I have seen the questions many times here on our forum asking if this or that is a good tow vehicle.  I would like to compile and publish a list on our forum regarding our respective tow vehicles.
I admit I am doing this for selfish reasons as I may be in the market for a new tow vehicle and would consider those mentioned most here when I go to buy.
Thanks
I know most of us have our tow vehicle listed in our signature.  If you do then just make a post and I will record it.
Posted.
I assume that is a 3500
posted... looking forward to the results
2022 Elite II, Hull #1097  Elli Rose 🌹 and she has the solar panels with the 390Ah lithium batteries.  Our tow vehicle is a 2025 Ford Lariat F-250 Super Duty 4wd, 6.7L Diesel with the Max tow package.  Elli Rose also has the street side awning and several walnut and cherry mods on the inside.
Here ya go..and thanks for compiling the list.
Just arrived at the Mother. Tow vehicle below. 😊
Checking In..from Sarasota
Legacy Elite II   Hull 218  TV  2023 Ford F-150 Lariat   2x4   5.0L Max Tow Pkg   Ham W8CB    South Central Michigan
I’ve had four different tow vehicles. Finally found the one that works for us.
@HDRider thanks for doing this but please list which model trailer the owner is towing in your results.
2014 Ford F350 Super Duty 6.7 Power Stroke with heavy duty tow package; 3.55 ratio; AirLift rear suspension
2023 Elite ll Twin Bed and Lithium Pro and Truma Package; Hull #1368; Delivery Date: April 12,2023
Homebased in Richland, WA
@HDRider
2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, pulling hull 193
Mark & Claudia
“Mr. Douglas” 2024 LE ll twin, hull # 1457, Truma AC & WH, Platinum solar, Natures Head
2024 Ford f250 Lariat Ultimate 7.3L gasser / 3.75, FX4
Here is what I have so far.  Correct anything I got wrong.  I had some trouble with abbreviations or the TV coding.
