We all love our Ollie’s but….If you could change/add one thing on your Oliver what would it be?
I would love a window over the kitchen galley.
2021 Dodge Ram 1500
2021 Oliver Elite ll
Hull #732
Michigan
This has been discussed several times over the years.  I’d have a quieter AC and a larger black holding tank.  Mike
25 minutes ago, Mark Patricia said:
Bad knees  I would change the water hookup.
Quick connects help a lot when hooking up water….
Way to dump tanks when raining so that water running off roof doesn’t fall onto open outside basement door. Don’t want electric dump valves and don’t want to cut holes in basement door.
Bill and Martha
2019 Chevrolet 2500HD Duramax
A quieter AC is on my wishlist also!
2021 Dodge Ram 1500
Hull #732
Michigan
2 hours ago, Mainiac said:
I would move the fire extinguisher and put a small half in/half out waste basket.
Clever idea!
2021 Dodge Ram 1500
Hull #732
Michigan
Our previous camper had Dometic Seitz style windows you could open while raining.  They had built in shades, screen, and hinged window. Miss having that style of window.
  • Love 3
9 hours ago, Katjo said:
Clever idea!
Will probably happen. Just haven't figured out how to keep it stationary while going down the road. Think the solution will depend on when I find the right waste receptacle...
Love these windows! Would love to open the windows while it’s raining.
2021 Dodge Ram 1500
Hull #732
Michigan
1 Bigger black tank
 (There is only so much room... but I've always thought the grey and black tank combined capacity should be just a bit more than the fresh tank capacity... so you should run out of fresh about the same time your gray and black tanks  reach capacity)
2  a redesign of the sewer hose storage.   The stinky slinky hose storage is really awkward (especially with a bike rack in the way).
Oh wait... you said just one thing.
2022 Elite II, Hull #1097  Elli Rose 🌹 and she has the solar panels with the 390Ah lithium batteries.  Our tow vehicle is a 2025 Ford Lariat F-250 Super Duty 4wd, 6.7L Diesel with the Max tow package.  Elli Rose also has the street side awning and several walnut and cherry mods on the inside.
Never researched if they can be mounted in an Oliver,
Yep, we liked being able to open windows while it was raining.  Also liked having the ability to adjust shade and screen height together.
1 hour ago, Dave and Kimberly said:
1 Bigger black tank
Agree!!
2021 Dodge Ram 1500
Hull #732
Michigan
That's a tough one because fire extinguishers are supposed to be mounted by the exit. The idea is, you move to the exit to get the extinguisher and if the extinguisher doesn't work you now have the door behind you to escape.
Unless you are not able to reach either the extinguisher or the door. That is one reason for the emergency egress window in back, which is where I put my second fire extinguisher.
https://olivertraveltrailers.com/forums/topic/4291-how-to-element-fire-extinguisher-install/
BTW, has everyone actually opened and USED the rear window? Are you able to actually climb out and get around the spare tire and or bikes? I removed my fiberglass cover long ago for other reasons, but the rubber tread makes it much less problematic in scrambling over it and to the side.
Those of you who are mobility impaired and can’t climb out that way should definitely install a second extinguisher in back.
As improbable as it would be since it would require expensive mold changes, I would enjoy 80" twins instead of the 75".
2021 Elite II, Hull# 898
Such an important suggestion and one we are going to do today! We’ve not tried getting out our emergency exit, just haven’t gotten around to it and absolutely should/will!
2021 Dodge Ram 1500
Hull #732
Michigan
The Dometic S7 Flush Series is impressive:  Acrylic Frame, Awning Feature, Privacy/Screen, and the super bonus:  No Condensation!  These windows would be nice over the twin beds.  elsewhere less so (IMHO) as there are no sheets and bedding so placement of towels under the dining area is possible and in the bathroom not necessary to do so.
Here's another way to do the rear fire extinguisher thing:
One feature that would be nice is to separate the flush valves from the Basement hatch.  When on the road and boondocking, we like to do laundry at an RV Park and enjoy their showers and full hook up for charging the LiFePO4's.  I like to hook up the sewer hose and let the black tank run while at the bath house.  Current combined Basement/Dump valves hatch leaves our basement exposed to rain and theft.   Maybe someday Oliver will come up with  a OEM retro kit for us.  🙂
Top Gun:  I like your idea.  We tend wear ankle supporting (Paraglider Pilots) boots and removal for in and outs is time consuming.  That brings in some extra dirt. Without "hallway" runners, the seamless flooring makes my morning housekeeping a quick sweep out the entry.  For us, I would want to mount the extinguisher as you have, but a bit higher to facilitate sweeping.
It appears that you used Velcro to mount the extinguisher.  Did you modify the round extinguisher side, or is just a small strip of contact sufficient to KEEP the extinguisher in place when off paved roads?
Mahalo,  GJ
