Showing content with the highest reputation on 08/21/2021 in all areas
  1. I should probably clarify that I wouldn’t recommend towing your Ollie at 90 mph. But I did look down once while not paying attention and saw that number - and then slowed down. My experience though is that the trailer tows very well at any legal speed limit.
    4 points
  2. I’ve heard that the Elite II tows well at 90 without an Anderson and with a truck that people say was not meant for towing. Don’t remember where from - possibly the passenger seat from someone reminding me that we were towing.
    4 points
  3. In trailers with the suburban 6 gallon tank the inside switch turns the propane on/off for hot water. The outside switch turns the 110v on/off (when available). If electrical hook up is available there is no need to turn on the inside switch. When there is no electrical hookup, the inside switch turns on the propane which cycles on/off as needed. You can use both the 110v and propane at the same time if you want hot water fast! Mike
    4 points
  4. Good point. It was explained to me that if the mechanical system keeps sway down the electronic system on the truck won’t do anything. If for some reason the mechanical system fails the electronic system reacts. I can’t vouch for the validity of that but most new half tons will have the anti sway and folks still use an anti sway hitch. It would be nice if there was something definitive on this issue. Mike
    3 points
  5. Thanks everyone, Seeing this post was God sent. So we are out camping/ boondocking for the first time ever in the Oli. I tested all of the other systems at home accept the truma. I flip the switch on the on the truma in the outside bay. No hot water. We spent last night without hot water. I looked all over for a gas shutoff for the truma, I could hear the the igniter try to start, but didn’t get hot water. How I didn’t pay attention to the 2.5”x3” controller on the wall beats me. I saw this post the first thing I logged on the forum. So I looked at the main switch panel; No switch. Then over to the systems control area by the pantry, and there it was. Now I can get cleaned up with hot water! BTW, we went all night and the AGM batteries only got down to 12.7. That included a little heat and a movie. But now I’m off topic. take care everyone.
    3 points
  6. On my trailer, the switch does turn off the Truma. The reason being that it’s fun to spend an hour searching through manuals trying to figure out why your water heater doesn’t work after you inadvertently flipped the switch.
    3 points
  7. I’ve only got 3500 miles under my belt and this is my first RV. I was really worried about towing manners after seeing all the videos about sway. I have to say the towing manners of the Oliver is one of the most impressive features. No sway thus far. I use Andersen with my 1/2 ton and tows beautifully.
    3 points
  8. My driving partner, in a panic, terrified me by over correcting with a sharp right, then over correcting with a sharp left, then another over correction to the right. I was sure that a life changing event was beginning. But the combination of anti sway on the truck, the Anderson hitch, and the Oliver design actually straightened out the induced sway. I’m a believer in all three.
    2 points
  9. Not saying it couldn't ever happen, but 14 seasons, 2008 Elite, 3 different tow vehicles, over 100k miles, no experience with sway, ever. No wdh, no sway bar, older tow vehicles with zip for electronic sway control. Except for change in mpg/range, have to remind ourselves we're towing.
    2 points
  10. Can anyone state that they have had, or know of an instance where someone else has had, sway while towing an Oliver? I can not remember anyone on this forum ever mentioning it in the past 13 years. My personal experience is never any sway, no matter what.
    2 points
  11. Its also worth pointing out that most newer trucks and SUVs equipped with a towing packaging have electronic computer controlled anti sway built into the system and they work very well based upon my experience. This isn't to say the Oliver doesn't track well, it certainly does, just pointing out there are built in transparent systems that help with safety in this area. I suspect adding a mechanical system to a vehicle already equipped with electronic computer controlled anti sway might confuse or hamper the effectiveness it. Just a thought.
    2 points
  12. I just got back from the Oliver Service Department and had them install the one I was unable to push into place. Happy to report the suspension now has the correct upward travel with the installation of the 5" shackles and the annoying suspension squeaks are a thing of the past. While there, I looked at another Ollie I awaiting to be picked up and I am happy to report both the correct shackles were installed along with the hanger bushing. In addition, we had the shower floor squeak fixed while at the service department for the trailer's annual checkup (re caulk, bearing repack, system checks, etc). Spent a significant amount of time talking with the "Trailer Whisperer" Jason and he said the shower floor was not cut correctly from the factory and was rubbing up against the sides. Happy to report we no longer have the squeaking floor!
    2 points
  13. We've had a composting toilet since pick up in December. Love it. Watched the you tube videos before and learned from other's mistakes so has been issue free. We bought a spare blower from the company just in case of a potential break down and it would be super easy to instal while on travel. If you follow the recommendations on their site, there is no smell at all. The fan actually serves to lear the air "live" so no need to put warning tape across the bathroom door after usage. Our medium has not been changed in a few months now even though it's seen a lot of use. We usually go a couple of weeks between trips and, once home, unplug the fan after a couple of days so the medium does not dry out. The organic matter digests over those two weeks and it is all ready for further usage. Truthfully, we can't tell how long we can continue with this cycle as, so far, there is no increased smell. That said, we don't put toilet paper or wipes in the container. Keep a tiny, lidded, foot operated garbage pale between the toilet and sink and use our old deli meat zip locks for that material. throwing the bag out every 2-3 day and, no smell even in how weather. We also carry a spare pee bottle with cap. Never had a reason but if we needed to store a full bottle (mabey to wait out bad weather?) we could leave a full bottle with cap waiting outside till it was convenient to empty. Even while emptying the bottle, I've noticed very little smell. Certainly not as much as you would expect to encounter in a bathouse or, for that matter, in many RV bathrooms with flushers. I agree with using a bucket being a good solution for vomit. Would probably do the same if we had a flush toilet. Concerning diarrhea, I've been down that road and it was no problem at all. The inside of the bowl is super slick so we never clean with anything other then a wipe. Any over spray, were it to occur, could be spritzed off using the same spray bottle of vinegar mix used after peeing.
    2 points
  14. Our Hull #050, built in 2013/14, has the Suburban 6 gallon Water Heater with the outside switch. Having had an earlier model Oliver prior to this one I was familiar with the process of having to go outside to turn the the WH on/off. In the new trailer, I wanted to be able to control that aspect from the inside so during the build I had them install a relay that would control 110V power going to the WH via an interior switch. Both the electric and propane operations are activated from the inside. The outside switch on the WH is always left in the "on" position. This picture that shows the switches. Each of the switches has a LED beneath it to remind you they are "on." I modified the propane control switch so that the LED in the switch itself will come on while the WH is in the ignition stage and goes out when it lights. This is the same way the switch for everyone's propane control works.
    2 points
  15. I try to tow with a full fresh tank. Like routlaw said, even in emergency maneuvers the trailer tracks true. We’ve done hard braking and radical emergency turns at speed and our Ollie behaves like a champ. Mike
    2 points
  16. I think our group is pretty special, actually. A lot of intelligent, curious, and caring individuals. I also think that the low, flat tanks are helpful, in many situations. The water weight is spread along the length of the trailer. (We usually tow full, or empty, on fresh water ) We usually tow full, or empty.
    2 points
  17. What you tow is not nearly as significant as understanding the additional responsibilities you're taking on when towing.
    2 points
  18. We have a Hayes electronic SwayMaster installed on our LE2 Ollie. Not sure if this device is still on the market, there were problems with this unit working with some OEM vehicle sway systems. This unit applies trailer brakes when it detects sway events. It's equipped with a GPS to activate system above 45MPH. It's also equipped with a directional gyro that applies trailer brakes during a sway event with rapid direction change. On two occasions I had the brakes to activate when I was towing too fast down mountains halfway through both curves. At the time I thought both cases were sway events that activated the SwayMaster applying trailer brakes. In hind sight, I don't believe I experienced trailer sway or instability. Did not sense or see any sway or instability. Only thing experienced was trailer brakes being applied, due to going too fast through the curves with rapid direction change through the curve. I slowed down and never experienced this scenario again. Have always wondered why Ollies are so stable when properly loaded and towed reasonably. Is it the suspension and commercial light truck tires that contribute to Ollie's stability? I'm sure during slick conditions, improper loading, or towing recklessly any trailer can have a sway event.
    1 point
  19. Just removed all metal shavings from my Elite 1 by using a small diameter 8’ flexible plastic rod with a hunk of Duct tape on the end ~ worked just fine.
    1 point
  20. Thanks John. I did not notice that.
    1 point
  21. I never watch too much TV and have never watched the program Orange is the new Black. I was a bit surprised that I found listening to the audio book interesting. Bill
    1 point
  22. Interstate 80 at mile marker 344.4 an Elite II was headed west as Twist and I were headed east. Bill P.s. that mile marker was in Nebraska
    1 point
  23. Thanks everyone for the information. I really appreciate the support.
    1 point
  24. I think our group is pretty special, actually. A lot of intelligent, curious, and caring individuals. I read that the people who own Olivers are a close knit group and from what I have seen so far that seem to be the case.
    1 point
  25. We'll be collecting our LE2 on September 16th, and wanted specific dimensions of the interior of the HighPointe convection microwave so we can come prepared with appropriately sized cookware. I contacted Phil Andrews for the model number, which is ECO28KD7. The interior dimensions are 13" W x 13" D x 9" H, and the turntable is 12.4" in diameter.
    1 point
  26. Over 100k, no Anderson or antisway. Three tow vehicles. we have an Elite.
    1 point
  27. Also, CAT Scale has a couple of nice apps. Check out: "Weigh My Truck" and/or "CAT Scale". The latter app is newest and has a subfunction link to the the former. These really make the weighing process easy.
    1 point
  28. I’ve got 5.5 years and 60,000+ miles towing my EII and have never had a sway issue or any other misbehavior. That’s towing with a 2012 Tacoma, 2016 Ram 1500, 2020 Ram Rebel and now a 2020 Ram 2500 Diesel. I used the Andersen hitch on the first 3 trucks. I do not use the Andersen on my new 3/4 ton. Mike
    1 point
  29. Based on positive reviews from John Davies who started this thread, I’ve been using the TT600 since May. Works great! I was getting alarms every 1/2 hour or so, so I hooked up the booster, no more alarms. I broke the tiny antennae (my fault) and they sent me a new one no charge. Great Customer Service. I’ve got 6 sensors, using one on TV spare as Geronimo John recommended early on. There are plenty of reliable TPMS available, I’m pleased with the one I have,
    1 point
  30. David S. brought this to our attention sime time ago. We ask people to use private messages, or pms, when sharing contact info (email addresses, phone numbers,et), to avoid that information being swept up by spammers, bots, and bad guys. Private messages are just that-- private. Only you, and the intended recipient can see them. But, some members are new to forums, and our private message system can be a multistep process. The simplest way to send a private message (pm) is to log in, click on the three horizontal bars top right ( dropdown menu button.) Click on the envelope. Click on compose new. Start typing the first few letters of the user's screen name, and when you see the correct name, start writing your email. Proofread, and hit send. Done. ( note: this is a much simpler process than our old system!) Alternatively, if the person you would like to pm has a recent post, click on his username anywhere it appears in bold... in a post, at the recent users at the bottom of the page, or even in the "thanked by" section at the bottom of a post. Clicking on the username will take you to the user profile, and you'll see an envelope. Clicking here will take you to the message box, where you can type your message, proofread, and hit send. I added a few screenshots in the next post below as visual aids. Sherry
    1 point
  • Recent Achievements
    • dmorningcall earned a badge
      One Month Later
    • Grant earned a badge
      Week One Done
      One Month Later
    • Lucia earned a badge
      Week One Done
      One Month Later
    • GregCA earned a badge
      Week One Done
      Experienced
    • Todd B went up a rank
      Rising Star
    • GregCA went up a rank
    • Sentry62 earned a badge
      Week One Done
    • Mark W Clay earned a badge
      Week One Done
      One Month Later
    • KimHim earned a badge
      Week One Done
      One Month Later
    • Skynyrd earned a badge
      Week One Done
    • annasteve went up a rank
    • AKPilot earned a badge
      Conversation Starter
      First Post
    • Chasing Stars earned a badge
      Dedicated
    • Nisi earned a badge
      Week One Done
