Moderators Mike and Carol Posted August 30, 2023 Moderators Posted August 30, 2023 While in Colorado this summer I started getting an intermittent “trailer brakes disconnected” message on my dash. Very intermittent. At times I could drive a couple hours and all was good, then the message would come on intermittently for the next hour. It only stays on for anywhere from a few seconds to 20 or 30 seconds and then go off again. When I had the message the trailer brakes were definitely off. I checked the 7 pin connector and looked for loose wires. When we got home I had my local RV guy check the trailer. He found nothing. I took my truck in to the dealer, he checked everything (connector, traced wires, used trailer simulator and drove around, etc) and he found nothing. I just pulled our trailer over to the house to get ready for our next trip and sure enough I got the message couple of times before we got home. In the spring my RV guy recommended we replace the brakes next visit because there’s not much life left. When working they still have good stopping power. I’m thinking after this next trip (home mid-October) I’ll go ahead and have him replace them. My hunch is that it’s something loose or not well connected on the trailer side. Any thoughts? Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Rivernerd Posted August 30, 2023 Posted August 30, 2023 6 minutes ago, Mike and Carol said: Any thoughts? When the brake pads on my 2008 Tundra got thin, the "Brake" warning light on the dash started to light up intermittently. Like you, I knew the pads were near the end of their useful life because I check them when rotating tires. But, I thought the pads still had some life left, so I didn't immediately replace them. The brakes continued to feel solid, so the light made me wonder if there was another issue with the braking system. When I finally got around to replacing the pads on the 2008 Tundra, the "Brake" warning light went out. Lesson learned: when the light comes on, even intermittently, replace the pads (or in case of Oliver brakes, the shoes) sooner rather than later. I concluded the Tundra must have a sensor that activates the warning light when any of the pads get too thin. Please post what you learn after your Oliver brake shoes are renewed. 5 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Moderators Mike and Carol Posted August 30, 2023 Author Moderators Posted August 30, 2023 1 minute ago, Rivernerd said: When the brake pads on my 2008 Tundra got thin, the "Brake" warning light on the dash started to light up intermittently. Like you, I knew the pads were near the end of their useful life because I check them when rotating tires. But, I thought the pads still had some life left, so I didn't immediately replace them. The brakes continued to feel solid, so the light made me wonder if there was another issue with the braking system. When I finally got around to replacing the pads on the 2008 Tundra, the "Brake" warning light went out. Lesson learned: when the light comes on, even intermittently, replace the pads (or in case of Oliver brakes, the shoes) sooner rather than later. I concluded the Tundra must have a sensor that activates the warning light when any of the pads get too thin. Please post what you learn after your Oliver brake shoes are renewed. This is what I’m thinking as well. I’ll be getting them replaced next month and will let everyone know the result. 1 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
dhaig Posted August 30, 2023 Posted August 30, 2023 @Mike and Carol, I suggest checking for a loose ground connection, or a corroded connection, probably on the trailer. Also check the ground connection to the 7-pin connector. Add electrically conductive grease to the 7-pin connector, if you have not already done so. I have encountered similar symptoms on a utility trailer, which ultimately proved to have a poor ground connection. I have not seen these symptoms when towing our Oliver. Does the cover/latch on the 7-pin receptacle on the truck engage the catch on the 7-pin plug of the trailer to secure it? Have you tried wiggling the 7-pin connector when it is engaged in the truck's receptacle to see if this triggers the message?. I assume your Ram TV has an OEM brake controller. Has this been checked? When the message is displayed do the brakes respond when pressing on the brake pedal or by manually applying the brakes using the brake controller? When the trailer is connected and the the "trailer brakes disconnected" message is displayed do the lights on the trailer work? Brake lights? If you have another trailer or a friend has one, does the problem still occur when another trailer is connected to your truck? Good luck. Don 1 1 North Texas | 2022 LEII, Hull #990, delivered 2/17/22 | 2014 BMW X5 35d
SNY SD UP Posted August 30, 2023 Posted August 30, 2023 M & C, Are you getting the notice via your Dash Messages? We did, and here is what it was. (I am working on a Post about this). JD had a similar post about Brake wire issues, which I found informative. https://olivertraveltrailers.com/forums/topic/2685-how-to-brake-wiring-is-undersized-some-answers-and-partial-solution/#comment-25131 There is a 2-wire pair (mine looked like old brown table lamp cord) which travels through the front and rear axles that bring the current for electric brakes from the Drivers side to the Pass side. It is a common way RV manufactures do it. That wire has slack and sits inside and rubs inside those tubes. Ours rubbed/abraded to bare wires on a couple of surfaces, causing an intermittent short that soon became a constant short. I basically just cut the old wires off and ran a larger insulated 2-wire pair 12awg across the outside of the back of the axles at the rear so to prevent rock strikes, once I had it all connected. WE HAD BRAKES AGAIN… I found that removing the wheels made it easier to get in and work at each hub, where green brake wires go into back of the plate to get to the brakes. Before you cut your wires, maybe test the green wire going into brakes with a meter to make sure. If you pull the "Brake break-away" cable and then measure the current where the brake wires come in (inside driver side wheel well) you might get a reading, but I am not sure what an electrical short might do to that reading. I was told 80% of the time it is the 7-pin (which it was not), so I naively replaced it, before I found out what the real issue is; now I have a “bugly” 7pin, which is not sealed to the weather like the OTT factory one... Best of luck. B~Out 4 2 3 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
Moderators SeaDawg Posted August 30, 2023 Moderators Posted August 30, 2023 We had this intermittent issue probably 10 years ago. It was a poor ground connection. 1 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators Mike and Carol Posted August 30, 2023 Author Moderators Posted August 30, 2023 1 hour ago, dhaig said: @Mike and Carol, I suggest checking for a loose ground connection, or a corroded connection, probably on the trailer. Also check the ground connection to the 7-pin connector. Add electrically conductive grease to the 7-pin connector, if you have not already done so. I have encountered similar symptoms on a utility trailer, which ultimately proved to have a poor ground connection. I have not seen these symptoms when towing our Oliver. Does the cover/latch on the 7-pin receptacle on the truck engage the catch on the 7-pin plug of the trailer to secure it? Have you tried wiggling the 7-pin connector when it is engaged in the truck's receptacle to see if this triggers the message?. I assume your Ram TV has an OEM brake controller. Has this been checked? When the message is displayed do the brakes respond when pressing on the brake pedal or by manually applying the brakes using the brake controller? When the trailer is connected and the the "trailer brakes disconnected" message is displayed do the lights on the trailer work? Brake lights? If you have another trailer or a friend has one, does the problem still occur when another trailer is connected to your truck? Good luck. Don Don, thanks for the suggestions. I replaced the 7pin connector, my RV guy checked it when I took it in. Dielectric grease applied. The 7pin fits and is secured by the cover. The Ram dealer checked the controller. The brakes don’t work when the message is on. I haven’t had the message come up when stationary, so I can’t tell if lights are affected. Wiggling the 7pin does nothing. I’m going to crawl under the trailer in the morning (when it’s not 100+ degrees) to “explore”. Mike 3 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Moderators Mike and Carol Posted August 30, 2023 Author Moderators Posted August 30, 2023 1 hour ago, SNY SD UP said: That wire has slack and sits and rubs inside those tubes. Ours rubbed/abraded to bare wires on a couple of surfaces, causing an intermittent short that soon became a constant short. I basically just cut the old wires off and ran a larger insulated 2 wire pair across the back of the axles at the rear so to prevent rock strikes, once I had it connected. WE HAD BRAKES AGAIN… Bryan, I haven’t checked that wire - will do so in the morning when the weather is a bit cooler. Thanks - Mike 3 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Moderators Mike and Carol Posted August 30, 2023 Author Moderators Posted August 30, 2023 55 minutes ago, SeaDawg said: We had this intermittent issue probably 10 years ago. It was a poor ground connection. Thanks, Sherry. I’ll check it again. Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Steph and Dud B Posted August 30, 2023 Posted August 30, 2023 2 hours ago, SNY SD UP said: That wire has slack and sits inside and rubs inside those tubes... I basically just cut the old wires off and ran a larger insulated 2-wire pair 12awg across the outside of the back of the axles at the rear so to prevent rock strikes, once I had it all connected. WE HAD BRAKES AGAIN… Same thing happened with our first trailer. The wires were actually folded inside the axle tube and chafed until they shorted. Dumb design. Same repair. Never had another problem. 1 3 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Moderator+ ScubaRx Posted August 31, 2023 Moderator+ Posted August 31, 2023 Mike, every time I've seen this problem, it's been due to the white (ground) wire coming into the trailer from the 7-pin wiring bundle not being securely connected to the grounding buss bar located under the aft dinette seat. All the rest of the wiring on that bar is yellow. All this was going on between the time our trailer was built and about Hull #200. The factory actually sent out a bulletin about this and a standing order to check for this problem on every trailer that passed thru the shop for any reason. Your trailer was probably checked at some time in the past and it either passed inspection or was fixed. Some of those back roads Carol makes you drive on could very easily have loosened that wire. Now would be a good time to check tightness on all the wires attached to that bar. 5 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Moderators Mike and Carol Posted August 31, 2023 Author Moderators Posted August 31, 2023 5 hours ago, ScubaRx said: Your trailer was probably checked at some time in the past and it either passed inspection or was fixed. Some of those back roads Carol makes you drive on could very easily have loosened that wire. Now would be a good time to check tightness on all the wires attached to that bar. Steve, it would be nice if that was the issue! I’ll check it today. Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Geronimo John Posted August 31, 2023 Posted August 31, 2023 19 hours ago, Mike and Carol said: Add electrically conductive grease to the 7-pin connector, if you have not already done so. 19 hours ago, Mike and Carol said: Dielectric grease applied. Mike: Good catch. For sure Dielectric Grease. GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators Mike and Carol Posted August 31, 2023 Author Moderators Posted August 31, 2023 3 hours ago, Mike and Carol said: 8 hours ago, ScubaRx said: Your trailer was probably checked at some time in the past and it either passed inspection or was fixed. Some of those back roads Carol makes you drive on could very easily have loosened that wire. Now would be a good time to check tightness on all the wires attached to that bar. Ground wire was tight. Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Moderators Mike and Carol Posted September 12, 2023 Author Moderators Posted September 12, 2023 OK, just back from the RV repair shop, again. They pulled the brake wires from inside the axles and attached new wires, zip tied to the outside of the axle. They gave me the old wires. One was about 11’ long, the other about 9’. The excess was stuffed into the axle. One had a spot where the insulation was rubbed through showing bare wires. The other had about 6” of electrical tape wrapped around the end where it connected to the brake. When I took the tape off I found a weird situation that makes no sense to me. This appears to be the same issue SNY SD UP was experiencing (his photos above). First, here’s the rub: (brown insulation worn to the red then to the copper. Then here’s the end that was taped. The tape extended from the end of the wires to where my fingers are, making it look as though it was one set of wires. The ends of the brown pair on top were completely covered with tape and the left end of the bottom brown and white pair was also covered, leaving only the ends of the brown and white pair showing. So, it appears they were not connected to anything? The tech simply cut the wires off when he was replacing them which are the brown/white pair. The top pair has one wire stripped and one is a few inches shorter than the other. I’m not sure what this was all about. They zip tied the new wires to the axle. I will add a few more to what they used. I had no “trailer brake disconnected” messages on the way home. We leave tomorrow for our fall trip for some cooler weather and fall leaves. Hopefully the problem is solved. I will close out my ticket with Oliver service. Their only offering was that when they’ve encountered this issue it’s almost always the tow vehicle. Not in this case. 4 2 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
John E Davies Posted September 12, 2023 Posted September 12, 2023 That is scary wiring that the tech removed, BTW the wires should be run along the back side of the axle tubes, not the top or front. That way errant stones won’t cut or crush your pretty new wires. I personally would install split loom over them, but that is a personal choice. I bet the brakes work great now. John Davies Spokane WA 4 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Moderators Mike and Carol Posted September 12, 2023 Author Moderators Posted September 12, 2023 I had asked him to run the wires on the back of the axle. I guess it depends on what your definition of back is? I’ll move them when I add a few more zip ties. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Wolfepack Posted September 12, 2023 Posted September 12, 2023 For others that may experience this same problem, on my previous Chevrolet 1500 LT I was getting intermittent but often trailer brake disconnected warnings in the cab. Replaced the OEM brake controller. Never had the issue again. The issue has not resurfaced in my GMC 2500HD with about 3500 miles towing leading me to believe it was a faulty brake controller switch and not the trailer. 2 Patrick and Danielle Wolfe / 2022 LE II Tail #22-1052 / 2023 GMC 2500HD SLT 6.6L Gas
BoondockingAirstream Posted yesterday at 12:58 AM Posted yesterday at 12:58 AM (edited) (Mike & Carol asked me to check this Thread out. I had already read this. I went back to my original post to add: " I lifted each side of the trailer, spun the wheels, pulled the 'brakeaway switch' out. The spinning wheels stopped immediately and I could not physically turn any. Plugged it back and they spun freely. Did both sides. Brakes probably have very little wear... Even the bearings were smooth and quiet. This is not something I would wish upon any Oliver owner. The Brake Wiring changes are so frequent with these electrical wiring... there seem to be changing the braking wiring all of the time. ???? ) Purchased the 2019 Oliver Elite II February 2022 from Original Owner. It was clean and had not been used very much. Much like on the Oliver lot when new. We got the plates, insurance paper work filed and paid and connected the Oliver to the 2016 F350 4x4 Diesel. We also have a 2019 27FBQ Airstream International. The Oliver was for a Boondocking alternative travel trailer. NO BRAKES. Plug into F350, pull away and 'Brakes Disconnected'. The Brake System of the F350 works perfectly with the 2019 Airstream. Not on the Oliver, apparently. I was told by Oliver it is possible the 2016 F350 may not be compatible. I am going to try one of our under the dash units, used on two other Airstreams we owned over the last 19 years. The heavy F350 handles the Oliver easily, but having Trailer Brakes... is necessary. Also to sell, as well. I removed the Truma Hot water system. It was not operational, as well. I was notified about a Recall in the US MAIL,,, but since I removed the totally mutilated Truma... "sorry no can help". It had the uncrimped propane heating unit that is on the recall.. Previous owner gave me Service Tickets trying to have it fixed. Did not work then either, Reading other posts about Trailer Brakes Not Working... our wiring looks nothing like any of those, with worn wires. No information in the Oliver Service Guide. Oliver is careful not to get into giving advice and then have things go wrong, which I understand. We were also told, possibly, our 2016 F350 trailer electronics, may be too OLD for the Oliver. It works perfectly with our 2019 Airstream. Hmmm. It appears that the wiring on Olivers change often. Ours is different under the table and beds than other photographs seen on the Forum. I photographed the possible areas. Did check all of the wiring into the Buss Bar. All snug and look good. Everything else works that is electrical. Any suggestions? First photo... front (towards rest room) dining table seat. Second photo... rear (towards street side bed) dining table seat. Edited yesterday at 01:10 AM by BoondockingAirstream 1
jd1923 Posted yesterday at 01:17 AM Posted yesterday at 01:17 AM 16 minutes ago, BoondockingAirstream said: It appears that the wiring on Olivers change often. 🤣 🤣 🤣 Yeah, but the brakes should work given power from ANY brake controller! Voltage and correct amperage draw at the wheels? Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Snackchaser Posted yesterday at 02:08 AM Posted yesterday at 02:08 AM Based on the breakaway switch working okay, and the F-350 working with the Airstream, I'd take a close look at the Oliver's 7-pin plug. It could have a loose connection within the molded rubber plug. It could be a hard thing to test, but your best bet would be a continuity test between the plugs female pins and the other end where it terminates... while twisting and pulling it to be sure the circuit break is not intermittent. You might just replace it if there is any doubt. My 7-pin cord terminates in a electric 4" x 4" junction box under the sink, could be loose or shorted in there too. I didn't read the entire post, so apologies if you have already done this. Good luck, Geoff 3
BoondockingAirstream Posted yesterday at 02:06 PM Posted yesterday at 02:06 PM Snackchaser: I removed the panel under the sink yesterday, and nothing like you describe. What year is your Oliver? What are you towing with? My Oliver is a 2019. My tow vehicle is a 2016 F350 Diesel 4x4. Does anyone reading this in the Las Vegas, Nevada area? If I can plug my F350 into your Oliver and everything works... it is the Oliver. If nothing changes it is the Tow Vehicle. 1
Snackchaser Posted yesterday at 05:41 PM Posted yesterday at 05:41 PM Your 7-pin pigtail has to terminate somewhere in the trailer. Mine is a 2022 and they should be somewhat similar. Trace the pigtail to where it enters the trailer through the penetration, likely behind and under the propane tanks. From inside, it probably enters under the bathroom sink and from there you can trace to where it terminates. It has to be in an accessible location. Mine is in a standard junction box under and to the right of the bathroom sink, on the floor. It is somewhat obscured from vision by the heating duct.
