John Dorrer Posted April 19, 2024 Posted April 19, 2024 (edited) I must be doing something wrong. Today unhitching on a slight downgrade, we got Jolli Olli level, set chocks and raised the tongue. The truck and trailer appeared to be lined up. When the bulldog came off the ball, the trailer lerched sideways close to 1-1/2' and back a foot, with the front jack block sliding and the front jack almost coming off the block. This is the worst I have ever seen. We have this happen on a regular basis (not bad like today, but almost every time we unhitch) and don't know how to stop the tension and lerching. I have to believe the bulldog should be able to lift off the ball smoothly. Thanks for any advice. Edited April 19, 2024 by John Dorrer Typo John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Moderators topgun2 Posted April 19, 2024 Moderators Posted April 19, 2024 (edited) I assume that you had both sides of the Ollie's wheels chocked (passenger and drivers sides). Can I also assume that you had already removed the "whale tail" from the bottom of the hitch? Bill Edited April 19, 2024 by topgun2 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
John Dorrer Posted April 19, 2024 Author Posted April 19, 2024 1 hour ago, topgun2 said: I assume that you had both sides of the Ollie's wheels chocked (passenger and drivers sides). Can I also assume that you had already removed the "whale tail" from the bottom of the hitch? Bill F250, no Anderson WD. We use Andersen jack blocks (round ones) and the Andersen ramp levelers for side to side. This is the 3rd campground in a row we needed to level side to side and all 3 times the trailer jumped. John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Dave and Kimberly Posted April 19, 2024 Posted April 19, 2024 John Dorrer: The same thing happened to me once on my relatively flat driveway. It scared the bee-jeebies out of me for a moment. In my scenario there was a slight decline to the right of the Oliver. Afterwards I investigated and believe that the problem was the way I placed the chocks. I placed the chocks behind each of the Olivers back wheels. Then as the tongue came up and off of my truck there was nothing to keep the Ollie wheels from coming forward. The tongue came up and then moved about 10" suddenly to the right (towards the Ollie's right). I believe that my Oliver "pivoted" on the right rear chock and because there wasn't anything on the left side to keep it from going forward.... it did. Since then, I have put my 4 chocks front and back on each side. It keeps both sides of the Oliver planted in place. I also think that because I was on my concrete driveway...and maybe the hard plastic chocks didn't "grip" on my concrete well ... it was a scenario that allowed the Oliver to move even quicker than it might have on a gravel camp-site. 2 5 2022 Elite II, Hull #1097 Elli Rose 🌹 and she has the solar panels with the 390Ah lithium batteries. Our tow vehicle is a 2025 Ford Lariat F-250 Super Duty 4wd, 6.7L Diesel with the Max tow package. Elli Rose also has the street side awning and several walnut and cherry mods on the inside.
Dennis and Melissa Posted April 19, 2024 Posted April 19, 2024 2 hours ago, John Dorrer said: When the bulldog came off the ball, the trailer lerched sideways close to 1-1/2' and back a foot What stopped it from going even farther? I'm not trying to be snarky. Whatever stopped it might expose what was "missing" when you decoupled. 1 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
rideandfly Posted April 19, 2024 Posted April 19, 2024 We camp on many campsites that are not level. Always put the level blocks under wheels on low side leveling Ollie (we use Camco Level Blocks) and chock the wheels on the opposite side. Then before jacking Ollie's hitch off of the ball, place the tow vehicle in neutral letting the trailer settle on the level blocks and chocks, next place TV in park and jack hitch off of ball without much movement. 7 Bill 2015 LE2 2024 F-350 6.8L
Moderators topgun2 Posted April 19, 2024 Moderators Posted April 19, 2024 36 minutes ago, John Dorrer said: We use Andersen jack blocks (round ones) and the Andersen ramp levelers for side to side. OK - let's see if we can narrow this down a bit. The "jack blocks" generally will not have anything to do with the trailer moving in the manner you describe. If blocks are not placed flat on the ground (i.e. they are on edge) then some slight movement could occur. But, with the Andersens shape and size this would be very rare if even possible. The Andersen "ramp levelers" are another story though. Obviously, even on flat ground, the curved shape of the Andersen levelers will cause those levelers to move unless the chock part of the system in put firmly in place. I also use the Andersen levelers and early on I started carrying a rubber mallet and use that to give those red chocks a tap to make sure that they are firmly set. I also use this mallet to set the regular chocks on the opposite side of the Ollie. This is not only safer, but it is much easier on the hands or feet that I used to use to try to firmly set the chocks. Finally, Rideandfly's recommendation of letting the Ollie "settle" with the TV in neutral is a good one. Bill 1 4 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Dennis and Melissa Posted April 19, 2024 Posted April 19, 2024 8 minutes ago, rideandfly said: place the tow vehicle in neutral letting the trailer settle always 2 1 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
Wandering Sagebrush Posted April 19, 2024 Posted April 19, 2024 13 minutes ago, rideandfly said: We camp on many campsites that are not level. Always put the level blocks under wheels on low side leveling Ollie (we use Camco Level Blocks) and chock the wheels on the opposite side. Then before jacking Ollie's hitch off of the ball, place the tow vehicle in neutral letting the trailer settle on the level blocks and chocks, next place TV in park and jack hitch off of ball without much movement. Important point! 1 2 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
John Dorrer Posted April 19, 2024 Author Posted April 19, 2024 38 minutes ago, topgun2 said: OK - let's see if we can narrow this down a bit. The "jack blocks" generally will not have anything to do with the trailer moving in the manner you describe. If blocks are not placed flat on the ground (i.e. they are on edge) then some slight movement could occur. But, with the Andersens shape and size this would be very rare if even possible. The Andersen "ramp levelers" are another story though. Obviously, even on flat ground, the curved shape of the Andersen levelers will cause those levelers to move unless the chock part of the system in put firmly in place. I also use the Andersen levelers and early on I started carrying a rubber mallet and use that to give those red chocks a tap to make sure that they are firmly set. I also use this mallet to set the regular chocks on the opposite side of the Ollie. This is not only safer, but it is much easier on the hands or feet that I used to use to try to firmly set the chocks. Finally, Rideandfly's recommendation of letting the Ollie "settle" with the TV in neutral is a good one. Bill You hit the nail on the head. My wife placed the plastic wedges on the wrong side of the Andersen Levelers. That was just a few of the errors that were made. Next time we will bring our "X" chocks We will also grease the ball. After watching several YouTube videos, I believe that might be a good reason the bulldog doesn't come off the ball smoothly. John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
John Dorrer Posted April 19, 2024 Author Posted April 19, 2024 (edited) 57 minutes ago, Dennis and Melissa said: What stopped it from going even farther? I'm not trying to be snarky. Whatever stopped it might expose what was "missing" when you decoupled. Didn't have enough chocks and my wife didn't place the Andersen ramp leveler wedges in the correct place. It was a cluster of han error. I will also start greasing the ball. Watched a bunch of YouTube videos. I think this was a case of big time owner error🙃 Edited April 19, 2024 by John Dorrer John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Rivernerd Posted April 19, 2024 Posted April 19, 2024 3 hours ago, John Dorrer said: set chocks and raised the tongue. 3 hours ago, John Dorrer said: When the bulldog came off the ball, the trailer lerched sideways close to 1-1/2' and back a foot, with the front jack block sliding and the front jack almost coming off the block. Been there, done that, "got the T-shirt." I learned that my ability to accurately determine which way the campsite slopes is limited. So, I the started carrying chocks for both the front and back of each set of wheels. Before disconnecting the coupler, I ensure that the wheels are chocked both front and back, and rubber-hammered into place. So far, this has prevented unwanted movement. 6 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
routlaw Posted April 19, 2024 Posted April 19, 2024 Lot of good points made here, have not thought of putting TV in neutral to let it settle but on more than one occasion have discovered there is a tension between TV and Oliver based upon how the last movements went, usually from backing up with a significant turn. What I always do now is take the tension away from the two by pulling forward usually a few inches or a foot max will do while straightening the TV front wheels. Some ground can be difficult to read the slope certainly and in this case front and back chocks work well. Like a few of you I have always taken a big rubber mallet and pound the crap out of those things so they are in tight both for rubber chocks as well as the Anderson leveling blocks. As for the X Chocks the company warns they are not meant to hold the camper in place, only to stabilize it once setup claiming the device is not strong enough to hold most campers steady. That said I have no doubt a lot of people use them in this manner. Good luck in the future 1 3 Legacy Elite II #70
Moderators SeaDawg Posted April 19, 2024 Moderators Posted April 19, 2024 Chasing an unchocked, or improperly chocked trailer, can be very scary. Did that one time, dramatically. (Someone else's trailer, about to run backwards down a slight slope, through bushes, to a ten foot drop.) Fortunately, a lightweight, small trailer, and three of us from neighboring sites got it stopped. Good chocks, well placed, follow instructions above. No issues. 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
DavePhelps Posted April 20, 2024 Posted April 20, 2024 One last tip that I could add is that I always leave my safety chains (or cables if you have those) attached until the very end of setting up. After a long drive, potential bad weather, and road weariness has set in, things can go sideways in a hurry! Lots of great tips above. Never put my van in neutral before but will start doing that. And always chock both sides of your wheels.👍 Dave 4 2015 Oliver Elite 1, Hull 107 2025 GMC Sierra HD 2500 AT4, 6.6 L8T (gas)
Geronimo John Posted April 20, 2024 Posted April 20, 2024 4 hours ago, Dave and Kimberly said: Since then, I have put my 4 chocks front and back on each side. For sure us too! ++++++++++++++++++++ 2 hours ago, John Dorrer said: We will also grease the ball. After watching several YouTube videos, I believe that might be a good reason the bulldog doesn't come off the ball smoothly. If I am reading that grease inhibits movement, that would not be the case. For the Bulldog and the Anderson ball, I give both a short spritz from some white lithium grease aerosol. When I get to the next stop, I wipe out the Bulldog and wipe off the Anderson ball. The first is to help keep the Bulldog clean. The latter is to help keep my jeans or leg clean. +++++++++++++++++++ One more safety must when on any slope of a camp site: PLEASE remember to have your TV in Park and Parking Brake Set, and most importantly always keep at least one of your safety chains attached until AFTER you have unhooked and leveled her. If you have any problem at all, she will not be going far. GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted April 20, 2024 Posted April 20, 2024 (edited) 12 hours ago, John Dorrer said: We will also grease the ball. 9 hours ago, Geronimo John said: The latter is to help keep my jeans or leg clean. I found this product a few year ago and really like it, been using their dielectric grease for 7 or 8 years, as well. It took a couple trips to work all of the old grease off of the Bulldog after initially wiping clean with paper towels, perhaps a thorough cleaning with a solvent would have been a better approach. Most of all, since it is clear/opaque there is no soiling of self or clothes. I also use a hitch ball cover when unhooked to help keep the ball free of dust and debris, as well as a clean hand when handling the hitch. Edited April 20, 2024 by Ronbrink 1 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Cameron Posted April 20, 2024 Posted April 20, 2024 I share everyone's thoughts on this. I also have learned the hard way (just minor scares, no damage) about chocking front and back of both sides, as well as putting the TV into neutral and letting it settle into those chocks. It's really more of an issue boondocking than when on a nice flat campground gravel/concrete/asphalt spot. Also, I almost always pull out my hitch ball and place it somewhere safe after setting up camp. I've got one of those funky GMC tailgates that can dent if dropped down on the ball. 2 2021 Elite II #841, 2020 GMC Sierra 1500 AT4, 3.0 diesel
Dennis and Melissa Posted April 21, 2024 Posted April 21, 2024 I fell asleep last night trying to analyze this using my "simple machines" physics from 50 years ago. 🙂 I think that goes like this.... Instead of an Ollie, we have a sled with 4 wheels that spin and roll frictionlessly across a plane. If that plane is inclined, the sled will always roll down hill. To keep it from rolling, put chocks (another inclined plane going the other way) on the downhill side of the wheels. If held motionless, there will be force on those chocks equal to the force pushing the sled down the hill (sine of the angle of incline IIRC??? , doesn't really matter). It's clear from this picture, the bigger the incline, the bigger the chock needed. (IOW, a little chock will just get run over before creating enough back pressure.) It's also clear that, if you put a big enough chock on the downhill side, and drag the cart "up" it, eventually the cart will "roll backwards" when released. So, how do you know when you are in the sweet spot? How do you know if you let go of the cart, it won't roll? How do you know if you have 0 tension on the hitch? Honestly, I don't have an answer for this. Unless there is some way to actually measure pressure at the ball. It leads me to conclude that I have been getting really lucky, and that I don't live on a frictionless plane. So far, friction has made my guesses "good enough". Henceforward, I'm vowing to chock all 4 tires, front and back, before unhitching. I'm even considering the advice to leave the chains on. 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
MAX Burner Posted April 21, 2024 Posted April 21, 2024 In "Love/Hate" category of wheel chocks is where "X-Chocks" fall... We use them exclusively on fairly flat surfaces, and augment them with Anderson "double-chocks" where the terrain is stepper, uneven, and OTT needs leveling. Just a suggestion, but it works for us... There's nothing wrong with leaving the chains connected in these conditions, we've been there/done that, too! Cheers! 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
John Dorrer Posted April 21, 2024 Author Posted April 21, 2024 57 minutes ago, MAX Burner said: In "Love/Hate" category of wheel chocks is where "X-Chocks" fall... We use them exclusively on fairly flat surfaces, and augment them with Anderson "double-chocks" where the terrain is stepper, uneven, and OTT needs leveling. Just a suggestion, but it works for us... There's nothing wrong with leaving the chains connected in these conditions, we've been there/done that, too! Cheers! We use the Andersen levelers. I had kinda the perfect storm of owner error. I should have backed up onto them with the thicker end to the back. John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Moderator+ ScubaRx Posted April 22, 2024 Moderator+ Posted April 22, 2024 (edited) @John Dorrer posted this on FB this past Friday and I responded to it soon afterward. My advice to everyone...buy yourself four real chocks. After parking, put one behind each rear tire and one in front of each front tire OR on both sides of the single axle tires. Kick them hard into place, up snugly against the tires. DO NOT ever place them only on one side. Raise the hitch off the ball BEFORE unhooking the safety chains. Unless you've accidentally parked on a sixty degree slope, the trailer should not move at all. Finish unhooking trailer and move the tow vehicle. Level front to rear with the 3000 pound capacity front jack. After placing at least six inches of blocking under each, level side to side with either of the 3000 pound capacity rear jacks. Your trailer will not move with these chocks. Yeah, I know they're from HF and they spell like a tire factory, but they're inexpensive, they work and I challenge you to be able to make that trailer move with these chocks properly set. Don't believe me? Try driving off after forgetting to remove them. I do not care for the Andersen Levelers. They're too expensive for what they do, they're useless (and never intended to be used) as chocks and they will skid around on concrete. Edited April 22, 2024 by ScubaRx 5 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Boudicca908 Posted April 22, 2024 Posted April 22, 2024 6 hours ago, ScubaRx said: they will skid around on concrete. .... and on gravel, as I experienced 2 days ago! Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
rideandfly Posted April 22, 2024 Posted April 22, 2024 (edited) Comparison of Anderson and Beech Lane Leveling systems: The majority of our camping is in Federal and State Parks. We use the Camco leveling chock system, should not have said blocks earlier, for raising the Ollie's low side with rubber mats underneath to prevent slipping, Then chock the high side. When we purchased the leveling system, read reviews about slippage on hard surfaces like concrete and asphalt, so started using rubber mats underneath. The Camco Leveling Chock system we use, photo taken several years ago when we still had BF Goodrich LT tires mounted on Ollie: Edited April 22, 2024 by rideandfly 1 Bill 2015 LE2 2024 F-350 6.8L
Rivernerd Posted April 22, 2024 Posted April 22, 2024 8 hours ago, ScubaRx said: I do not care for the Andersen Levelers. They're too expensive for what they do, they're useless (and never intended to be used) as chocks and they will skid around on concrete. Which is why we use Rophor levelers. They are similar to the Andersens, but include rubber grip strips that are placed on the ground underneath the levelers. After installing one or both of these levelers, as needed to level the trailer, we also hammer in Harbor Freight chocks. https://www.amazon.com/gp/product/B09NJSXRRB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 2 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
