Upgraded Shower and Bathroom Access Hatch
NCeagle
6 hours ago, Jps190 said:
So I just got the separate shower valves and a new shower head to do this mod. Can someone tell me what I am going to find when I take the towel rack/cubby out of the vanity.  I am assuming just 2 pex lines (hot and cold) with a valve going to a 1/2 inch NPT with supply lines to the faucet as pictured above. I am planning on adding a T to those vales and hopefully that will be it.  These will be the first big holes I have put in the fiberglass.  What is the preferred method for doing this.  I was going to use a hole saw on my drill.  Any other techniques or gotchas to be aware of.
This photo shows the stock LE2 bath plumbing that matches my 2017.  The red and blue PEX lines exiting the right side of the photo go to the faucet/shower fixture.  The blue PEX exiting the left side is the toilet supply as the text in the photo SNY SD UP posted indicates.
I covered the area to be drilled with blue masking tape.  Then I did my layout on the masking tape and then used a hole saw and drilled in reverse.  Worked pretty good with new drill bits.
Thanks for the info guys.  I measured the towel rack that is currently in the cutout and the outside dimensions are 19x13.  Did y'all have to enlarge that hole to install the hatch.  I assume everyone has used that 12x24 in hatch that was posted in another thread.
John and Kim
2021 Oliver Elite II.   Hull #887
On 12/30/2020 at 5:14 AM, NCeagle said:
After 18 months, how does the gelcoat look where the shower hose chafes? Do you think that a couple of small retainer clips would prevent that? Or else a quick detach coupling so you can store it away when not needed?
https://www.amazon.com/Disconnect-Adapter-Attachment-Bathtub-Bathroom/dp/B08HNHNWKT/ref=sr_1_10?crid=LHVFB0NA6J84&keywords=quick+release+coupler+for+handheld+shower+hose&qid=1656436063&sprefix=quick+release+coupler+for+hand+held+shower+hose%2Caps%2C235&sr=8-10
Thanks,
My Seaflo hatch was listed as 12x24".  My existing hole was wide enough but not tall enough. So I enlarged the hole with a multi tool.  I also used nuts and bolts to attach it.  The curve of the vanity face required careful tightening of the hatch.  I constantly checked the latch’s operation as I tightened the hardware.  The sides will have a little more gap than the top and bottom and that’s why I used the butyl tape, which has a little more body than silicone caulk.
I only have a few months and about 1500 miles with a hanging shower head, so for me it’s just an excuse to use another noodle.
  • Love 2
The hatch I used was 14" x 24" and fit perfectly width-wise as the inside cutout required was 13".  I also had to enlarge the height of the opening and removed a few inches from the bottom (protected area I was cutting with masking tape) just as @mossemidid.
States Visited Map
@John E Davies, I used plastic retainer clips for a while but the vhb tape on them didn't hold for very long on the shiny, waxed gelcoat.  I've also been using a noodle for about a year now!  I do want to put on some semi-permanent clips eventually - for looks, functionality and convenience.  I have to find some decent stainless clips and I'll try 3M 4000 adhesive/sealant.  Either way, "Secure the shower hose" has always been on our pre-departure checklist.  🙂
States Visited Map
Sure am glad about that - given the "camo green" color of the pool noodle I'm sure you could miss it.😁
  • Haha 4
Nicely done. As a side note, we are using what look to be the same plastic clips to hold our shower curtain in place while showering and I love those things!!
Nice upgrade in the bath, the four screws to remove the factory excess cover are really not that hard to do, plus the need to get in that area is not needed that much, but nice job.
trainman
Consider taping the gel coat surface in the area of cutting.
Charlie.
  • 1 year later...
IMG_7815.thumb.jpeg.6999d13d89491b8ed967c8f75a49848d.jpegFYI:  Our's came from Scandvik on Amazon:
1156354580_Screenshot2023-08-03at19_39_14.thumb.png.a0a1c33fcd9dd73f551bdc73ab5580bb.png
Edited by MAX Burner
added a photo....
  • 2022 TUNDRA w/Airlift Load Lifter 5000 kit
  • 2017 LE II; Hull #226 "Casablanca", 3x Battle Borns; Victron Cerbo S GX, Other Victron Stuff: SmartShunt, MPPT Solar Controller,  DC-DC Charger, 12VDC Starlink kit, and Alcan 5-pack Leaf Springs
You’re a star….thanks!😊
Truma water heater & AC
My valves are Shurflo brand (Trinidad style) the same manufacturer as our water pump. These are very similar to the Scandvik brand if not identical. I actually did not buy the valves because I had the Oliver folks do the modifications before we took delivery of our trailer in 2017. I would imagine that we could buy direct from the Shurflo folks. Also, we don’t leave the shower head hanging while traveling. We wrap the shower head in a towel and then lay it on the floor.
2017 Elite II, Hull #208
2019 Chevy HD 2500 Duramax
  • 2 months later...
On 12/30/2020 at 8:14 AM, NCeagle said:
And now with the same shower mixer as Mountainoliver...
Mountainoliver, the check's in the mail!  But... I don't know how to get anything delivered by the post office these days.  😉
So glad I didn't have to rip the caddy out again - sure made this addition easy!
Seadawg and Mountainoliver, I am following after your footsteps here first in installing the Marine hatch and second in replacing the shower system. I really like the design.  But I can not see the diverter in these pictures. I only see the hot and cold valves where the shower hose connects.  W/hat am I missing? Besides glasses.
I think/thought that the sink faucet and the shower faucet were on "separate supply lines" - therefore, no diverter is necessary.  Of course, there is a "shut-off" valve at the top of the shower head that can be seen in the photo for temporarily shutting off the water flow while taking "Navy" showers.  But, assuming that the additional faucets that are shown on the front of the bath vanity have been plumbed by tapping into the supply lines that supply the sink faucets then no diverter would be necessary.
  • 4 months later...
On 6/28/2022 at 7:49 PM, mossemi said:
@mossemi OR anyone else that has done this modification, do you have the name and model number of the hatch that you used?
Edited by Townesw
Bill and Martha
2018 LEII Hull 313
2019 Chevrolet 2500HD Duramax
It sort of looks like THIS one.
But, take a look at Mossemi's comments in his post above dated June 28, 2022.
We used the same one that @topgun2 refers to:
The "O-ring" keeps paper goods nice and dry inside when the wet-head is being used as a shower...
Here's a pic of our install/mod:
Cheers!
added a pic
Cheers!
This is great.  Just what I needed to motivate me to get er done.
ARILINIAKSKYLAMIMNMONMOHOKPASDTNTXVAmed.
