Thought I would reach out to the group to get opinions
Planning to add Firestone, Airlift or RAS to our F150 to decrease squat and improve ride quality/ driving experience
I was dialed in on the Air Lift air bags until I read about the RAS Roadactive suspension that doesn’t use air bags and is lower cost
for some odd reason I cannot paste the web pages for the 3 products and the search function drives me to drinking
any feedback is appreciated
Edited by Tideline77
Robert E
2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
Is THIS the link to Road Active Suspension you were looking for?
Yes, that is the website I attempted to paste in the OP
Robert E
@Tideline77, to paste a link into a post:  copy the link, then in the compose box look at the icons at the top.  You will see what looks like some chain links in the second group after the  U  S.  Click it and then paste the link into the top box named URL.  The box under that (link text) gives you the option to provide a description instead of the URL, like what Bill did in his post.  He typed in THIS in the link text box which takes you to the URL he pasted.  Hope this helps.  Mike
This F150 product I was asking for input from the mass mind of the Oliver herd
From everything I read and researched about this product it helps reduces suspension sway and squat along with improving traction
Robert E
My suggestion is that you join a Ford F150 forum to ask this question where there is specific towing expertise for your truck.
That’s what I do for my TV. I’m a member of the Cummins Forum and the wealth of their experience is amazing.
On a Ford truck forum you can certainly read the experiences of many F150 owners that have installed and used all of the aftermarket suspension helpers that you are considering.
Best wishes an hope this helps!
Installed two sets of Firestone rear differential airbags on two pickups and three sets of Timbren suspension enhancement systems on three pickups, all for towing.
Currently running Timbren SES on the rear differential our current Ollie TV, a 2024  F-150 5.0L.
My main reason to use them is to reduce rear end sag when towing trailers.
I like airbags because they are adjustable depending on load. Still have Firestone airbags on one pickup with about 10 years of service. They leak a little, so check pressure weekly when towing with that pickup.
Timbren are lower cost and easy to install. It also depends on how much load you carry in the pickup bed when not towing with the Timbren system. My F-150 still has about 3/4" air gap between the rear differential pad and Timbren rubber blocks giving a nice ride when Ollie is not attached with our normal camping gear loaded in the pickup bed. The Timbren system gives a firm ride when the differential pad is contacting the rubber load blocks with Ollie connected.
Original Ford rear differential jounce blocks:
Here's a photo of the Timbren SES load block with air gap between the block & differential pad when Ollie is not connected with camping gear in F-150 pickup bed. With another brand pickup I had with Ollie disconnected and camping gear loaded in the pickup bed, there was still enough load for the Timbren load block to contact the differential pad which gave a firm ride, not desirable. In that case airbags would be better than the Timbren SES system.
Edited by rideandfly
I installed an Air Lift system on both my former Chevy Silverado 1500 4x4 and current GMC Savana 2500 TVs for the primary purpose of reducing squat when fully loaded and trailering. The system will also compensate for uneven weight distribution in the TV cargo bay from side-to-side. The remote control for the onboard air pump is a great feature for ease of adjustment, based on situational needs; in general, 25psi for daily driving and 35psi when trailering with the Silverado. I will determine like settings for the newer Savana with more use. The trailering psi provides for the optimum ball height specified by Oliver, 23.5” as I recall. It is important to wire these systems to operate only in the keyed ignition ON position, since pressures are affected by temperature variances and minor seepage overtime; otherwise the starter battery could be compromised! As a bonus to this system, when dumping the waste tanks the front of the Oliver can be lifted to speedup the process and ensure a complete dump. There have been times when this is necessary due to poorly designed dump stations or an awkward approach. It is a fact that airbags will not increase vehicle load or tow capacities, but based on my experiences they do improve overall handling, especially when towing. That said, I never felt the need for the Anderson WDH. You can pan below to view my post titled ‘2019 GMC Savana 2500 Cargo Van’ and dated October 24, 2024, wherein there is some discussion on the Air Lift install.
Edited by Ronbrink
2020 OLEll, Twin, 579:
I installed the Airlift Loadlifter 5000 system on our 2019 Tundra two years ago.  It effectively reduced both squat and "jounce" when towing our Elite II, and added cornering stability.  Our air bags rely on a manual air pump, which I prefer.  It only takes me a couple of pumps with a bicycle pump to raise each spring to the 25 PSI level we prefer when towing.  I was already carrying a bicycle pump for my mountain bike.  I always carry a tire pressure gauge, so measuring the PSI of the airbags is easy.
I cannot compare to the Firestone or RAS Roadactive systems, as I have no experience with either.  But it appears to me that the RAS Roadactive system is not adjustable.  We like being able to reduce pressure with our Air Lift system when not towing, then raise it again when towing.
For what it's worth, the RAS Roadactive system presently costs $589 for our Tundra vs. $379 (with rebate) for the Airlift Loadlifter 5000.  Given our positive experience so far, I would again choose the Airlift Loadlifter 5000 because it works well, for a significantly lower price.
Edited by Rivernerd
More that a few of our owners with F-150's use the Firestone Air Bags and Bilstein 5100's on the rear shocks.
I have 18,000 miles on mine and wish I had upgraded earlier.
This GMC Savana 2500 conversion van owner is getting ready to have Bilstein 4600’s installed front and rear. I wished the 5100 Series was offered for my make and model. I plan to have a shop install the front shocks due to the heavy coil springs, given a quote of $180; I can manage the rear installs.
I use the Timbren suspension systems on my 2024 Ram 1500 Larame as it was a lot less expensive than the air bags. Additionally, you need to check the air bag pressure often as they will loose pessure over time.
Maine
True that, but not very much! Added benefit of the on-board air pump: each time the ignition is turned ON a few seconds of inflation is initiated to bring the bags up to the set pressure. Regardless of whether the vehicle is a daily driver or infrequently used, when the ignition is engaged the lost pressure is immediately restored. However, if wired to a constant 12V circuit and left unattended for a period of time the starter battery will be drained and possibly damaged in time. No bueno!
@Tideline77:   We installed the AirLift system on our Tundra a couple years ago and it's been operating as designed ever since.  No squat, good ride either towing, hauling, or normal daily driving.  Looking into the onboard inflation upgrade -- we're just carrying a bicycle pump for now.... No biggie.  The AirLift price point was about the same at the advertised RAS cost, FYI.
  • 2022 TUNDRA
I've had the RAS installed on two tow vehicles that have pulled my Elite tens of thousands of miles.  First, on a Toyota Tacoma, and now on my F150.  They have worked very well, indeed.  The ride is much better with, or without the trailer attached.
I went with the air bag / Bilstein 5100 combo and have been very happy with the outcome.  The Air Lift bags I had installed can be pumped up to 100 PSI but I have found that 30# does the job real well without excessive rear end lift.  I did use the Bilstein 5100 ride adjustable front shocks set at 1.75" in order to counteract the nose-down effect you get when pumping up the rear air bags.  This combo gives a smooth, level ride and virtually eliminates the hobby horsing you get on uneven road surfaces such as northern frost heaves or slumping road surfaces.  Far superior to the factory F150 shocks that came on my '21 crew cab.
I have Firestone airbags installed on my Tundra and have liked the way they perform (25,000 miles towing to date).  Adjustability is key for my uses. 25 psi when towing eliminates jouncing in rear of truck. Happy Camper. Adjustability, price point (approx $400 at time of install) and ease of install were selling points for me. Very little leakage over 3 yrs.
2021 Elite II, Hull# 898
I installed the standard duty version of RAS on my 2021 Silverado 1500 and was able to do it myself.  It reduced the squat from the trailer by about 1.5 inches so I've been satisfied with it. They are adjustable and I have it about middle of it's range.   Towing and non-towing with it now for 45K miles and I can't say I really noticed much of any change in handling/ride quality when not towing and that's fine with me.  I'd recommend the RAS but it seems like airbags are good as well.
  • 3 months later...
I wanted to follow up on this thread as I did have a local truck accessory shop install the RAS on my 2018 F150 4x4 super cab with 6’6” bed $610 installed
My setup had too much squat even before the truck bed or Oliver were loaded with camping gear.
this aftermarket product does have a noticeable improvement on the truck ride when not towing and it does reduce the squat when the trailer is on the ball.  But after 5000 miles towing I am not happy with the RAS system.
After email conversations with RAS there is no solution.
the maximum amount of squat it will reduce is 2 inches and in order to reduce the 2 inches of squat the RAS should be adjusted to the maximum setting .
this setting raises the rear wheel well height 2 inches from stock height to reduce the squat 2 inches
It works great while towing, handles great, truck is almost level, trailer is level.
the problem is when not trailering on my daily driver vehicle , the RAS needs to be adjusted and that is a PITA
riding 2 inch high in the rear end doesn’t work
I am looking at other options
I was traveling light in the truck bed and in the Oliver
  • Sad 1
Robert E
Robert,
When I used Firestone rear differential air bags at about 30PSI, did not have much TV rear end sag towing Ollie. It was a firm ride while towing, but when not towing decreasing the air pressure to about 5PSI gave a nice unloaded ride. I have not used the RAS system.
I'm currently using the Timbren rear differential system towing Ollie, but believe many folks here have had good results using rear differential air bags because of flexibility given by adjusting air bag pressure when towing or empty.
Some folks use onboard air compressor for the rear differential airbag systems, but I mounted the rear license plate with left & right airbag valves and found that air pressure could be easily increased with a simple bicycle air pump.
Allow me to add this, I installed the RAS on my 2013 Lariat Super Crew 3.5 Eco Boost a couple of years ago. Initially I adjusted it for the max setting using black thicker gauge disc. On my setup this was just too much and felt the ride was a bit too hard, tail up too high and finally the the tow vehicle to trailer looked like an inverted V with trailer pointing upwards at the hitch ever so slightly. A few months ago I adjusted the RAS back down to the lower setting using the thinner white disc and like this setting a lot compared to the previous max. Ride is better, TV and trailer are flat out level and the truck bed tail gate combo set lower while not towing.
From my perspective I don't think the max setting is needed on an Oliver given its modest size and weight. I would encourage you to at least try this method and see how you feel about it before abandoning the RAS. BTW never used air bags so no idea how it compares.
Legacy Elite II #70
2 hours ago, rideandfly said:
Robert,
As always sano install Bill! 👍🏻🇺🇸🤩
Edited by Patriot
3 hours ago, rideandfly said:
Robert,
Thanks for that info
the Timbren is on my list of possibilities
are you happy with the Timbren setup ?
Robert E
do you have the 5.5’ bed or 6’6” bed ? Would that make a difference? . The springs on my truck seem too soft .
We initially set it on the mid setting but after 1700 miles  I was unhappy with the ride, nose up , ass down .  Too much sag, uncomfortable driving. Rather than attempt the adjustment in a campground , I ask the 81 year old camp host if there was a shop around anywhere nearby
He mentioned a little one man shop in South Fork , Colorado
“the last garage”
very reasonable, nice garage, very nice lift !
for $75 Klaus and myself adjusted the RAS
Cool guy, known for helping travelers without gouging them
the rest of the trip the towing was great
I can give it another try but I’m frustrated enough to throw in the towel and take my $610 ass whipping
the unhitched ride on the mid tension setting was really good even tho the rear end was up about 1 3/8 inch
Robert E
I do have the 6.5 foot bed, but doubt it would make a huge difference one way or the other. Just curious are you also using the Anderson WDH? It seems there are still some folks with half tons and not using it so that certain could make a noticeable difference too. Regardless using the RAS system will raise the bed, no way around that, to what degree depends largely on adjustment implemented, ie heavy vs light. Unfortunately I can't take any photos now of my setup having just traded in my older '13 F150.
I see you have the 2.7 engine, probably somewhat lighter in weight. Curious if that throws the front to rear weight balance off compared to my setup.
Legacy Elite II #70
