Hello all,
I have been towing a LE2 for the past year with a 2025 tundra and an Anderson weight distribution system. I can say that the Anderson helps significantly with porpoising, but I found the tundra to be too little truck for the trailer. The power and torque are more than adequate, but every time I went out I found myself white knuckling going down steep grades. Just felt like very minimal safety margin if something went sideways. I sold the tundra and bought an f250 Tremor with 11000 gvwr tow package. It has a 3” receiver. My Anderson has a 2” ball on a 2” shank.
Should I by a new 3” shank with 8” drop,
or just by a new tow hitch and skip the Anderson all together. It is a bit of a hassle to use.
I was considering weigh safe hitch with 8” drop.
The new trucks receiver is at about 22.5” on center.
Any thoughts would be appreciated,
Marc
2024 Legacy Elite 2 hull #1502
Southern California
Very nice truck - I wish that one of those would fit in my garage!
You don't "have to have" the Andersen with the 250 Ford.  However, I would suggest hanging on to it until you have some time to determine how you like the ride without it.  I'm guessing that you will sell the Andersen eventually.
Thank you. I wish the truck would fit in my garage, but living in Southern California I can keep it in my driveway without much worry.
I’ll probably buy a cover for it as I really will be mainly using it as a tow vehicle. The Calmark cover for the trailer is extremely well made, so I would probably buy one from them. The fabric is so much better than what covercraft uses for their premium covers.
I’m leaving towards buying a new shank for the Anderson ball/cone assembly. It’s $240 vs over $400 plus, and I can still use the Anderson.  I’m assuming that the Anderson will still offer some degree of stability.
Southern California
I towed 5 years with the Andersen, 5 years without.  I don’t miss the Andersen at all.  If I remember correctly, 19.5” is what the top of the ball should be, you won’t get much drop from the weight of the trailer on your F250.  I had to get a drop hitch for my 2500.  Mike
Nice truck! We still have a WDH, but the WDH has been stored since we purchased a F-350. We can just fit the Super Duty in our garage, but it's a tight fit.
About 23" top of the ball measurement is where I start with the F-350 before placing Ollie on the ball. When placed on the ball Ollie is a little nose high at 480 to 500lbs tongue weight, very little sag with Ollie placed on the ball.
Ditch the Andersen and all 2" hitch hardware. Replace the old with a 2 5/16" Bulldog coupler and use whatever you need on the tow vehicle to get a 2 5/16" ball at the correct height. I installed this product:
https://www.bulldogproducts.net/product/028462_square-rectangular-mount-coupler
Is this a direct replacement for the 2” bulldog coupler? Just take off the old and replace with the new one?
Couldn’t I use a drop hitch with a 3” shank and a 2 “ ball on the existing bulldog coupler
Apparently they are in chapter 11 right now, and the product is unavailable
Southern California
Yes, you could. I just wanted the security of the larger ball.
The referenced model is the direct replacement! It’s critical to line up/drill the bolt holes accurately, but that’s it.
Chapter 11 surprising, but they did put 7K labels on one or more 5K couplers. One failed on an Oliver. Maybe the lawyers got them, too bad.
We pull our LE II on the ball with our ‘22 F250 tremor 6.7 and have been very satisfied including during a few very windy trips out west. We used an equalizer with a previous TV and Airstream.  We were very happy to leave the WDH behind. There are a few other SD tremor owners on the forum, some have a F350 and I think they all tow wo a WDH. And congrats on the Tremor.
Robert and Cheryl, Louisville, KY, Legacy Elite II 2023 Hull #1390 Oliphino, TV F250 Tremor
Thanks. My 250 has the 11000 gvwr package, so the rear axle and springs are the same as the f350. It’s a 350 with the GVWR of a 250, so it doesn’t fall into commercial vehicle territory.
what size drop did you go with? 4 inch?
Southern California
We use a WeighSafe 3” aluminum drop hitch on our 3500. Nice hitch. (We don't have a WDH but our dually isn't comparable for that part of this discussion.)
Yes a four inch drop on a two inch hitch and an adapter to go from 2” to 3”. I sometimes think the trailer looks slightly nose high but a level on the a frame indicates it is dead level.
