fish and wildlife biologist agent. Don’t take my word for it, these folks are experts. 😉 Cheers! Maybe share how you carefully sanitize your composting toilet? 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
Overland Posted November 30, 2021 Posted November 30, 2021 2 hours ago, Patriot said: Maybe share how you carefully sanitize your composting toilet? As I mentioned above, time is the typical answer. It’s generally accepted that six months of drying will reduce pathogen numbers to a level that poses no health risk. So if you’re a seasonal camper, then you can just leave the toilet alone and know that it will be sanitized by the time you’re ready to camp again. But as I mentioned, that doesn’t work for everyone. My process is to empty the toilet and let it sit for a few weeks, which for an empty toilet should by itself reduce any pathogens considerably. After that, I’ll place a bleach solution in a garden sprayer, take the toilet apart, and spray everything thoroughly. That should kill anything else that remains. The next day I’ll hit it all with a pressure washer. I typically do this while I’m cleaning out the trailer so that I’m not doing a lot of extra work - for example, when I’m sanitizing the water tank I just make an extra gallon of bleach solution to use on the toilet. 3
Overland Posted November 30, 2021 Posted November 30, 2021 If anyone wants to get geeky about these toilets - their design, safety, environmental impact, etc - there’s a very thorough study that you can download here that I think is very much worth reading. You’ll notice that the paper is on urine diverting dry toilets, or UDDTs, which is what these toilets actually are. Despite the name, they are not composting toilets. 2
Moderators SeaDawg Posted November 30, 2021 Moderators Posted November 30, 2021 Patriot, I'd certainly agree that human waste, disposed of improperly, could be a biohazard. That's why wells can't be dug next to septic tanks, raw sewage isn't dumped in the waterways, etc. And, why so many people in developing countries have extreme difficulty obtaining clean drinking water. Just saying a bundle of coir or peat moss and poo isn't "hazmat" when properly disposed of, anymore than soiled disposable diapers. And, that I think the owners here are a) pretty intelligent b) pretty responsible and c) care enough about the environment to dispose of waste responsibly. After all, most of us bought these campers to get out and enjoy nature. We certainly don't want to be the morons wrecking it... 4 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators SeaDawg Posted November 30, 2021 Moderators Posted November 30, 2021 4 hours ago, Overland said: If anyone wants to get geeky about these toilets - their design, safety, environmental impact, etc - there’s a very thorough study that you can download here that I think is very much worth reading. You’ll notice that the paper is on urine diverting dry toilets, or UDDTs, which is what these toilets actually are. Despite the name, they are not composting toilets. Your link leads to documentation by SuSanA, a very worthy, loose knit organization that tries to provide decent,,waterless sanitation in many areas of the world for those who desperately need it. I hope others will actually look at the documents, and read them. I've read a bunch. We're so very spoiled here, and in most of the developed world. Even so, sanitation is difficult in remote areas, and presents difficultiesin urban areas, as well, as populationswells beyond capacity. Vault toilets in many remote parts of US and CA require pumpout. So do many remote dump stations. Volunteers clean out vault toilets in remote areas of the AT, via atvs. It's much trickier than a single nature's head. As my mother in law's proctologost said, everybody poops. We have to learn how to handle it better, and uddt toilets may be the way. we'll see. 3 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
GAP Posted December 1, 2021 Posted December 1, 2021 We bought our E2 last December with a Nature's Head. Love it and have had no problems - mostly because we did our homework, watched the online videos to see what folks did wrong and learned from their mistakes. No smell except similar to potting soil when we actually dump the solid matter. Saves a ton of precious water when boondocking. Super easy to keep the bowl clean. No scrubbing ever - just the occasional wipe with a big "handiwipe". Fantastic for the quick winter time trips we frequently take where we don't wake up the water system. Not having to handle a black water hose is a a huge plus. If we are going to a campground and going to dump our grey water at the same time that we need to change the solids tank, it's easy to dump the solids in the hose hole first and wash the tiny bit of spilled composting material (if any) into the hole with the grey water we are disposing. The solid matter allows for weeks of continuous use and is easy to dispose of. We put ours in our compost box which gets naturally hot enough to break down for use in our perennial garden beds. Dumping in an open compost pile would do the same. If we turn the macerator a dozen times, it breaks down the solids really well and mixes thoroughly with the coir medium. Truly makes for an inoffensive final product. Anyone who has a dog is dealing with much much grosser material in a much more up close and personal way. From what Ive found on line, it is fine to simply put the stuff in a bag and dump legally in the garbage. We've only done this a couple of times but use a recycled bag. The liquid can be safely poured around the base of a tree or shrubs and the nitrogen feeds their roots. We've been doing that for a year and the plants seem to love it. I've never experienced a strong smell when dumping the pee container even indoors into a toilet. We don't allow liquid to stay in the container for more then three days, so that may help. After a trip, we keep the computer fan running for about a week and then unplug it. This allows enough time for the medium to do it's thing enough so there is no smell. As mentioned above, it's best to keep the coir (we prefer the coconut coir over peat moss for environmental and price reasons) on the dry side so, if it's super humid out, we'll run a dehumidifier in the trailer for that week which dries out the trailer in general and material in the solids tanks. No problem even when stored for extended periods. Saves the hassle and intimate contact of having to clean out the bin. Per instructions from manufacturer, we never clean out the solids tank. The minnimal amount of material (a couple of table spoons worth) when we dump it out is the medium to start the next batch. Kinda like sourdough bread. As to toilet paper, we don't put any in the toilet. I KNOW, I KNOW: Sounds gross but, in reality, not so much. We keep a little, lidded, foot operated garbage can near the toilet. Inside is a plastic container that 40oz of mixed nuts came in. No lid. We line that with the plastic bags you get from the deli for meats and cheeses. A rubber band hold the bag in place. Toilet paper goes in there, as does general bathroom trash and it gets tossed every 3 days or so. Even in hot weather, no smell. Using this system prevents the macerator in the toilet from getting clogged. Nothing gross to handle, look at or smell. 1 1 SOLD: 2021 Elite 2, Twin Bed, Lithium & Solar, 3000W Inverter SOLD: 2022 Ford F150, 3.5L V6 EcoBoost, 4x4 Supercab, Trailer Tow Package
