dewdev Posted January 19, 2022 Share Posted January 19, 2022 It would be nice to have some reliable way to measure the amount of propane in the Ollie propane tanks. (another new toy). I believe I have seen this topic on the forum in the past, but could not find it when I did a search. My present procedure is to put hot water on the side of the tank and look at where the frost forms on the side of the tank to indicate where the propane level is in the tank. Short of that my general procedure is when one tank is empty switching to the other tank and getting the empty one filled. For longer camping trips, I like to start with 2 full tanks, but am sick of taking the active LP tank to be filled when it is only half empty. I would like to have a more scientific system with some type of device to actually measure the liquid level without having to cut in gauges in the feed lines. I could then easily monitor the amount of LP being used each day and project when to get the tank filled. One device I have found onlline is the "AP Products 024-1001 Propane Tank Gas Level Indicator" which connects via a magnetic to the bottom of the tank with the level reading shown on your smart phone. The reviews of this device are mixed with some saying they are great and others say the device works at first then after awhile the sendor does not work. What does Ollie owners do or have bought to reliabily measure LP liquid in your LP tanks? 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio Maine Link to comment Share on other sites More sharing options...
Moderators mossemi Posted January 19, 2022 Moderators Share Posted January 19, 2022 I like the Truma LevelCheck. Link to YouTube video. Mossey 1 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
Corvus Posted January 19, 2022 Share Posted January 19, 2022 I like the Mopeka sensors. You can get readings on a mobile device or a unit they sell to install inside the trailer. 2 Jerry & Kathy 2019 LEII Standard #539 + 2019 Tundra Limited 4X4 Link to comment Share on other sites More sharing options...
AndrewK Posted January 20, 2022 Share Posted January 20, 2022 I have used the Mopeka Tank Check for almost three years now. It is not perfect, but I do like it and it does give me fairly accurate readings. The two negatives for me are: - Around or below freezing, it registers lower than the actual amount in the tank. - The batteries need to be changed too frequently. About every 6 and 9 months. I did have a problem with one of my original sensors and contacted Mopeka. They immediately sent me two new sensors and said they were an improved version. No problems since. I would definitely purchase the Tank Check again. Andrew 3 Andrew 2019 Legacy Elite II 2018 BMW x5 35d Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted January 21, 2022 Moderator+ Share Posted January 21, 2022 I've had no problems with my Mopeka system for the past three years or so. I do not like using my phone as a monitor for anything. I bought the wireless display and mounted it inside the trailer. I have to change the batteries at least once a year. 2 Steve, Tali and our dog Rocky plus our beloved Storm, Maggie, Lucy and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
John E Davies Posted January 21, 2022 Share Posted January 21, 2022 2 hours ago, ScubaRx said: I do not like using my phone as a monitor for anything. I haven't installed my system yet, but will soon, I like the app option. Rather than using my iPhone, I will use the iPad Mini 2 that I installed in place of the Zamp solar controller. I can view two apps simultaneously, for example Garmin Earthmate (to send text messages through my inReach communicator) and the Victron Connect battery monitor app. . I will post a new thread about the Mopeka sensors, eventually. John Davies Spokane WA 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Trainman Posted January 21, 2022 Share Posted January 21, 2022 Would someone answer the question for me, if the regulator valve is turned down and not turned to the right, or left does it draw from both tanks at the same time. trainman 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold. Link to comment Share on other sites More sharing options...
Ronbrink Posted January 21, 2022 Share Posted January 21, 2022 I’ve been using a similar device to the one Mossey featured above, but made by Dometic. It is easy to use and provides an accurate assessment of the tank levels. Regardless of the brand, each seem to be comparable in function and pricing. 2 2020 OLEll, Twin, 579 2012 Silverado 1500 4x4 No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, Hughes Autoformer, dual Lagun tables Link to comment Share on other sites More sharing options...
Mountainman198 Posted January 21, 2022 Share Posted January 21, 2022 I just use my hand to sense the temp difference between gas and liquid. Hasnt let me down yet. Also have a ir light temp guage which I would think would work too. 2 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW Link to comment Share on other sites More sharing options...
Moderators mossemi Posted January 21, 2022 Moderators Share Posted January 21, 2022 1 hour ago, Trainman said: Would someone answer the question for me, if the regulator valve is turned down and not turned to the right, or left does it draw from both tanks at the same time. trainman Never have tried the neutral position because the Fairview instructions do not mention that setting. Mossey Fairview LP Gas Regulator.pdf 2 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
John E Davies Posted January 21, 2022 Share Posted January 21, 2022 Entered in error. John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
bhncb Posted January 21, 2022 Share Posted January 21, 2022 At initial hook up, whichever regulator input is pressurized first becomes the "active" side. Then, when the selector is moved to the center (auto) position, the other input becomes the "reserve" side. When pressure on the active side tank drops to a predetermined level, the auto changeover valve will switch to the reserve side tank. Whenever one of the tanks is removed for refilling, the selector should first be moved from auto to the tank that will remain in use. After the refilled tank is put back in service, it will become the reserve once the selector lever is moved back to the auto position. 1 2 Link to comment Share on other sites More sharing options...
Trainman Posted January 21, 2022 Share Posted January 21, 2022 Thanks bhnch for the great explanation, I am now going to go out a check my bottles to see how much is in each one and set my valve to the lower bottle for first use. One quick question, do I turn on the reserve bottle before moving the selector to the center position, or after I move it to the center position for auto setup. Thanks trainman 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold. Link to comment Share on other sites More sharing options...
Steph and Dud B Posted January 21, 2022 Share Posted January 21, 2022 4 hours ago, bhncb said: At initial hook up, whichever regulator input is pressurized first becomes the "active" side. Then, when the selector is moved to the center (auto) position, the other input becomes the "reserve" side. That doesn't sound right to me, at least with a Fairview. We have the same regulator on our fifth wheel. Point the lever at the tank you want to use first. When it's empty, the red indicator will show and the regulator will switch to the other tank. Before disconnecting the empty tank, turn the lever to the other tank, which now becomes the primary. There is no center position for the lever. The pdf in Mossey's post says the same thing. 2 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999: Link to comment Share on other sites More sharing options...
bhncb Posted January 21, 2022 Share Posted January 21, 2022 1 hour ago, Trainman said: do I turn on the reserve bottle before moving the selector to the center position First, I stand corrected. The Fairview regulators operate as described, which may explain why the BTU capacity is reduced once an auto changeover occurs and why the lever must be pointed toward the active tank before the opposite one can be disconnected. If the lever has to be manually switched to regain full BTU capability, and shut off backflow to the other port, it seems to me the Fairview regulator is more semi-automatic in operation. The BTU reduction could explain some of the reported propane delivery problems at low temperature and/or high altitude. I routinely experience both and never had a problem prior to replacing my original Fairview. But then, I generally start looking for a refill before an auto changeover happens. It's somewhat moot now but in response to Trainman's question: Generally the lever would be moved after the reserve tank is opened. The sequence may not matter but the regulator relies on pressure differential in determining when to switchover. A sudden surge from opening the tank valve may fool it, causing an unnecessary and undesirable switchover. 4 Link to comment Share on other sites More sharing options...
Ralph Mawyer Posted January 21, 2022 Share Posted January 21, 2022 (edited) Anyone using the Pro vs Standard version mopeka.com/product-category/sensor/ https://mopeka.com/product-category/sensor/ Edited January 21, 2022 by topgun2 added direct link 2020 Legacy Elite II : Hull 625 - 2013 Lexus LX 570 San Antonio/Boerne - Texas Hill Country Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted January 22, 2022 Moderators Share Posted January 22, 2022 The most fool proof, easiest, least expensive way to monitor propane tank levels is to simply leave one tank's valve closed. When the cooktop will not light then switch to the other tank and get the first tank refilled. 😇 Bill 4 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted January 22, 2022 Moderators Share Posted January 22, 2022 38 minutes ago, topgun2 said: The most fool proof, easiest, least expensive way to monitor propane tank levels is to simply leave one tank's valve closed. When the cooktop will not light then switch to the other tank and get the first tank refilled. 😇 It’s worked well for me. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
John Welte Posted January 22, 2022 Share Posted January 22, 2022 1 hour ago, topgun2 said: The most fool proof, easiest, least expensive way to monitor propane tank levels is to simply leave one tank's valve closed. When the cooktop will not light then switch to the other tank and get the first tank refilled. 😇 Bill Very fool proof. It's what we have done for years too. 1 John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Link to comment Share on other sites More sharing options...
johnwen Posted January 22, 2022 Share Posted January 22, 2022 40 minutes ago, John Welte said: Very fool proof. It's what we have done for years too. Us too 🙂 1 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/ Link to comment Share on other sites More sharing options...
Steph and Dud B Posted January 22, 2022 Share Posted January 22, 2022 2 hours ago, topgun2 said: The most fool proof, easiest, least expensive way to monitor propane tank levels is to simply leave one tank's valve closed. I know a lot of people do that but we've always run both tanks on and checked the little red changeover indicator every day or two when using a lot of propane. Never ran dry in 20 years. Would hate to find out we're out of propane when the furnace quits at 2:00 AM. Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999: Link to comment Share on other sites More sharing options...
Trainman Posted January 22, 2022 Share Posted January 22, 2022 Thanks everyone, I got it all figured out from the responses you'all posted. trainman 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold. Link to comment Share on other sites More sharing options...
Galway Girl Posted January 22, 2022 Share Posted January 22, 2022 I’ve been using both my hand and recently my laser temp reader. I pour a cup of hot water on the tank and scan down the side until the temp drops and stays solid. Works well. 2 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Link to comment Share on other sites More sharing options...
