I guess there are pro’s and con’s for the never-lubes.  Seems like a good thing, not to have to worry about repacking all the time.  I have my bearings repacked and brakes checked every spring before the rally.  7 years and still original bearings.  We do 10-15,000 miles a year.  Mike
  • 1 month later...
Well, I took on the challenge of replacing the bearings and races in my 2021 Elite I. It was actually not bad at all. Took a couple of hours on the first wheel because I was careful to check and double check each step to make sure things were correct. . Second went much faster. The original set of bearings appeared fine and had “China” imprinted on them but don’t know enough to comment on their quality. I used Timken products all the way around along with Redline CV-2 grease. Repacks will apparently be even quicker since the races aren’t removed and replaced. Anyway, definitely a DIY project if you’re physically able.
2021 Legacy Elite I , Hull #765
2021 Chevrolet Silverado 3.0 Diesel
Navarre, Fl
  • 3 weeks later...
2021 LE 2
Timken counterfeits or WBA app wonky...
Last year, I bought Timken bearings from Rockauto to replace all the original wheel bearings. I used the WBA app to authenticate them. Oliver service performed the work. Oliver saved the original China bearings for me to keep as "road spares".
In preparation for repacking this year, I purchase six seals and two sets of Timken bearings to have on hand, if needed. These bearings were also purchased from Rockauto. I checked them with the WBA app....which indicated that both of the set4 and set17 bearings were counterfeit !!
After sleeping on it, I started trying to find out more info on the WBA app....revisions...updates...reliability reviews. Most of what I found was marketing speak.
I decided to delete the WBA app from my iphone (originally downloaded in 2022) and download again. This time the app approved as genuine both of the set17 and one of the set4.
Once again I deleted and downloaded the WBA app. I rechecked all the sets with the same result...one set4 counterfeit.
Next, (without another delete/download) I very gradually moved the iphone camera over the counterfeit set4 CR code without the bar code in the image.....and before my very eyes the counterfeit set4 transformed into genuine Timkens.
I share this with the group for anyone who uses the WBA app for authentication.
So, do I have genuine or counterfeit? False positive?...false negative?...scam WBA app?
I've bought OEM parts from Rockauto for years without incident.
I guess the bottom line is to do the yearly bearing maintenance and carefully inspect them. I'll look forward to how last years installed "genuine" Timkens look this year.
Steve
  • 1 month later...
I just ordered Timken bearings for my E2, from Summit Racing Equipment. Upon receipt and inspection they are ALL labeled, “Made in USA”!
shipping was quick and free.
2021 Elite II, Hull# 898
How are folks doing with the Never-lube bearings on the new trailers? Curious if it's worth having a set of backups in hand with these kind of bearings on our Oliver.
No issues the first 2K miles on Hull #1291.  But, bearing issues usually do not appear for at least 10-12K miles.  That said, I ordered a Nev-R-Lube bearing cartridge to have on hand as a backup, just in case.   In the event of failure, it will save at least a week of down time waiting for shipment of the replacement cartridge.
  • 3 weeks later...
On 4/28/2022 at 3:36 PM, topgun2 said:
Flat tire - I carry a "plug" kit that I can get in WalMart.  I've always carried one of these kits - with or without the Ollie in tow.
Wheel bearing issue - I carry a set of bearings like this:
While I could change out the bearings with this set, that is NOT my intent.  It is fairly easy to get the drum off the axle and carry that to virtually any gas station or tire shop that has a mechanic.  The issue is not doing the job on the side of the road where it could be fairly dangerous, but, getting to a safe place and NOT having to wait for them to order the bearings.
Yes, these bearings are fairly standard, but, I don't want to hear, "I'm sorry, we just sold our last set this morning".  I've been carrying two of these sets around for the past seven years - just in case.  And, before you ask - yes, they are made in China.  However, I figure that they will last long enough to get me home where I can do a proper job with good bearings and good grease.
Bill,
on AMAZ is this your "on the fly" kit
https://www.amazon.com/Trailer-Bearing-Spindle-Redline-BK2-100/dp/B002PNJZN8/ref=sr_1_17?crid=17SIRFR32CI5R&keywords=trailer+parts+pro+redline+BK2-100&qid=1681157189&sprefix=trailer+parts+pro+redline+bk2-100%2Caps%2C218&sr=8-17
My Visited North America Map
Certainly that looks the same and the part number is the same.
I've had tow sets of these in my Oliver since day one - over 7 years ago - and thankfully have never needed either set.  They look exactly the same today as they did then.  Good insurance.
17 hours ago, ScubaRx said:
If there's a downside, it would be that if/when you need to replace them it will cost a lot more than the old style bearings and seals. A sealed Nev-R- Lube bearing Kit -42MM CARTRIGE & ATTACHING COMP, FITS 5,200 LB & 6,000 LB AXLES - Part #K71-997-00 will cost over $300 per wheel. I would be remiss to only replace one at a time.
A friend of mine just replaced bearings on a Nev-R-Lube axle with genuine Timken bearings bought from Summit for $50 each. Same part number on the bearing as OEM. Worth researching if needing replacements or backups.
  • 1 month later...
I have a few questions re wheel bearings on our Elite 2:
If the bearings are appropriately maintained, how long can they be expected to last?
if the bearings are in for service anyway, is it worthwhile to replace the original bearings with Timken?
The bearings on our trailer now are original to the trailer and are whatever brand Oliver uses. They have held up fine so far, and mechanics who have looked at them have indicated that they are decent quality.
Thanks in advance.
David
Kim and David Thompson Nomads' Nest 2018 LE2 #366 2018 Toyota Tundra, 4x4, 5.7L
Thanks in advance.
David
With appropriate maintenance, I would expect the bearings to last decades. Your original bearings are of what came in the axles supplied by Dexter to Oliver. To the best of my knowledge, Oliver doesn’t actually have a dog in that race.
I agree with ScubaRx, quality bearings can last indefinitely. What kills bearings quickly is water contamination, cheap seals leak, then corrosion causes pitting and grease breakdown. Even if you don’t want to upgrade the bearings, I strongly recommend the Timken seals they are FAR superior to the  $2.00 cheap ones. Change the seals for new Timkens at every service.
One thing I like about eliminating the chrome hubcaps is that you can install marine style caps with rubber inspection plugs, you can pop off the plugs and easily see if the grease is still in good condition. This lets you extend your service intervals. You must seal the perimeter where they go into the hub with silicone sealer, or they will seep grease and sling it out onto your pretty wheels.
I also strongly recommend Redline CV2 full synthetic grease over any other brand. Another tip that may not be practical, depending on your climate, never tow on rain soaked highways…. that spray acts like a high pressure hose, driving water and grit past the seals. That problem is easy to avoid:
On 10/7/2021 at 6:55 AM, Mike and Carol said:
Certainly the sets I bought are "Made in China" but to get me back on the road until I get home - I don't care.
We carry the same - pre-grease packed in ziplock bags, ready to install on the side of the road....
  • (SOLD) 2022 TUNDRA
On 4/17/2022 at 2:27 AM, Frank C said:
Here’s the tools/etc. that I used for my recent replacement of the bearings on all 4 wheels:
I would add a full roll of paper towels, a 5 gallon "Home Depot" bucket (or simular), and a boat throw cushion.
The last two items are optional, but trust me if you are my vintage and choose to skimp on them ..... you will regret having done so.
I do carry a large Husky kneeling pad to make things more comfortable when working at ground level.  I don’t have much trouble kneeling down to work on the wheel bearings, it’s getting back up that’s the issue 😂.   I’m “vintage” as well.
  • Care 1
I love that pad.  My truck has a similar one I always carry as well.
Chris
o-o  2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110"
o-o  2024 Ford F-250 Lariat, 7.3L Godzilla gasser
o-o  Augusta, Georgia
Because of this thread I had repacked my bearings over a year ago, wow, over 1.5 years.  Oy!  Time flies.
Anywho, when putting on my tire I had got checked out at the tire shop I noticed not one, but two wheel bearings needed to be snugged up a tad bit.  It was a good find and a quick tweak.
All-in-all, a good night for minor repairs and improvements.  Maybe a step closer to a super long trip.
I still prefer these forums over Facebook.  🙂
  • Like 7
Chris
  • 1 year later...
I was in the automotive business for quite a few years and learned alot about bearings and grease. I also have been boating for over 40 years and dunk my trailer in salt water all the time.  Over the years I've learned that China can make quality bearings depending on who manufactures them.  I prefer the Japanese bearing because they seem to have the best quality control. Had the least issues with them and got the most life time without on ball going bad first. Mobil I synthetic grease seem to work the best because it's not effected by water and withstand high tempertures with melting.  Doesn't mix and look like chocolate milk and lose it lubricating ability. I've been using Mobil I sysnthetic on grease fitting on my vehicles and three trailers and never had a issue with bearing failures. Just my take.
Hiroshi
2023 Oliver Elite #1299
2024 Lexus GX550 Overtrail
  • 1 year later...
Can someone explain to me (with pictures and drawings if needed) how the Neverlube bearing system works. Being more of a tekkie and less of a motorhead, I have understood that axle bearings are -  1  an Inner race, and 2, an outer race on a common shaft. with shoulder bracing against inner movement of the inner race, and a nut preventing outer movement of the outer race. Someone recently posted on this forum that the Timken Set 49 was a direct replacement for the Neverlube.  Price difference being "¼ of" with Timken being the cheapest for once. I have looked at the Timken Set 49, and it is ONE outer bearing sleeve with two inner races. Maybe 2" long. I cannot begin to guess how that works.  Please help the mentally challanged.
theOrca,  2020 Legacy Elite II, Twin, Hull 615
Tow Vehicle - 2016 Ram 1500, Hemi, 8 Speed with 1500# rear springs and Goodyear bags.
Nevermind. I found the answer about two pages before this one:
There is an excellent YouTube tutorial by the Trailer Smith illustrating the difference between never lube, easy lube and traditional bearings. I would encourage you to look up this video as he tears each one apart and explains his takes in depth.
I also like the Husky pad, keep three of them around and one always comes with me on trips.
Legacy Elite II #70
I repack original bearings and replace seals every two years on our Ollie's original 5200lb axles, we don't tow Ollie as many miles as Mike & Carol. Bearing repack gives me the opportunity to inspect brakes, drums, bearings and races. I try not to let trailer hubs get hot while towing by using engine braking towing down mountain grades.
Here's two videos by Trailer Smith, Dexter Nev-R Lube and Bearing Buddy VS. EZ Lube-What's The Difference:
Edited by rideandfly
Bill 2015 LE2 2024 F-350 6.8L
Thanks for posting those. Have a number of his videos but not the one with the bearing buddy what ever that is.
Legacy Elite II #70
The Nev-R Lube bearings work like a pair of conical bearings pressed into a case to keep the grease in on a "permanent" basis (expect on average a 5-year life). You cannot pack these bearings with new grease to prolong their life.
DX031_071_03__93538.1393510255.jpg?c=2
As far as bearing maintenance, I already wrote a post showing removal and replacement:
