Gliddenwoods Posted November 7, 2022 Posted November 7, 2022 Our TV has "dropped" into viewing position when towing. We are interpreting this action as a message that the TV should be in the down position when towing. Those of you with more tow traveling miles agree? Any counters to our conclusion as why not? A few brief replies would be appreciated. Thanks 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Moderators Mike and Carol Posted November 7, 2022 Moderators Posted November 7, 2022 Ours is folded up while driving, not down. In fact, it’s been folded up for several years since we don’t really watch TV while camping anymore. I should just remove it. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
CnC Posted November 7, 2022 Posted November 7, 2022 Ours is always up when towing. It's never came down while towing. Arizona | 2020 Oliver Elite II Twin bed Hull #617 | 2021 Ram 1500 e-Hemi 4x4
Ralph Mawyer Posted November 7, 2022 Posted November 7, 2022 57 minutes ago, Gliddenwoods said: Our TV has "dropped" into viewing position when towing. We are interpreting this action as a message that the TV should be in the down position when towing. Those of you with more tow traveling miles agree? Any counters to our conclusion as why not? A few brief replies would be appreciated. Thanks Check the nut/bolt hidden in the hinge. Mine kept dropping and found the nut almost fully backed off. Need to remove plastic end cap on hinge. 2020 Legacy Elite II : Hull 625 - 2013 Lexus LX 570 Factory Upgrades: Truma A/C, 640AH Lithionics, Alcan Springs, 5200 Axle, Bulldog Shocks (June 2025) San Antonio/Boerne - Texas Hill Country
bhncb Posted November 7, 2022 Posted November 7, 2022 THere are a few things you can do to address this problem. On the mount assembly: 1. The hinge bolt should be just tight enough to hold the TV in any position and require some force to change the angle. 2. The gold anodized latching bar should likewise be tight enough that it doesn't spin freely, but not so tight that it can't be turned with two fingers. 3. When pushing the TV up to the stored position, conclude with a downward pull to fully seat the latch. Lastly, for insurance, find some foam packing material or pool noodles and cut some pieces to wedge between the TV back and overhead cabinet. These will keep the latch under tension and cushion any TV wobble. 3 2
Geronimo John Posted November 7, 2022 Posted November 7, 2022 1 hour ago, CnC said: Ours is always up when towing. It's never came down while towing. Ditto. Up. That's how it was when I picked up our OE2. It took me a month to figure out how to lower it. (Doing so was low on my learning curve. 🙂 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Katjo Posted November 7, 2022 Posted November 7, 2022 We keep ours up. It dropped once while towing so we tightened the hinge bolt, no problems since. 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
Gliddenwoods Posted November 7, 2022 Author Posted November 7, 2022 Thanks for the responses and some good advice as how to maintain the up storage for towing. 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Moderator+ ScubaRx Posted November 8, 2022 Moderator+ Posted November 8, 2022 That sucker will come down????? We've always just both lay with our heads under it and look up at the screen. I'll be a..... 6 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Moderators topgun2 Posted November 8, 2022 Moderators Posted November 8, 2022 10 hours ago, ScubaRx said: We've always just both lay with our heads under it and look up at the screen. Sure does beat rolling the Oliver over on its roof so you could lay on your stomach!😇 4 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
SNY SD UP Posted November 10, 2022 Posted November 10, 2022 Our TV actually broke at 2 of 4 attach points (see picture, with yellow circles on addtl fractures) and started to come apart at the back where the bracket attaches to it, so I have removed the TV. Sometimes we would find the TV down when we entered the trailer while stopped between setups. I always pushed it back up to the catch, sometime it was down again, when we arrived at our final destination. I say sometimes, but not always. We would then put it up when we were setup and inside unless we were actually viewing TV, which was like not very often. Possibly caused - by starting out with trailer tire psi of 80 (at delivery) and we did not change that for about the first 10,000 mi, until I started to read threads on recommended tire pressure, then we dropped it to 65psi. It would still come down, but not always, and then we lowered our trailer tire pressure to 55psi. By then I noticed it was beginning to pull apart at the back of the TV. If I had to do over, I would leave it down when under tow, and then raise it up to catch, when we are setup and inside. I never did put in pool-noodle sections to act as shock absorbers. Before our next outing, I will repair the broken area and re-attach it in the trailer. We will however leave it down while under tow... and put it up when setup and Willis (KamperKat) wants to lounge on top of the nightstand. i will also look at any adjustment that can/need to be made on the bracket as mentioned above. Regards, 1 3 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
Geronimo John Posted November 11, 2022 Posted November 11, 2022 I don't recall reading anything about "Up" or "Down". Did I speed read over this chapter when I read the O&M Binder? TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Mcb Posted November 11, 2022 Posted November 11, 2022 Our tv is wire tied so it can’t come down while driving.. which it did several times. since we don’t use it this isn’t an inconvenience .. Mark & Deb..2020 Elite II..Dearie..Hull #685..2016 Tundra
John Dehne Posted November 11, 2022 Posted November 11, 2022 We travel with ours down to take stress of the tv mounts and have tightened the hinges bolt also. Running 55# tire air pressure differently helped. It would be nice if there was a tv setting to invert the picture so you could watch it while it was up. 😀 1 John & Chris Dehne Manchester, MD. 2021 Elite II twin Hull# 901 “Fiberbeergrass” 2021 Ram 2500 Cummins 4x4 Life is good!
Steph and Dud B Posted November 11, 2022 Posted November 11, 2022 20 minutes ago, John Dehne said: We travel with ours down to take stress of the tv mounts I've been thinking about this. It does seem that the raised position puts more stress on all the mounting points than the lowered position would. Right?? Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Geronimo John Posted November 12, 2022 Posted November 12, 2022 (edited) On 11/11/2022 at 11:41 AM, Steph and Dud B said: I've been thinking about this. It does seem that the raised position puts more stress on all the mounting points than the lowered position would. Right?? In the down position, It would put the mounting screws in more sheer. With it up, the TV is resting on the mount. That should take off most of the stress of travels. So my pea-brain says it should be up on rough travels. That said Thanks Seph and Dud B for the oops. If my mount looked like the below, I would consider adding an aluminum plate between the TV and the rack to stiffen up the TV side of things. Edited November 13, 2022 by Geronimo John Corrected tech error by Steph and Dud B. :-) 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Steph and Dud B Posted November 12, 2022 Posted November 12, 2022 1 hour ago, Geronimo John said: With it up, the TV is resting on the mount In the up position the TV hangs down from the mounting screws. I'd expect the TV case design to account for shear, since they normally hang vertically on a wall, but not for loads applied pulling against the back of the TV. 2 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Patriot Posted November 18, 2022 Posted November 18, 2022 We leave our TV in the stored up position, no issues. 👍🏻 Patriot 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
John and Jodi Posted November 18, 2022 Posted November 18, 2022 Thanks @bhncb for the suggestions. Our TV comes down often. I'll go through your list. John and Jodi San Antonio, TX 2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost. Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
AlbertNTerri Posted November 19, 2022 Posted November 19, 2022 Wedging a custom sized pool noodle on either side of the TV (in the up position) has become one of our check list items for breaking camp. It took a couple of tries to get the right lengths (the left and right will be slightly different) but one noodle provides plenty of material to make a few attempts at it 1 Albert & Terri Sterns Paonia, Colorado Elite II Hull #1125 Standard Floorplan / 2017 Ford F250 gas
Gliddenwoods Posted November 19, 2022 Author Posted November 19, 2022 9 hours ago, AlbertNTerri said: Wedging a custom sized pool noodle on either side of the TV (in the up position) has become one of our check list items for breaking camp. It took a couple of tries to get the right lengths (the left and right will be slightly different) but one noodle provides plenty of material to make a few attempts at it Could you please share a photo of this technique? Thanks. 2 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Moderator+ ScubaRx Posted December 28, 2022 Moderator+ Posted December 28, 2022 Ours has ridden >150K miles in the up position, 90% of the time with 80psi in the tires. I’ve found it down only a couple of times. It sounds as if some have not tightened the adjustment screws properly. Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
John and Debbie Posted December 28, 2022 Posted December 28, 2022 On 11/18/2022 at 8:31 PM, AlbertNTerri said: Wedging a custom sized pool noodle on either side of the TV (in the up position) has become one of our check list items for breaking camp. It took a couple of tries to get the right lengths (the left and right will be slightly different) but one noodle provides plenty of material to make a few attempts at it Is that to keep some tension on the TV so if the trailer bounces, the TV doesn't come down to viewing position? Any pictures of how you do that? John 1 John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
AlbertNTerri Posted January 9, 2023 Posted January 9, 2023 sorry to take so long to get back on this, we've been on the road and havent been checking the internet. I'll see about getting some pictures and post them in the next day or two. 1 Albert & Terri Sterns Paonia, Colorado Elite II Hull #1125 Standard Floorplan / 2017 Ford F250 gas
CnC Posted January 9, 2023 Posted January 9, 2023 Ours has never come down in more than 12,000 miles. That may be because we eliminated all the cords except power, antenna and HDMI when we recovered them with a white protective wrap. Charlie. 1 Arizona | 2020 Oliver Elite II Twin bed Hull #617 | 2021 Ram 1500 e-Hemi 4x4
