Trainman Posted November 9, 2021 Posted November 9, 2021 So after a 2 1/2 year period of owing our Elite II and setting outside in the Texas sun our fiberglass gelcoat was beginning to show some chalking and dulling and in need of a buff and wax job. Now being a retired body shop mgr. for some 35 years at a large DFW dealership doing the proper job was not a problem for me, but at 76 it wouldn't be doing it like I was 40, for sure. I used my 7" buffer and wool buffing pads, I used the Velcro system pads and buffer backing plate, the tie on pads are pretty much useless. I first buffed with Mequiar's #67 RV and Marine compound which did a very good job and really cut the oxidation, probably running the buffer back and fourth on the surface 8-10 times till the gelcoat what at a very high luster, due note here, the top of the trailer and ends we the most dulled areas on the trail, but I did the whole trail just because I didn't want to do a partial job when it comes to doing something. Due note here, I did have to use scaffolding to do the top, you will not be able to reach far enough in with a ladder, plus the scaffolding is much more safe for this old guy. I did the top and ends in one day and the sides the next day. Now for the Mequiar's Flagship RV and Marine polish which I put on by hand and took off with a orbital buffer and a polishing pad for it's final on this project, I hope this will last another couple of years before it needs another buff job, but will polish once a year to help preserve the finish. I watched several video's on YouTube on this and this guy knew what he was doing, or the way I would do it, trainman 4 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold.
John Dehne Posted November 12, 2021 Posted November 12, 2021 I have had great success with the Mequiar’s Flagship wax. Been using it for years. Holds up great and gives me some exercise. I will apply twice a year. 1 John & Chris Dehne Manchester, MD. 2021 Elite II twin Hull# 901 “Fiberbeergrass” 2021 Ram 2500 Cummins 4x4 Life is good!
LongStride Posted November 13, 2021 Posted November 13, 2021 Meguiar's Flagship appears to be the choice of many others as well. We used it to wax our Elite just prior to putting it to bed for the winter. 1 Mike and Yasuko 2021 Legacy Elite Hull #820
rideandfly Posted November 14, 2021 Posted November 14, 2021 We had water spots that normal waxing would not remove. Called Meguiar's and they recommended using Meguiar's #67 compound first then using Meguiar's Flagship wax, the combination worked great removing water spots and putting a great finish on Ollie! We used both during a two day "workout". 5 Bill 2015 LE2 2024 F-350 6.8L
dewdev Posted November 14, 2021 Posted November 14, 2021 I also used both Meguirs products on my newly purchased used Olliver this spirng. I found that the 67 One Step Comppound took off the water spot markings easier than 2 other non-Meguiars products I tried. I used the Meguiar's Cleaner Wax this spring after the 67. This fall I used the Meguiars Flagship Premium Marine Wax. The Premium Marine Wax was a lot easier to apply than the Cleaner Wax and appeared to leave a far superior finish than the Cleaner Wax. Having owned a few boats in the past, these Meguiars products are a lot better than any of the other waxes I used in the past. 1 Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
Mountainman198 Posted 22 hours ago Posted 22 hours ago (edited) Reviving this thread for those who are not interested in the ceramic path for what ever reason. Thanks Trainman! It works! My gelcoat was beginning to chalk and shadows were present where the Oliver logo was removed in the lower rear. Using a 120v makita rotary buffer, a white Presta wool pad and Meguiars One Step polish, the gel coat is again glossy and shadows have been eliminated. Took about 2 hrs to do the entire lower half of the trailer. Will finish buffing the upper half using scaffolding then apply 3M Marine paste wax by hand. While I wax the entire trailer each year, this is the first time the lower half of trailer has had to be buffed since new (upper half was buffed 2years ago for the first time). Trailer lives outdoors 24x7x365. Edited 22 hours ago by Mountainman198 6 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW
Ronbrink Posted 58 minutes ago Posted 58 minutes ago Been using the two Meguiar’s products @rideandfly highlights on our 2020 OLE ll since new. I installed fall protection on the scaffolding, and use an umbrella as not to apply said products to a heated surface and personal comfort. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
