Hello all,
I have been towing a LE2 for the past year with a 2025 tundra and an Anderson weight distribution system. I can say that the Anderson helps significantly with porpoising, but I found the tundra to be too little truck for the trailer. The power and torque are more than adequate, but every time I went out I found myself white knuckling going down steep grades. Just felt like very minimal safety margin if something went sideways. I sold the tundra and bought an f250 Tremor with 11000 gvwr tow package. It has a 3” receiver. My Anderson has a 2” ball on a 2” shank.
Should I by a new 3” shank with 8” drop,
or just by a new tow hitch and skip the Anderson all together. It is a bit of a hassle to use.
I was considering weigh safe hitch with 8” drop.
The new trucks receiver is at about 22.5” on center.
Any thoughts would be appreciated,
Marc
2024 Legacy Elite 2 hull #1502
Southern California
Very nice truck - I wish that one of those would fit in my garage!
You don't "have to have" the Andersen with the 250 Ford.  However, I would suggest hanging on to it until you have some time to determine how you like the ride without it.  I'm guessing that you will sell the Andersen eventually.
Thank you. I wish the truck would fit in my garage, but living in Southern California I can keep it in my driveway without much worry.
I’ll probably buy a cover for it as I really will be mainly using it as a tow vehicle. The Calmark cover for the trailer is extremely well made, so I would probably buy one from them. The fabric is so much better than what covercraft uses for their premium covers.
I’m leaving towards buying a new shank for the Anderson ball/cone assembly. It’s $240 vs over $400 plus, and I can still use the Anderson.  I’m assuming that the Anderson will still offer some degree of stability.
Southern California
I towed 5 years with the Andersen, 5 years without.  I don’t miss the Andersen at all.  If I remember correctly, 19.5” is what the top of the ball should be, you won’t get much drop from the weight of the trailer on your F250.  I had to get a drop hitch for my 2500.  Mike
Nice truck! We still have a WDH, but the WDH has been stored since we purchased a F-350. We can just fit the Super Duty in our garage, but it's a tight fit.
About 23" top of the ball measurement is where I start with the F-350 before placing Ollie on the ball. When placed on the ball Ollie is a little nose high at 480 to 500lbs tongue weight, very little sag with Ollie placed on the ball.
Ditch the Andersen and all 2" hitch hardware. Replace the old with a 2 5/16" Bulldog coupler and use whatever you need on the tow vehicle to get a 2 5/16" ball at the correct height. I installed this product:
https://www.bulldogproducts.net/product/028462_square-rectangular-mount-coupler
Is this a direct replacement for the 2” bulldog coupler? Just take off the old and replace with the new one?
Couldn’t I use a drop hitch with a 3” shank and a 2 “ ball on the existing bulldog coupler
Apparently they are in chapter 11 right now, and the product is unavailable
Southern California
Yes, you could. I just wanted the security of the larger ball.
The referenced model is the direct replacement! It’s critical to line up/drill the bolt holes accurately, but that’s it.
Chapter 11 surprising, but they did put 7K labels on one or more 5K couplers. One failed on an Oliver. Maybe the lawyers got them, too bad.
We pull our LE II on the ball with our ‘22 F250 tremor 6.7 and have been very satisfied including during a few very windy trips out west. We used an equalizer with a previous TV and Airstream.  We were very happy to leave the WDH behind. There are a few other SD tremor owners on the forum, some have a F350 and I think they all tow wo a WDH. And congrats on the Tremor.
Robert and Cheryl, Louisville, KY, Legacy Elite II 2023 Hull #1390 Oliphino, TV F250 Tremor
Thanks. My 250 has the 11000 gvwr package, so the rear axle and springs are the same as the f350. It’s a 350 with the GVWR of a 250, so it doesn’t fall into commercial vehicle territory.
what size drop did you go with? 4 inch?
Southern California
We use a WeighSafe 3” aluminum drop hitch on our 3500. Nice hitch. (We don't have a WDH but our dually isn't comparable for that part of this discussion.)
Yes a four inch drop on a two inch hitch and an adapter to go from 2” to 3”. I sometimes think the trailer looks slightly nose high but a level on the a frame indicates it is dead level.
Turns out my receiver is 2.5” not 3”
I went with a BW tow and stow with a 5” drop.
I am very impressed with the quality of this hitch.
Edited by Mroth
Southern California
On 5/1/2026 at 10:17 AM, Mroth said:
Hello all,
Marc
I am kind of surprised the Tundra gave you some issues since they don't require a WDH for trailers below 5k.  Obviously, your LE2 could exceed that with whatever you load into it and also what is in your truck.  The reason Toyota states you can get away from it is due to their active stability system offering sway control.
Were you overloaded or just wanted the diesel with exhaust brake?
Nice truck, by the way.  I would buy one but have an aversion to spending more the $50k for a truck.
The Tundra has plenty of torque and HP, so pulling is no issue. The limitations I experienced were in going down 6% grades or greater. It just simply feels way too squirrely for my taste. I also had many times where I felt like I was being blown around by passing 18 wheelers or gusts of wind. I  got cut off on my last trip and had to lock op the breaks. The trailer tires were smoking and the momentum of the trailer felt like it was pushing the truck forward.
The Tundra manual stated weight distribution required for trailers over 5k, I think the elite 2 with lithium ion batteries already exceeds that when dry. I’m pretty sure the Tundra was still within its payload capacity, but likely pretty much maxed out.
The Tundra is a great truck, and definitely capable of towing the LE2. But for me personally it was way too stressful, and felt like there was little to no margin of safety. I can afford the new truck, so the price should be worth the better ride. We shall see, I’m taking it out for its first trip with the Oliver tomorrow.
I’ll let you know if it lives up to my expectations.
Edited by Mroth
Southern California
Its the parent company, apparently. Affecting a bunch of good companies they've bought, including Reese and Tekonsha.
Major RV Hitch/Towing Company Goes Bankrupt; DOJ Investigating - RV News https://share.google/kvLioMOy73cWpU6Z3
For most of the country the Tundra is fine. I've never had any issues with sway at all and as you say the torque and HP are more than adequate especially with the twin turbos.  Colorado however can get a little challenging on the down grades, the 6 cyl engine just doesn't have the engine braking capability that the bigger trucks have.  It's too bad that Toyota doesn't offer a diesel version in the States as they do in other parts of the world, political reasons most likely.
We upgraded from 1/2ton F150 with eco boost 6 for that same reason.   The downhill compression breaking in the diesel engine makes a world of difference and no need for an Anderson hitch as the new truck has antiseay brake controls.
Getting ready to head out to San Clemente state beach. The trailer barely made the truck squat. This truck has some stout leaf springs.I’ll keep you posted about my drive.
Edited by Mroth
Southern California
@Mroth
Do  you have the original manufacdtures springs on it?
Edited by dewdev
2018 Oliver Elite II, Twin Bed, Hull #354, new 3- 130 Lithonics batteries and  Xantrex Freedom XC 3000 Pro Inverter in 2025
Maine
2 hours ago, dewdev said:
@Mroth
Do  you have the original manufacturer springs on it?
Yes, this truck came with the 11000 GVWR package. That gives you the same rear axle and springs as the F350
Southern California
Made it down to the beach. The difference in towing was night and day. Literally no comparison. It’s almost like the Oliver wasn’t behind us. Exceeded my expectations.
Southern California
I have a 2020 with the V8 and have never had any problems with power or going down grades. I do all my towing in "S" and "Tow Haul" modes which makes a big difference, as does having the larger drums with the 5.2k axles. Getting the trailer controller dialed in correctly makes a big difference, too... When it comes to braking, you don't have the larger margin of safety that 3/4 ton trucks do so everything has to be dialed in.
I'm with you on a diesel option and would buy one the second it hit the market. Not a fan of *any* of the modern big 3 diesel options and wouldn't even consider one.
