I added a valve in the bumper so I could keep my drain hoses connected and not have anything leak into the bumper area when done emptying. Well, I forgot I did that. And did not open the valve in the bumper. And when I went to empty my black tank first it went from 50% to 10% full. Then I went to empty my gray tank and noticed it wasn’t emptying. That’s when I realized my mistake in not opening the valve in the bumper.  So I shut both valves, opened the valve in the bumper, then opened the black drain valve. The black tank went down to 5%. Then I shut the black tank valve and opened the gray tank valve and it worked as it should and went down to about 40%. What I am afraid of now is that my black water backed up into my gray water tank when I had the valve in the bumper closed. Hopefully I explained this well enough. Does anybody have any thoughts?
Either way - not the end of the world as we know it.
I'd flush the heck out of both tanks and call it a day.
    I agree with Bill... it's not a real big deal.  They are both going to the drain system and can't impact your fresh water in any way.  That said we are kind of fussy about keeping both the gray and black as clean as possible.   I would recommend that whenever you find your self in a campground with full service at the site- as a regular part of preventative maintenance, to occasionally give your black tank a good hard flushing (with the black tank flush port and a dedicated hose) and fill your gray tank up a time or two and flush it also.    Then once clean and before departing to the next destination... put about 5 gallons of water back in the black tank... and maybe 10 gallons of water in your gray and add a generous dose of Dawn dishwater soap in both.   The sloshing and sudsing inside of both tanks, as you drive; stopping, starting and turning, should give the inside of both tanks a good cleaning.   Then drain and maybe give both of them another good rinsing to get out any "scaling" that came off.   This of course, is only possible when going from one campsite with dumpstations... to another.
    I like to do this every couple of weeks when using.
Edited by Dave and Kimberly
2022 Elite II, Hull #1097  Elli Rose 🌹 and she has the solar panels with the 390Ah lithium batteries.  Our tow vehicle is a 2019 Ford Lariat F-150 4wd, 3.5L Eco-boost, 3.55 rear end, with the Max tow package.  Elli Rose also has the street side awning and several walnut and cherry mods on the inside.
Thank you both! Great information. I am at a full service site now so both tanks will get a good cleaning. I appreciate your responses.
From the order of your steps, it appears you got more gray water in the black, than vice versa. As others have said, not a big deal.
Never tried Dawn in the tanks, though Dawn is great for so many cleaning purposes it does get very sudsy (laundry detergent is less sudsy). This company has cleaning videos, and we use the solution they suggest. The Pine-Sol is a disinfectant and the Calgon Pearls are a lubricant for the valve seals.
Get Kleen Tank's exclusive RV tank solution recipe
I like rinsing the tanks with just volumes of water. Use the black tank fill port and connect to City Water and run the sinks. Afterwards when rinsed and empty, we put a 1/2 cup of this solution in the black and a gallon water (fill the bowl 3 times). For the gray, add a cup of solution with 2 gallons water. Not too much water in each since we will travel this way and not drain these small amounts and just use the tanks as-is. If you smell Pine-Sol in your coach, you either left some in a sink trap or you have a gray plumbing vent that is not sealing.
Thank you, jd1923, I appreciate the additional input and will definitely be following through. I’m just relieved I didn’t mess something up.😀
Both Dishwater Soap and Laundry Soap can get sudsy.  However, Dishwasher Soap does not.  If it does not suds, you can use more of it.
Just suggesting less suds, the less potential for a Bubble Bath In Ollie!
We put Calgon and Pine-Sol in our black tank.
Mix 40 ounces of Pine-Sol with enough water to just about fill a gallon jug. Top off with a half cup of Calgon Bath Beads. Use eight ounces in each tank (or more in especially hot weather or if your tanks will be filling up slowly over time).
HDR:
Yep, was a great long standing approach for Black/Gray tank cleaning.  Used it in my previous camper.
But,  "In 2011 it was discovered Pine Sol, Glade, Tide, Febreze, Clorox, and Simple Green, contain chemicals that are known to cause hormone disruption, pregnancy complications, birth defects, and cancer, and can aggravate allergies.".  So it was reformulated.  The new version does not have the punch of the ole one.
Combined with the bath beads, it still is pretty good for our purposes.  But it is an expensive blend compared to the cost of two or three dishwasher machine pods.  Comparing the effectiveness of the two approaches, they seem be about the same. So either one will work.  But comparatively, why not save about 2 1/2 pounds and some $$ too?    Certainly worth giving the dishwasher pods a shot.
If you're treating grey tank with pinesol, be prepared for a lot of heavy pine smelling  vapors coming from the sink drains, etc.
I often use pinesol to clean my toilets at home. But, I run the exhaust fan, afterwards. Otherwise, I smell pinesol for days.
Pinesol was on the list of agents that killed covid back in 2020, so I started using it again, then, since disinfectants being very tough to find... but, I scored a gallon of pinesol. 🙂
On 5/16/2024 at 1:59 PM, SeaDawg said:
If you're treating grey tank with pinesol, be prepared for a lot of heavy pine smelling vapors coming from the sink drains, etc...
We're used the Pine-Sol-Calgon solution 4-5 times over the last 6 months, and I did not smell a thing. My sense of smell is acute. Last time out, I smelled some in the toilet, since the toilet had been left without any water in the bowl. With a good seal and water in the bowl, and clean water meaning no Pine-Sol in the plumbing traps, you really should not smell it. Cause can be plumbing leaks or plumbing vents that do not seal. These vents are designed to allow air in and not out. But who knows, when the TT is bouncing down the road!
That being said... In the future, I'm going with @Geronimo John's suggestion to use dishwasher soap pods. Do you really need 2-3? I would think 1 should suffice. I like this option because the pods are light, small and travel nicely. With Pine-Sol you really have to be careful, not only in transport but in application. If you do not very carefully put a cup of the liquid down one sink, no spills, flush the trap, then yep as @SeaDawg wrote, you're going to smell it.
Edited by jd1923
My Ollie gets used 3 - 4 months, and then cold storage.  Somewhere along the tour, when I am leaving a FAMCamp and going to a place with an easy dump station, I'll do the tank clean with two pods.  At the end of the season, my last clean is with three pods.
Why 2 or 3 dishwasher pods?  No justifiable reason what so ever.  Guess it just felt right.  Let's try it with one and then 2 for the end of season and save another 1/3 of the cost.  Easy to check the black tank with a strong light and a mirror on a stick.  Have not thought of a way to check the Gray tank other than to just see clean water during flush.
Good question for sure.
Edited by Geronimo John
We use one pod and a capful of Calgon water softener.  When it’s going to sit a month or two we also add some Happy Camper in both black and gray tanks with a gallon or so of water.  No odors, no issues.  Mike
The Calgon water softener is basically a water softener in a box or bottle.  Way back I used the liquid and don't recommend that due to the propensity for spills and the weight.  But their powder is good stuff for carrying in our RV's
Softer water in the tanks makes the detergent more effective.  Better Dishwasher pods have water softening chemicals therein.  So it becomes a trade off between using less dishwasher pods with Calgon or just using more dishwasher pods.  Either way, it gets the job done.
if you have real hard water, then I would lean towards Mike and Carol's approach.
Distinguished dishwasher from dish washing soap
On 5/17/2024 at 11:27 AM, jd1923 said:
Do you really need 2-3 pods?
Mike and JD:
Combining your two responses with one of mine was a bit transformational.  They have caused me to rethink my previous thoughts on this subject over the past 30 years. .
I have always suggested and used "CHEAP" dishwasher pods.  But to get the water softening needed for many of the sites we use, those water softening agents certainly would be good
So, I'm going to shift over to using a small container of the more premium dishwasher pods for tank cleaning such as this one.
For this product, I like that it has both Dawn for grease cutting and anti-sudsing agents that keep the suds to a minimum.  Amazing technology for sure.  However, the shelf life of such dishwasher pods varies by brand, but generally, they last for about 12-15 months.  The cheap dishwasher pods typically las two years in my Ollie.  To mitigate the shelf life, each season I'll either bring back to the house the left over pods.  Or justbring  6 pods for the summer tour.
Maybe I have come to a good solution considering shelf life, cost, weight, and performance.
Surprisingly, this old dog can still learn new tricks. Thanks for the idea!
typo
The powder calgon has been discontinued in the US and Canada, for a number of years. (Hence, the Polish version in gj's photo.)
Liquid has limited availability.
Washing soda (not baking soda) has the same major active ingredient.  Many dishwasher pods also use it. (Sodium carbonate.)
Or, borax (different chemical, same effect.). Or powdered laundry detergent.
Lots of good choices.
Or nothing at all. We don’t use any chemicals. No odors, we don’t put anything in the black tank other than poop and pee. You should never put tissue, wipes, feminine hygiene products or cigarette butts into the toilet system. When dumping, we flush the black tank 2-3 times until the water runs clear. Ten years in and never an issue.
...this thread's all about the "WAP2", War Against the Poop Pyramid!  Almost boils down to: Less is More.
  • Haha 3
  • (SOLD) 2022 TUNDRA
Really?  That's strange because Amazon sold 250 of these this past month.  Here is their hyper link:
https://www.amazon.com/s?k=calgon+powder+for+laundry&crid=4JTDABLQYVB6&sprefix=Calgon+Powder%2Caps%2C213&ref=nb_sb_ss_ts-doa-p_1_13
Same here no issues.
Edited by Patriot
  • 3 months later...
Very interesting discussion!!  So, some  people use nothing for odor control. What about for Black & Grey water Valve Slide Lubrication?  Do you use anything for that?
Mary        My husband and I have Hull # 55.  An Elite 2, bought in 2014
I have been buying Calgon beads on Amazon-along with the pinesol this works great. I mix up a gallon before a long trip
This was suggested to us by the guys who were professionally cleaning tanks at the rally.
