Each year, we watch end of year/black friday/ Christmas sales.
Last year, we snagged some great deals. Solar panels,, etc..
This year, I'm watching for very little. Packing cubes. Some storage containers.  We pretty much have all we need.
I'm watching for January white sales, early, as 14 year old trailer towels are getting aged. And, a new, small fry pan.
Lithium!.... Batteries that is.    LOL
“Mouse” is pretty well equipped for stuff, but I guess a clay bar and Rejex job for the outside, and maybe a couple of thirty minute mods…… I want to put in a power switch for the radio head to kill the panel lighting and parasitic draw, and grind off those nasty sharp corners on the inside bath door handle, I laid my head open on it a couple of months back and said a lot of nasty words as I bled copiously all over the floor.
I am watching for a sale on Element E50 extinguishers, but those are not for the trailer.
I am hoping that my son will 3D print a Land Cruiser 200 model for me, to match the Ollie model he made last year. If that happens I will update that thread with more pics….
  • Sad 1
Our Ollie is going to be bummed out this year considering the attention she got last year for her very first Christmas!
This year she's getting a good bath, clay bar and two coats Meguiar's premium marine wax.  Under the tree she'll find 3 cutoff valves (one for each of the lines leading to the outdoor shower and one for the fresh water intake line), some fuse labels as well as Timken bearing sets and seals.
We're also going camping in December before Christmas, so she is getting a new red carpet runner and some Christmas pillows and lights to get us into the holiday spirit!
  • Like 7
States Visited Map
Ollie will be getting a second coat of Meguiar’s flagship wax and  a small rechargeable  vacuum any recommendations?
John & Chris Dehne Manchester, MD.  2021 Elite II twin Hull# 901
“Fiberbeergrass” 2021 Ram 2500 Cummins 4x4  Life is good!
https://www.amazon.com/gp/aw/d/B00IOEFBKS?psc=1&ref=ppx_pop_mob_b_asin_title
Though I admit to rarely using it, mostly I just grab the broom.
https://www.amazon.com/gp/aw/d/B01ASYZSVI/ref=ya_aw_od_pi?ie=UTF8&psc=1
It collapses and tucks away neatly in the closet using a single Command tool holder.
I got a Ryobi handheld only because it uses the same lithium battery as my drill and other shop tools.  However, I understand that Black & Decker makes a popular one.
Ours got a wash & wax and a new Calmark cover aka - winter blanket! 😊
  • Like 7
North Carolina 🇺🇸
We're getting our OLLIE for Christmas!  😀
And all the accessories.....
mb
MaryBeth
Boulder, CO
2022 Elite II #953
I bought a small black and decker years ago. Not the foldable, more powerful model. Don't buy the cheaper one, like I did. Pretty much useless .
I've heard the ryobi is good. I now  carry a Dyson, that I also use at home. Love it.
On 11/19/2021 at 7:06 PM, Mountainman198 said:
She is getting a tow to warmer climates
Same for our Ollie.  Beacon will spend Christmas in Florida.
Why is there no emoji choice for - "I'm jealous"?
🤢 I always thought this emoji represented envy and every time I felt envious, maybe it was really jealousy.
A VIAIR air compressor...
Thankful for the TPMS.
And for Progressive Roadside Assistance.
Chris
Chris & Duke Chadwell
🐾Maddie & Baxter🐾
Elite II Hull 292
Chris
There has to be a good story behind that, can you tell us? Are you trying to reseat the bead? Is that the “hair spray and a match” trick?
Uneventful story. About 30 minutes after leaving Oliver Service, TPMS alarmed that my back left tire had a slow leak so I turned around & went back to the Oliver campground. That was the wonderful roadside assistance man from Libby's Auto & Diesel Towing who, instead of simply swapping out bad tire with spare (which is what he is supposed to do per contract with Progressive) fixed my valve stem in the freezing rain so that I would not have to continue my journey without a spare.
So thankful!
Chris
  • Care 1
🐾Maddie & Baxter🐾
Elite II Hull 292
So thankful!
Chris
What a nice guy. That doesn't happen,  everywhere.
My Ollie got the Dexter EZ Flex suspension installed.  While I was doing the install I decided to change out all the wheel bearings and seals to Timken roller bearings.  The original bearings had “Made in China” on them and I simply could not rest well knowing that.  There is just over 20k miles on the Ollie so it was probably a good time to change them out anyway.
While the brake drums were off I did a complete inspection of the Nev R Adjust brakes.  I was not pleased at all with what I found and decided to pull the brakes completely apart, clean them thoroughly, re-lube all the contact pads and actuators.  The drums looked great and showed very little wear.  The brake pads have less than half the pad wear of a new brake shoe……so they went back in.
Two of the wheels had a brake drag I was not pleased with and when I inspected the brakes I was very disappointed in the action of the Nev R Adjust system.  They all appear to move much better now that the system has been cleaned and lubricated as it should be.  I was very surprised that the backing plates had no lube on them at all at the brake shoe contact points.  We will see how they now work and adjust; if not working well, I will change out the backing plates to the regular manual adjust system.  Not very impressed with the Nev R Adjust system as it just does not appear to be a very robust adjuster/brake system.
I did add a new tool to my collection.  It is a Milwaukee 2 speed electric grease gun.  The battery is the same 18 volt I use on some of my other tools so this was an easy choice to make lube much easier.  The EZ Flex has 8 zerks on each side and even with the angled zerks installed it still is somewhat of a pain to lube.  I must mention that the electric grease gun will also make it much easier to lube my Kubota tractor and my Kubota zero turn mower as well.
Tools Plus had the Milwaukee grease gun on a BlackFriday sale for $139, so that helped in making my decision.  Lowest price around before the sale was $199, so this was a great buy.  It even includes free shipping.
Milwaukee 2646-20 M18 18-Volt Li-Ion Cordless 2-Speed Grease Gun (Tool-Only)
Steve
2015 Oliver Elite 2
Hull #106
2019 Ford F-250 Super Duty, 6.7 diesel
My story is very similar to Steve's about the nev r adjust brake system.  Very disappointed in its performance.  It overadjusted the two rear brakes causing brake overheats due to dragging brake shoes with inadequate running clearance.  We are getting all new brake system components with manual adjustment capability, not automatic.  We have just a little over 11,000 miles on our trailer, pretty expensive lesson about the auto adjust system.  My recommendation is if you have the nev r adjust system, check your brake temps for approximately equal temps after stopping periodically.  If you have a mix of temperatures to the touch, you may be developing running clearance issues.
George and Gretchen
Gig Harbor, Wa.
Hull Number 178
  • 1 year later...
Well, it's temporarily back to the weak little black and decker. The Dyson died after just less than 4 years. (And, I'd had to replace the batteries once. Yes, I cleaned and replaced filters on a regular basis.)
I did used the Dyson almost every day for 4 years, but I expected more life from an expensive gadget.
I got a shark for home, but it's too big and heavy to carry in the trailer. I'll be looking for a new, smaller lightweight something else for the Ollie.
