Rivernerd Posted January 21, 2023 Share Posted January 21, 2023 Those who do their own maintenance may wish to simplify periodic greasing of the suspension by installing zerk caps. The caps keep road grime from coating the grease zerks, so you don't have to wipe them off each time you grease them. The zerk caps on my tractor have saved a bunch of time, so I installed them on my Elite II suspension as well. You must remove the wheels to install the caps, so they are most easily installed when already doing regular maintenance. Zerk caps are available for $11 from Amazon, or from the manufacturer, LockN Lube. Amazon link below: https://www.amazon.com/dp/B0779K66DW/ref=dp_iou_view_item?ie=UTF8&th=1 3 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package Link to comment Share on other sites More sharing options...
taylor.coyote Posted January 21, 2023 Share Posted January 21, 2023 I love the nice and tidy look. It's nice to know about the option. For me, functionally I don't feel enough is gained to invested the time. I have several other project such as mud flaps and waxing the beast yet to get done. Maybe it's something to do next time I rotate the tires or grease the suspension. 2016 Legacy Elite II, Twin Beds, Hull #124 Tow Vehicle: 2019 Ford F250 4x4 / Short Bed / Crew Cab / 6.7 Diesel Fieldbrook, Ca Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted January 21, 2023 Moderators Share Posted January 21, 2023 I’ve been using Zerk caps for quite some time. Cheap and effective. I didn’t have to remove wheels to put them on or to lube. Mike 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
Frank C Posted January 21, 2023 Share Posted January 21, 2023 Definitely a simple worthwhile addition to keep the fittings clean to prevent dirt contamination. I added the caps shortly after our Ollie purchase, and I also changed to angled Zerk fittings to make re-greasing easier. 2 Link to comment Share on other sites More sharing options...
Steph and Dud B Posted January 21, 2023 Share Posted January 21, 2023 I just received my set of covers last week. Will put on before before our first trip of 2023. Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999: Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted January 21, 2023 Moderators Share Posted January 21, 2023 I put mine on almost seven years ago. I really didn't think that given the "cheapness" of the plastic they would last very long - so - I bought a full set of extras. Fortunately, I've not had to use a single one of those extras - yet. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
Patriot Posted January 21, 2023 Share Posted January 21, 2023 Like @Frank C we also changed our zerk fittings. Adding the zerk caps seems to make greasing a much easier task to ✅. Thanks @topgun2 for the suggestion at the time on the caps. -Patriot 🇺🇸 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor North Carolina 🇺🇸 Link to comment Share on other sites More sharing options...
Rivernerd Posted January 21, 2023 Author Share Posted January 21, 2023 2 hours ago, Mike and Carol said: I didn’t have to remove wheels to put them on or to lube. You must have much better manual dexterity and body flexibility than I do! I can't get a grease gun, even with a Lock N Lube fitting on the end of a flexible hose, on to the two zerks inside the central bracket that holds the EZ flex assembly, without removing my wheels. 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted January 21, 2023 Moderators Share Posted January 21, 2023 1 hour ago, Rivernerd said: You must have much better manual dexterity and body flexibility than I do! I can't get a grease gun, even with a Lock N Lube fitting on the end of a flexible hose, on to the two zerks inside the central bracket that holds the EZ flex assembly, without removing my wheels. It’s not as easy as it used to be, but I can still do it! 4 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
Geronimo John Posted January 21, 2023 Share Posted January 21, 2023 1 hour ago, Mike and Carol said: It’s not as easy as it used to be, but I can still do it! It's tough getting older. My replacement knees and thinner butt makes suspension maintenance a lot less fun than it used to be. But having a nice bucket and one of these really helps it to be a lot less of a PITA! Seriously. 🙂 I store my boat throw cushion as a pad to my Honda EU2200. The generator is lashed down in the curbside rear corner of the truck bed. The cushion sets vertically between the side of the generator and the side of the truck bed. Best part is I can remember where I put it! GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR). Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted January 21, 2023 Moderators Share Posted January 21, 2023 52 minutes ago, Geronimo John said: But having a nice bucket and one of these really helps it to be a lot less of a PITA! Seriously. 🙂 I store my boat throw cushion as a pad to my Honda EU2200. The generator is lashed down in the curbside rear corner of the truck bed. The cushion sets vertically between the side of the generator and the side of the truck bed. Best part is I can remember where I put it! Great use for an old boat cushion. It doesn't have to float on pavement,or atop a bucket, just give our old bones a bit of cushion. We also have knee pads, and some old carpet scraps, for work at home. Everything helps! 3 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Moderators mossemi Posted January 21, 2023 Moderators Share Posted January 21, 2023 4 hours ago, Rivernerd said: You must have much better manual dexterity and body flexibility than I do! I can't get a grease gun, even with a Lock N Lube fitting on the end of a flexible hose, on to the two zerks inside the central bracket that holds the EZ flex assembly, without removing my wheels. All of my zerks are oriented to the inside of the frame. So I use a creeper and the only trouble spot for me is getting my belly under the axles.🤔 Mossey 1 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
C&MCurrie Posted January 21, 2023 Share Posted January 21, 2023 Seems like a worthwhile addition. What size angled Zerk fitting do I need and can the caps be purchased in smaller quantities? Looks like Amazon has only a 50 count of the yellow ones. I have the Elite I and as far as I can tell, I only need 6 caps. Thanks 2021 Legacy Elite I , Hull #765 2021 Chevrolet Silverado 3.0 Diesel Navarre, Fl Link to comment Share on other sites More sharing options...
Frank C Posted January 22, 2023 Share Posted January 22, 2023 14 hours ago, C&MCurrie said: Seems like a worthwhile addition. What size angled Zerk fitting do I need Our Oliver had 1/4-28 thread size Zerk grease fittings but this may not be the same for all Olivers. I think some owners have found that their Dexter suspension assemblies have a 6mm-1 metric size Zerk. Best to remove one of your existing Zerk fittings to confirm the thread size. 1 3 Link to comment Share on other sites More sharing options...
MAX Burner Posted April 13, 2023 Share Posted April 13, 2023 Anyone tried this grease gun? Looks promising.... 3 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
John E Davies Posted April 13, 2023 Share Posted April 13, 2023 1 hour ago, MAX Burner said: Anyone tried this grease gun? Looks promising.... Yep, it is worth twice that, you can buy the fitting direct too, ships free. https://locknlube.com/products/locknlube-grease-coupler?variant=32586284204116 I have used one for years, I have been reluctant to recommend an attachment that costs more than most grease guns. But OTH I also use an expensive pneumatic gun. Just buy it and enjoy it. John Davies Spokane WA 5 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
MAX Burner Posted April 13, 2023 Share Posted April 13, 2023 1 hour ago, John E Davies said: Yep, it is worth twice that, you can buy the fitting direct too, ships free. https://locknlube.com/products/locknlube-grease-coupler?variant=32586284204116 I have used one for years, I have been reluctant to recommend an attachment that costs more than most grease guns. But OTH I also use an expensive pneumatic gun. Just buy it and enjoy it. John Davies Spokane WA Thanks for the vector, John. Getting one today.... 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
snakeriveridaho Posted April 13, 2023 Share Posted April 13, 2023 2 hours ago, MAX Burner said: Anyone tried this grease gun? We have one also. Works great! Definitely worth the money. Kirk 1 2 Kirk and Carrie Peterson Twin Falls, Idaho 2018 Ram 3500, with overland conversion: Rooftop tent, water, stove, Battle Born batteries, lockers, onboard air, raised air intake, Warn winch. 2023 Elite 2, twin beds, delivered December 5, 2022 Truma package, lithium platinum package. Hull #1305 Link to comment Share on other sites More sharing options...
