rideadeuce Posted March 13, 2024 Posted March 13, 2024 (edited) Coming back from a beautiful trip to West Key, FL. pulled into camp outside of Tampa and found this... Hopefully we can limp into town and get it replaced with a 2-5/16 in coupler rated for 12,500lbs. Saw a members post a while back and almost upgraded then but decided to wait. Luckily, the family is okay. Best to everyone, safe travels. Mike Edited March 14, 2024 by rideadeuce 4 11 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
CRM Posted March 13, 2024 Posted March 13, 2024 6 minutes ago, rideadeuce said: Hopefully we can limp into town and get it replaced with a 2-5/16 in coupler rated for 12,500lbs. I wouldn't move another inch If I were you. Pick one up and install it right there. 1 6 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
DavePhelps Posted March 14, 2024 Posted March 14, 2024 Whoa! I would not try and drive that anywhere. At the least, get a mobile welder to come out to weld it back together so you can safely and carefully get to a shop where a new hitch can be installed. Unless you are able to install the new hitch where you are. It looks like there's rust where the hitch broke apart? Could have been cracked for a while. Never thought this could happen to a Bulldog Hitch. Thank heavens you weren't cruising down the freeway when that happened, that would have been pretty ugly. Glad you are all safe and sound. 🙏 Dave 1 5 2015 Oliver Elite 1, Hull 107 2025 GMC Sierra HD 2500 AT4, 6.6 L8T (gas)
jd1923 Posted March 14, 2024 Posted March 14, 2024 OMG, I've seen a lot of automotive failures, but NEVER one of this kind! The Bulldog ("think Bulldog" means strength) should be an extremely strong hardened steel connection. I've towed 30 some trailers in my lifetime and NEVER would I contemplate this kind if occurrence! 🤕 Trailer hitches have issues, but NEVER of this kind! I'm a Mechanical Engineer with over 45 years of automotive restoration experience. This of course, is NOT, not right. This pisses me off! It appears that somehow you came out of this OK... Thank God, and God bless you and yours! You purchased a relatively new OTT, and tG your OTT did not break away and end up upside down in a ditch! You have a strong liability claims again OTT, Bulldog, and perhaps other parties. Not only should you not move, for a replacement, for a welder, or absolutley anything else. You have already good pics here but take another 100 pics at every possible angle. If your Oliver is insured, file a claim asap. And if so, don't touch ANYTHING. From our family to yours, God Bless you and yours! You must have good Charma, because without it... you would not be writing about this but instead living the reality of this disaster. 1 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted March 14, 2024 Posted March 14, 2024 (edited) Mike, Wow. First and foremost glad you and your family are ok. Seeing the failure of your BD hitch is scary and deeply concerning to say the least. Oliver Service and the manufacturer of the Bulldog hitch should be made aware of this failure as soon as possible. This failure could have resulted in a really bad accident in so many ways. As others have mentioned take lots of photos, as every picture tells a story. As time allows, please keep us posted on any further details if and when you learn the possible cause of this failure. Again, most importantly, so glad you and your family are safe. Patriot🇺🇸 Edited March 14, 2024 by Patriot 1 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Minnesota Oli Posted March 14, 2024 Posted March 14, 2024 Looking at the second picture the tear in the side of the hitch shows a rusty fracture except for the last half inch. This tells me it was disaster in the making for awhile and it's another area to pay attention to in our walk around inspection. Will be interesting to hear the official analysis of the cause of the failure. I believe you have guardian angels looking out for you and your family for it could have been a much worse outcome then just a breakdown in the middle of a camping trip. 3 5
Steph and Dud B Posted March 14, 2024 Posted March 14, 2024 (edited) Glad you are safe. That could have been catastrophic. Many, many questions here. I agree, the rust seems to indicate there has been damage in that area for some time. Any unusual history to that hitch? Involved in any previous accident/impact? Used in severe conditions, off-road, etc.? Exposed to salt water/road deicers? Modified in any way? Also agree you should not move or alter the hitch in any way until you've contacted your insurance company, Oliver, Bulldog, and possibly the NHTSA: https://www.nhtsa.gov/report-a-safety-problem#index Good luck! Edited March 14, 2024 by Steph and Dud B Typo 1 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
rideadeuce Posted March 14, 2024 Author Posted March 14, 2024 (edited) "On the road again!". Ramblers, I do feel fortunate that nothing serious happened to my family or anyone else on the road. When saner minds prevailed and after a few hours of sleep. I got out the tools and took off the broken coupler and headed to a Bulldog dealer (A and A Hitch) in Bradenton, FL. Mechanic/welder since 1985, said he had never seen one do that. Upgraded to the 2- 5/16 in coupler. 12,500 lb pull capacity and 1875 lb tongue load. A and A Hitch drilled the holes for me. Weight distribution device was never used (not needed?) pulls like and sits like an arrow, tongue weight always within spec (Yamaha 2200 gen since day 1 in basket), maybe 20K on frame, 2018 Tundra pulled without incident since day 1, mostly beach, MI and CO trips. Special thanks to @Mossemi and others for feedback and willingness to help. It really made me feel better and helped me make a better decision on how to rectify. Also, when looking at the broken coupler you can see where there was a seminal break that is rusted and then the subsequent clean fracture. The only thing holding it together was the top plate that was bent up. Check proximal to the neck for cracks. This happed without warning and I did not see the cracks from the outside. Side note: I like the gray paint. It may help someone see cracks vs. the standard black. Best, Mike Edited March 14, 2024 by rideadeuce 1 8 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
rideadeuce Posted March 14, 2024 Author Posted March 14, 2024 (edited) duplicate Edited March 14, 2024 by rideadeuce - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Rivernerd Posted March 14, 2024 Posted March 14, 2024 I, too, am stunned to see your photos. Kudos to you for thinking to unbolt the original coupler and locate a replacement. Your report makes me glad we upgraded to the 2-5/16" coupler when we bought Hull #1291! 1 4 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2026 Ford F350 Crew Cab with 7.3L gas engine
Steph and Dud B Posted March 14, 2024 Posted March 14, 2024 I think I would still file a report with the NHTSA. This is probably just a one-off, but on the odd chance this has happened to other Bulldog hitches, maybe NHTSA will see a pattern and initiate a recall. There was a reasonable chance that failure could have led to injury. 4 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
ChrisMI Posted March 14, 2024 Posted March 14, 2024 19 minutes ago, rideadeuce said: Weight distribution device was never used (not needed?) pulls like and sits like an arrow, tongue weight always within spec (Yamaha 2200 gen since day 1 in basket), maybe 20K on frame, 2018 Tundra pulled without incident since day 1, mostly beach, MI and CO trips. It had nothing to do with your failure but I’d seriously consider adding a WD hitch to your trailer. You have a lot of tongue weight with your front storage box loaded, well above what’s recommended for a 1/2 ton. 1 7
rich.dev Posted March 14, 2024 Posted March 14, 2024 @rideadeuce Very glad you and your family are ok! If you haven't already, I would strongly suggest you take your fully loaded setup (Tv and trailer) through a CAT scale. I will be surprised if you're not very close to or exceeding the payload/cargo capacity of your 1/2 truck, and possibly your rear gross axle weight rating (GAWR). That will also give you an indication of your tongue weight. I have a very nice excel spread sheet (if you don't have one) that will show you what your loads are in relation to your axles, cargo capacity etc. Let me know if you want me to PM it to you. Anyway, just a suggestion, but again, very glad you and your family are ok! 🙏 2 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Geronimo John Posted March 14, 2024 Posted March 14, 2024 16 hours ago, DavePhelps said: It looks like there's rust where the hitch broke apart? 1 hour ago, Steph and Dud B said: I think I would still file a report with the NHTSA. This is probably just a one-off, but on the odd chance this has happened to other Bulldog hitches, maybe NHTSA will see a pattern and initiate a recall. There was a reasonable chance that failure could have led to injury. Is there any evidence of galvanic corrosion from the SS bolts, Bulldog and aluminum frame? I agree fully on submitting a report to the NHTSA. Your post has 85% of the info they will need. Process on line is easy. GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators mossemi Posted March 14, 2024 Moderators Posted March 14, 2024 @rideadeuce Thank you for the follow up and closure on your Bulldog coupler failure. Safe travels home! Mossey 3 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
DavePhelps Posted March 14, 2024 Posted March 14, 2024 Please post any future findings about this break. Has anyone tried bending the hitch back together to see if the break closes cleanly? I am seeing some things in the pics that are a little disturbing. Like in the above pics where there is rust in the center of the fracture and clean bright metal at the top and bottom. Maybe someone else can explain how this can happen. The rust edges also appear to be radiused. I'm no metallurgist so can only comment to what I am seeing. Hopefully, there will be a good explanation in the future on how this happened. Again, very glad you are all safe and back on the road with the new and larger Bulldog. Dave 2 2015 Oliver Elite 1, Hull 107 2025 GMC Sierra HD 2500 AT4, 6.6 L8T (gas)
mountainoliver Posted March 15, 2024 Posted March 15, 2024 It’s difficult to tell from the pictures but the hitch doesn’t look like it has a gusset in the broken area. My 2 inch Bulldog hitch has a 3/16 thick gusset welded at an angle just behind the coupler and just in front of the tongue. The gusset is welded from side to side. If the broken hitch doesn’t have the gusset…that could make a difference. Either the hitch didn’t have the gusset and should have or it was older and maybe never had one in the design, which would mean that the design was changed at some point. Maybe because of weakness and some failures. If the broken hitch doesn’t have the gusset I’d start asking a lot of questions to the Bulldog folks to figure out why. Not necessarily pointing fingers but maybe finding out that you got an old design. If that’s the case, everyone should check that the gusset is in place. If not then replace the hitch with the newer upgraded version? 1 4 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
Moderators mossemi Posted March 15, 2024 Moderators Posted March 15, 2024 11 hours ago, mountainoliver said: My 2 inch Bulldog hitch has a 3/16 thick gusset welded at an angle just behind the coupler and just in front of the tongue. The gusset is welded from side to side. If the broken hitch doesn’t have the gusset…that could make a difference. Would you post a picture of the gusset on your coupler. We should all be on the same page concerning this equipment failure. Mossey 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
MAX Burner Posted March 15, 2024 Posted March 15, 2024 Our 2017 LEII #226 2" Bulldog has the gusset. It's interesting that Mike's 2018 OTT was equipped with a non-gusseted BD (?). We routinely check the torque values of the BD's 2 through-bolts and use the hitch scale to ensure our tongue weight is within limits. MAX tongue wt measured has been just north of 485lbs, FYI. This failure may have been a combination of several factors - older design w/o the welded gusset, metallurgical issues starting from manufacturing, excessive tongue wt., non-use of a weight distributing hitch connection between the Tundra and OTT, etc. Mike, we're looking forward to any additional information you may learn about the BD failure - there's likely to be some of us thinking about going with the 2-5/16" option after reading through this thread. Thanks for posting! Bottom line is everyone's safe, many owner's have yet again learned some important attributes of our respective rigs, and @rideadeuce has a clean upgraded 2-5/16" BD! Cheers, ALL - Stay Safe out there! 5 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Steph and Dud B Posted March 15, 2024 Posted March 15, 2024 @mountainoliver, is this the gusset you're referring to? And, should I be concerned about that weld on the left side of this photo? 2 2 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
mountainoliver Posted March 15, 2024 Posted March 15, 2024 (edited) We’re out of town right now so can’t get a photo of mine but, yes that is the gusset that I was referring to. The 2 5/16 hitch however doesn’t have a gusset but instead has a tube that extends into the formed steel section and is heavily welded around. Edited March 15, 2024 by mountainoliver Add content 2 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
rideadeuce Posted March 15, 2024 Author Posted March 15, 2024 (edited) @mountainoliver @Steph and Dud B That is very interesting. Mine definitely did not have that gusseted welded section where the break occurred. I wonder when they made the change and why they didn't put out a recall if that is the case. Or mine was just defective from the factory. More pics of others pre-2018 might be interesting. @Geronimo John I didn't see any signs of galvanic corrosion. Bolts, aluminum and steel around bolt sleeves looked good to me. @MAX Burner I am just curious. How can the max tongue wt max be 485 lbs when the TT dry is 4900 lbs. A basic rule of thumb is tongue wt max 10% of total wt. Through various online sources, I have always considered the V-8 Tundra's to be in the 600-700 lb range. I would appreciate any input on this. I mean if you can overload your max tongue wt with a 55lb generator in the front basket I would be shocked again. And correct me if I am wrong, the Tundra pulls the Ollie incredibly well without a sway bar or WDS. SO why not just OEM the 2-5/16th coupler instead of the marginal 2 in. Lots of variables here to think about for me personally and fellow owners as well. BTW, we are back home safe and sound in good ol' Tennessee! Edited March 15, 2024 by rideadeuce 2 3 1 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Geronimo John Posted March 15, 2024 Posted March 15, 2024 5 hours ago, MAX Burner said: the BD failure - there's likely to be some of us thinking about going with the 2-5/16" option after reading through this thread. As you know, I had OTT build our Ollie with the 2 5/16 BD. Glad I did. But if I had not, I would not toss a perfectly good 2" BD until it wore out. The corrosion failure for this 2017 BB had to have occurred over a long period of time. Could have been originated from a single salt exposure (Sea or salted roads) environment. Once the corrosion starts, you would not need such an environment for it to continue to propagate down the weld line. If ignored all the way to failure. Either way, CAREFULLY inspecting our BD's (As well as all other rustable running gear) every couple of years and mechanically eliminating any rust and recoating should be added to our long term maintenance inspections. Especially if our rigs are stored in a salt air environment or are ever used on salted roads. GJ 5 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators mossemi Posted March 15, 2024 Moderators Posted March 15, 2024 18 hours ago, mountainoliver said: My 2 inch Bulldog hitch has a 3/16 thick gusset welded at an angle just behind the coupler and just in front of the tongue. I also have the gusset on my 2" Bulldog coupler, which is OEM installed on a 2017 LE2 hull #193. Mossey 1 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
CRM Posted March 15, 2024 Posted March 15, 2024 1 hour ago, rideadeuce said: That is very interesting. Mine definitely did not have that gusseted welded section where the break occurred. I wonder when they made the change and why they didn't put out a recall if that is the case. Or mine was just defective from the factory. More pics of others pre-2018 might be interesting. Our 2010 has the gusset and I can take a pic for you, if you would like. I'm guessing yours was a defect right from the factory. 1 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
