Ray and Susan Huff Posted February 25, 2021 Posted February 25, 2021 The biggest "con" we have found in our Elite II is that it is difficult to fully drain the waste tanks. Aside from jacking up the front of the trailer, are there any other tips for getting the black/grey tanks truly empty? Some dump stations have a ramp to facilitate gravity dumping, but most we have found do not. Our previous RV had a sewer macerator that pumped the tanks out rather than relying on gravity, so we didn't have to worry about how the RV was situated when dumping. I wonder if Oliver has considered a macerator as a solution to this problem. Is there any reason a pump wouldn't work in an Ollie? Has anyone investigated this as a possible mod? Could it be installed inside the rear bumper? I believe most boats use a pump system for emptying tanks, but probably the pump is on the dockside, rather than on board. Ray and Susan Huff Elite II Twin "Pearl" - Hull#699; delivered December 7, 2020 2013 F350 6.7l diesel Super Duty 4x4 long bed crew cab 1UP-USA Heavy-duty bike rack 2017 Leisure Travel Van Unity Twin Bed (sold)
Moderators SeaDawg Posted February 25, 2021 Moderators Posted February 25, 2021 We had a macerator. Actually, two. And Paul rebuilt the first one, once or twice. They're great, til they're not. But, easy for us to add on, if you want one. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators Mike and Carol Posted February 25, 2021 Moderators Posted February 25, 2021 1 hour ago, Ray and Susan Huff said: The biggest "con" we have found in our Elite II is that it is difficult to fully drain the waste tanks. Aside from jacking up the front of the trailer, are there any other tips for getting the black/grey tanks truly empty? Some dump stations have a ramp to facilitate gravity dumping, but most we have found do not. Our previous RV had a sewer macerator that pumped the tanks out rather than relying on gravity, so we didn't have to worry about how the RV was situated when dumping. I wonder if Oliver has considered a macerator as a solution to this problem. Is there any reason a pump wouldn't work in an Ollie? Has anyone investigated this as a possible mod? Could it be installed inside the rear bumper? I believe most boats use a pump system for emptying tanks, but probably the pump is on the dockside, rather than on board. Are you saying that the inside display is always showing a percentage in the tanks and does not read zero? They gray tank does drain slow, but ours does get to zero. The black is fast and easy, dump, fill/dump, fill/dump and the dump water is clear and the gauge reads zero. Elevating the front a bit does help. Have you checked the operation of your gates? Maybe they aren’t opening all the way? 1 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
BlueHighways Posted February 25, 2021 Posted February 25, 2021 I think raising the front is a must; not excessively but just a bit higher. Then, second most important item for us is a clear elbow in the line so we can do the dump/flush/dump sequence until the water is clear. For daily treatment, we use some calgon and borax in the tanks. Finally, it does take patience to make sure everything is drained. After the first couple of times, we have had no issues David and Vicky | Burns, TN | 2020 LEII #686 (RIP!)| 2024 LEII #1550 | 2017 Ford F-250 4x4 6.2L
Ray and Susan Huff Posted February 25, 2021 Author Posted February 25, 2021 2 hours ago, Mike and Carol said: Are you saying that the inside display is always showing a percentage in the tanks and does not read zero? They gray tank does drain slow, but ours does get to zero. The black is fast and easy, dump, fill/dump, fill/dump and the dump water is clear and the gauge reads zero. Elevating the front a bit does help. Have you checked the operation of your gates? Maybe they aren’t opening all the way? How does one check if the dump valves are opening all the way? The grey display is usually around 15%. Maybe we aren't patient enough. Do you empty the black then the grey? Ray and Susan Huff Elite II Twin "Pearl" - Hull#699; delivered December 7, 2020 2013 F350 6.7l diesel Super Duty 4x4 long bed crew cab 1UP-USA Heavy-duty bike rack 2017 Leisure Travel Van Unity Twin Bed (sold)
Moderator+ ScubaRx Posted February 25, 2021 Moderator+ Posted February 25, 2021 Empty the black tank first, then the gray. This will allow the gray water to somewhat clean the hose after the black water has gone through it. 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Patriot Posted February 25, 2021 Posted February 25, 2021 (edited) We have not had any issues with emptying either of the tanks. As others have mentioned Ollie nose up and always black first and then gray for the soapy rinse. I don’t see a problem and really like the simplicity of the tank discharge design. Edited February 25, 2021 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Mcb Posted February 25, 2021 Posted February 25, 2021 I’m not sure the sensors on the tanks are all that accurate.. or consistent for that matter. Usually our gray tank will get to zero, but sometimes it reads 6%... even though it’s empty. Next time yours is “stuck” on 15%, raise the front of the camper.. see if more water comes out.. if not, 15% is actually zero. Try lowering the front end as well.. as counter intuitive as that may sound, it may help “burp” the system.... 3 Mark & Deb..2020 Elite II..Dearie..Hull #685..2016 Tundra
Moderators Mike and Carol Posted February 25, 2021 Moderators Posted February 25, 2021 9 hours ago, Ray and Susan Huff said: How does one check if the dump valves are opening all the way? The grey display is usually around 15%. Maybe we aren't patient enough. Do you empty the black then the grey? Check under the dinette seat closest to the bathroom for the black valve. The gray is under the bed near the pantry. Just watch the gate when it is opened to see if it fully opens. Yes, we always dump the black before the gray. I do a couple of rinses until I get clear water flowing out. Then do the gray. While the gray is draining I’m unhooking the black flush hose and putting things away. We usually get down to zero in both tanks. 1 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Frank C Posted February 25, 2021 Posted February 25, 2021 (edited) I always consider the digital readout for the tank levels to be more of a suggestion than an absolute value. The gray and fresh water tanks are very long and flat, so any slight out-of-level with the trailer, front to back or side to side, will change the reading a lot, since the sensor is mounted in one corner of the tank. And the sensors are affected by water hardness, soap residue, toilet paper debris, and in the case of the black tank, other "nasty stuff" that can affect the sensor and cause it to read inaccurately. Follow the above recommendations of raising the tongue of the trailer a bit, empty the black tank first, then the gray. And it helps if you install a clear elbow or connector section on drain hose so you can see when the flow stops. I added these between each section of the drain hose. Camco Sewer Hose Adapter - Attaches to RV Outlet Connection , Extends connection for Easier Hookup- Transparent Adapter Allows You to View When Tank is Cleared - 3.5" (39562) https://www.amazon.com/dp/B016V2JMBS/ref=cm_sw_r_cp_api_glt_fabc_NNAP7JSFTAYMD3C1KDVR?_encoding=UTF8&psc=1 Edited February 25, 2021 by FrankC 1 1
Moderators topgun2 Posted February 25, 2021 Moderators Posted February 25, 2021 Ray & Susan - A quick use of the search function produced THIS THREAD on macerators in Olivers. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
John E Davies Posted February 25, 2021 Posted February 25, 2021 (edited) 2 hours ago, FrankC said: And the sensors are affected by water hardness, soap residue, toilet paper debris, and in the case of the black tank, other "nasty stuff" that can coat the sensor and cause it to read inaccurately. The Ollie sensors are not internal. They can possibly be affected by gunk inside, but the sensors themselves certainly do not have that issue. For those of you who still use the black tank, if you think your sensor is acting flaky, dump a bag of ice cubes, not crushed ice, down the toilet when the tank is half full, immediately before you start towing. They will crash around inside, loosing all the deposits so they will go out the drain the next time. If you use the tank flush feature, this should not be necessary, maybe, perhaps. Do any of you also use a hand flush wand, from the top of the tank? Yuck. ☹️ John Davies Spokane WA Edited February 25, 2021 by John E Davies SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Frank C Posted February 25, 2021 Posted February 25, 2021 (edited) 44 minutes ago, John E Davies said: The Ollie sensors are not internal. The can possibly be affected by gunk inside, but the sensors themselves certainly do not have that issue. Thanks for the clarification John. I should have read the manual more carefully. Yeah, the sensors scan through the wall of the tank. So they would only be affected by something clinging to the inside of the tank wall. The manual politely calls it "sludge" buildup on the tank wall that will affect the sensor reading. Edited February 25, 2021 by FrankC
Moderators topgun2 Posted February 25, 2021 Moderators Posted February 25, 2021 (edited) If you chose to use the "ice cubes in the black tank" for cleaning purposes, you should probably watch THIS VIDEO first. You can fast forward to about 5:14 where the results of the test and/or recommendations are made for how to get the best results. Bill edit - Here is another VIDEO that discusses another long term potential issue with the black tank and another possible solution. Edited February 25, 2021 by topgun2 2 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
dewdev Posted February 25, 2021 Posted February 25, 2021 Camco Sewer Hose Adapter - Attaches to RV Outlet Connection , Extends connection for Easier Hookup- Transparent Adapter Allows You to View When Tank is Cleared - 3.5" (39562) https://www.amazon.com/dp/B016V2JMBS/ref=cm_sw_r_cp_api_glt_fabc_NNAP7JSFTAYMD3C1KDVR?_encoding=UTF8&psc=1 I have seen in other forum threads a suggestion to have a elbow at the end of the hose at the dump site, whihc sounds like a great idea. Has anyone found a clear elbow similiar to the Camco Sewer Hose Adapter to use (noted above) so you only have one special fitting? 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Moderators Mike and Carol Posted February 25, 2021 Moderators Posted February 25, 2021 25 minutes ago, dewdev said: Camco Sewer Hose Adapter - Attaches to RV Outlet Connection , Extends connection for Easier Hookup- Transparent Adapter Allows You to View When Tank is Cleared - 3.5" (39562) https://www.amazon.com/dp/B016V2JMBS/ref=cm_sw_r_cp_api_glt_fabc_NNAP7JSFTAYMD3C1KDVR?_encoding=UTF8&psc=1 I have seen in other forum threads a suggestion to have a elbow at the end of the hose at the dump site, whihc sounds like a great idea. Has anyone found a clear elbow similiar to the Camco Sewer Hose Adapter to use (noted above) so you only have one special fitting? I have an extension like what is mentioned above. I find it takes too much space in the bumper area and since we never disconnect our hose from the trailer it doesn’t make sense for us. I do have a clear elbow that came with my Valterra hose that works well. I have a backup Rhinoflex hose that attaches to the Valterra, they seem to use the universal connections. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Patriot Posted February 25, 2021 Posted February 25, 2021 (edited) 2 hours ago, topgun2 said: If you chose to use the "ice cubes in the black tank" for cleaning purposes, you should probably watch THIS VIDEO first. You can fast forward to about 5:14 where the results of the test and/or recommendations are made for how to get the best results. Bill edit - Here is another VIDEO that discusses another long term potential issue with the black tank and another possible solution. I prefer shaken ice cubes in my tank...not stirred!! 🤣 Edited February 25, 2021 by Patriot 1 1 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Overland Posted February 25, 2021 Posted February 25, 2021 Patriot, if that's where you're making your martinis, I hope you don't mind if I skip your cocktail party at the next rally. 🤢 2 6 1
rideandfly Posted February 25, 2021 Posted February 25, 2021 Make 3 hours ago, Patriot said: I prefer shaken ice cubes in my tank...not stirred!! 🤣 Always try to pull in the direction to keep Ollie's nose highest at dump stations. The original double naught, Jethro Bodine on Beverly Hillbillys. https://www.imdb.com/title/tt0522464/ 1 Bill 2015 LE2 2024 F-350 6.8L
John E Davies Posted February 25, 2021 Posted February 25, 2021 3 hours ago, topgun2 said: If you chose to use the "ice cubes in the black tank" for cleaning purposes, you should probably watch THIS VIDEO first. You can fast forward to about 5:14 where the results of the test and/or recommendations are made for how to get the best results. LOL, I did not mention that you should wait long enough for everything to come back up to room temperature. On a hot day four hours would be enough. I kinda thought that was obvious. But maybe not..l.. John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Mattnan Posted February 27, 2021 Posted February 27, 2021 Rookie mistake and learning opportunity that hate to admit!!! The first time we dumped our tanks the gray tank reading was reading 15%. I was not too surprised having read this forum. So we jacked up the front of the trailer using the front jack. This got our reading to 0. We put away all of the hoses, removed my rubber gloves did a very quick, not very thorough walk around and got in the truck to leave. We even commented how smooth the whole process went!! The truck started forward and I heard terrible scrapping and grinding sound. Of course there were campers now behind us to use the dump station. I got out of the truck and we quickly realized I forgot to lower the Jack. We got some advice from other campers but the bottom line was the jack shaft was bent beyond repair. We ended up cutting the shaft off with a saw. My wife contacted the Jack manufacturer directly and they express shipped a new Jack to our next campground. Fortunately, I didn't damage the frame or fiberglass. The Jack arrived 2 days later. Removing the old jack and installing the new one was pretty straight forward. But the whole thing was embarrassing and a PIA. The trailer had to remain hooked up to the truck was installed so this did cost us some time site seeing in Savannah. The good news is I have the motor from the original Jack that has almost no use!!! I have a spare if needed.. So lesson learned!!!! I share this along with the embarrassment in hope this helps someone else avoid the same mistake. We were in a rural area and mobile techs get very slow and not in a hurry to help us out. Good idea to bring tools if you don't! Now if at a dump station I will live with a 15% full tank for travel and after unhooking at a full service site raise the trailer when we are unhooked!!!!! Dump away!!!! 2
Frank C Posted February 27, 2021 Posted February 27, 2021 Ouch! Sorry to hear about the jack accident. We all have, or will, make a mistake like that at some point. Glad you were able to get it repaired. I have a very lengthy printed checklist of things to do before departing a campsite, but every so often I get over-confident and think “oh, I can skip the printed checklist and do it from memory”. And when I do that I almost always forget at least one critical item. 2
BackofBeyond Posted February 27, 2021 Posted February 27, 2021 FWIW - I don't use the blank tank - composter - and it has always read 10%. One does need to consider front to back elevation when dumping - sometimes I have had to use the front jack to achieve the needed incline - though I am only dumping dirty H2O. I have adopted the - walk around EVERY time I stop visual check - just to make sure I haven't done something stupid and it is ok to proceed. Leaving the steps down - is a repeat offense. Closing the bathroom door comes in second. 52 minutes ago, Mattnan said: Rookie mistake and learning opportunity that hate to admit!!! We all make them - some more expensive than others. I am still looking for my tire monitor - the one I put away so I would not damage it or lose it while Ollie is in winter slumber!!!! RB 1 Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible"
Frank C Posted February 27, 2021 Posted February 27, 2021 (edited) Ditto on the steps down, and/or bathroom door not closed/latched mistakes. Edited February 27, 2021 by FrankC 1
Ray and Susan Huff Posted February 27, 2021 Author Posted February 27, 2021 1 hour ago, FrankC said: Ditto on the steps down, and/or bathroom door not closed/latched mistakes. And don't forget the grey tank valve in the bathroom . . . . if not closed (in), you will arrive at your next destination with a full shower pan. 1 Ray and Susan Huff Elite II Twin "Pearl" - Hull#699; delivered December 7, 2020 2013 F350 6.7l diesel Super Duty 4x4 long bed crew cab 1UP-USA Heavy-duty bike rack 2017 Leisure Travel Van Unity Twin Bed (sold)
