We received the replacement rubber from Pelland quickly and they sent an extra foot+ in length. Installed it last week, starting from the bottom, pushing hard to compress as much stock as possible. I used an automotive hose cutter tool. Cut it 1/4" longer at end and pushed in the extra length, so that when it shrinks, we should be good. The black does look so much better, as it is recessed, and the white frame is still prominent. Thanks all for your help! 🙂
  • Like 8
  • 4 weeks later...
Just an FYI. We purchased hull #49 about a year ago and have constant issues with water in our dinette window. I did everything possible that the forum suggested to no avail. After more investigation I took a little pick and ran on the inside of the window tracks and the pick kept grabbing on something. Turns out the drains were stamped  but not completely out. After some luck I was able to get all 4 drains clear. Not sure if this was an issue with earlier models or if we just got lucky! 😂 We have not had an issue since, knock on wood. Oops that's fiberglass.
  • Like 9
Glad you found the source of the problem!
Interesting that the previous owner must have lived with that issue since Hull 49 was new.
  • Wow 2
  • Sad 1
Unfortunately we are finding quite a few issues the previous owner lived with. No worries, "BUCK" will be good as new and ready for more adventures!
  • Love 2
I'm really glad that #49 found a great owner.
"Buck" is in good hands.
Here is the information that I have for for the windows:  For the 3 large windows, Pelland Enterprises in Arnold, Ca. phone number: 209-795-9330 - I bought 17'. The Item code is H109-376-19 and the description says 1/2" Glass Vinyl Seal, Black sold by the foot at $5.17 a foot for a total of $87.89.
For the escape window: I bought from Steele Rubber Products. Steelerubber.com The PN number is 70-3825-255 I do not remember how much I paid for it, but I think I ordered 10' .  I also ordered this in black.
I hope this helps someone.
  • Thanks 5
For hull #49, current product codes may not work.
I'd suggest a call, or email,  to service
What year is your Oliver @Nan?
**Sold😞**
Her trailer is a 2017.
I'm missing two black weep hole plugs, but I had completely forgot about them as I blocked them with white Gorilla duct tape, strong stuff. They blend in too well to remind me.  I just now looked at them, after nearly 2.5 years outside, and they're still perfect. Maybe I should pull the other two plugs to match. I'm getting a bit of water inside with heavy rains. Or, like my walk-in door, maybe the frames are leaking. Since I pulled off the door fame off the hull and resealed, it's been perfect, no more leaks.  Super easy job. I have a post somewhere in the forums. No vid yet, not sure how to organize content.
Chris
o-o  2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110"
o-o  2024 Ford F-250 Lariat, 7.3L Godzilla gasser
o-o  Augusta, Georgia
  • 1 month later...
On 5/11/2023 at 4:10 PM, Rivernerd said:
https://www.pellandent.com/RV-Window-Seal
Pull your flexible seal, then match the profile with the one on the Pelland Enterprises web page to ensure you get the same one.
Just put in the order.  Cost about $100 with shipping to Connecticut.  Ordered in black for longevity.  Any of these sort of plastic or vinyl bits that are on the outside of a vehicle can be treated with 303 which is an aerospace UV protector similar but better than armor-all.  I'm thinking the black will never show the fungus stains.  Thanks much for pointing me in the right direction.
Same here - the black should last longer.  It looks better too, iMO...
  • (SOLD) 2022 TUNDRA
  • 1 year later...
On 5/11/2023 at 5:37 PM, johnwen said:
My rear window is as described by Chris and was pretty straight forward as he shows in the video.  My side windows are not.  The slotted rubber piece on each side have a felt rubbing strip on either side of the channel and prevent the rubber piece from being extracted, unless you use quite a bit of force.  The felt strips are an H shape and fit over the edge of the rubber strip.  I'm not sure if the pictures are of any help.  I quit as RoadKingsofGa did and am unable to fit the H shape of the felt strip back over it edges.  So I quit at that point and finished cleaning as best I could.  I don't think it matters much if I don't get the felt strip back perfectly as the window still slides smoothly and none of the weep holes are blocked.  I'll search out the window experts at the rally.
BTW, there are 2 of those felt strips, 1either side of the rubber strip.  I did not attempt removal of the outboard strip.
John, have you figured out how to remove/install the side window window black tracks with the felt rubbing strips? My windows are the same as yours, I cleaned the rear window but like you and @RoadKingsofGA I couldn't remove the side window black tracks with the felt strips!
**Sold😞**
10 years here with the black.  No issues.
5 years with black window trim and no issues here either. We also pull window gaskets after each trip and used soap and water and compressed air and have never had any issues with water intrusion. It’s a cleaning and detailing  ✅ list to do! 😊
Edited by Patriot
All I do is when we return from camping trips, I pressure wash all the dirt off our trailer (and there’s so much dirt out here)! I hit the windows straight on with 3000 PSI water pressure and you see the dirty water come out of the drain holes first, followed by clean water. If I do not see this out of EVERY drain hole I would address this afterwards. As I am blasting the windows, Chris is inside with a towel to collect any sprayed water to the interior and there is generally little to none.
And our Ollie can get very dirty!
Edited by jd1923
  • Love 2
  • Wow 5
I can just see those guys at CGI having their way with #113! 😇
  • Sad 1
John, now that's camping to the full! 😄
**Sold😞**
5 hours ago, topgun2 said:
I can just see those guys at CGI having their way with #113! 😇 Bill
Chris and I are OK with our "Dirty Ollie." After a wash it goes from dirty to pasty, but not paying the big bucks for a shine.
That picture is from our very first Oliver camping trip, July 2023 to Kendricks Peak AZ, after 26 miles of dirt road. Ever since that trip, I've brought our Dewalt leaf blower which gets a lot of it off if blown as soon as we get to our campsite.
Just got back from 12 days to NM and back. We hit snow then fog and rain and it's not quite as dirty this time but it is sure stuck on now. Bought gas for the pressure washer yesterday and today it's a beautiful sunny 72F day and I should be getting wet and dirty after lunch today~!
That just looks awesome and assaults my OCD at the same time.  Especially the finger swirls on the back windows.
Please note
If anyone is looking for the posts concerning the possible new Oliver windows for 2026, that portion of this thread has been moved to a new thread titled:
New Windows for 2026?
Here's an update on the LE2 sliding vent window tracks.
I believe the correct Hehr part numbers are H109-602 (for the curved sections) and H109-599 for the straight pieces.  These can be ordered from Pelland.
There is an update for these vent tracks.  The tracks having the wooly fuzz on each side vertical section were replaced by flexible track made of TPV.  I do not have part number or supplier information for that, at least not at this time.  The TPV track is flexible enough that a separate radius-ed part is not required.
The sliding portions of the 5600 / 7600 windows are not designed to be removed (the only Hehr window sold up to this point which is designed this way), so replacing the vent tracks can be tricky.
I understand the vent tracks were made by an (unidentified) outside supplier and not by Hehr.   I further understand that the window model number is 5600.  Hehr 7600 windows are identical to the 5600 with the exception of the outer trim, meaning 5600 and 7600 series parts should work on Ollies with 5600 series windows.   Neither the 5600 series nor the 7600 series are shown among Lippert's current product offerings.
The story is a lot longer than this, but the important information is above.
Tim
Edited by TimD
2021 LE2, hull 701
On 4/30/2023 at 6:15 PM, Wayfinder said:
Not sure what other channel to place this.  Hope it helps our new-comers.
Chris — you posted an excellent video and it’s very much appreciated.
My recently cleaned window tracks managed to get so full of “muck” (the perfect word) that I had water intrusion last night. A first for me!
UPDATE:  My little black flexible pieces (with the oval holes, that sit in the window track) are not nearly as flexible as what I see in the video. And the vertical sides seem to be separate, or have split from the horizontal section (I only pulled up about 1/2 inch).
This made me wonder if my track liners were different from the video. After speaking with OTT Service Team, I decided not to remove those sections. At least not now, while I am on the road in remote areas. I’m going to finish cleaning the weep holes as much as possible, and when things are dry, use compressed air to blow the dust out.
All photos are taken from inside looking out… IMG_0866.thumb.jpeg.97bdf7a6a479193a9f2376198f672fbb.jpeg
Thanks to the service team for their support today.
Edited by Boudicca908
Update
my Oliver has camped here
Chris:
Thanks for starting this great post, and video!
One suggestion that I do may help during wanding efforts:  Raise or lower your front jack to assist the water flow to the next weep.  Gravity is a wonderful thing... occasionally anyway. For this purpose it is.  Certainly made my window weep process faster.  Also having some really long pipe cleaners to push and scrub in places you can't get to.
PS:  Recommend not going too steep as water will pass by one drain hole and could over flow inside at the low end.  Figured that one out all by my self!  Sadly!
Edited by Geronimo John
GJ, I was also recently thinking the same thing while washing on my last trip.
I also now have the newer windows (replaced last year, 2024) which do not have that flexible & removable rubber track around the windows.
I do think though that the newer windows drain a bit easier.  I think I need to update the video for the newer windows.  I'm thinking to recommend to use a mini-vacuum attachment to suck out any dry debris.  That might make it easier to clean out when it does get wet.
I'll do more videos when I'm retired, since I'm on the computer ALL DAY LONG for work, for 35 years.  I'm done with them.  LOL
Chris
